Old 01-23-2006, 04:27 AM   #1
BlazedGlory
BlazedGlory will become famous soon enoughBlazedGlory will become famous soon enoughBlazedGlory will become famous soon enough
S13-KTS, 300ZX Brakes, 17x8/17x9, 235/45 - 255/40?
I know people are running this setup because I've read about it somewhere, but I've been searching for the last hour or so and cannot seem to find it. I appologize if I've overlooked it.
I have an S13 (hatch). I'm getting KTS coilovers, 300zx front brakes, 17x8 +35 and 17x9 +20 5zigen fno1rc's (4-lug) with 235/45-17 and 255/40-17 Bridgestone Potenza RE750's. Will I need to run spacers anywhere to get this to fit? I've been told that I really need a +25 offset on those 8" wheels. If this is so, where can I get a 10mm hubcentric spacer? H&R only sells a 5mm and a 15mm (w/ studs) I think. If I get two 5mm spacers could I use the factory studs still? Will I need to roll fenders?
Thanks!
BlazedGlory is offline   Reply With Quote
Old 01-23-2006, 08:41 PM   #2
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
Run 17x9 +20 in the front.
17x10s in the rear.
I dont think you can use a 10mm spacer on stock studs, I run a 8mm and I barely have enough threads. Like, 3 threads.
Best bet, get better wheels.
My 17x8 +8 fits fine in the front.
95zilvia is offline   Reply With Quote
Old 01-23-2006, 08:49 PM   #3
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
17x10s in the rear.
I would not recommend 17x10 in the rear on a S13. 17x9 no problem but unless you go widebody with a very low offset, you stand a chance of rubbing up against the inside of your wheel well with a 17x10 on the rear of a S13. On S14's its fine.
New Video
Buy my mounts!
Old 01-23-2006, 08:52 PM   #4
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
run lower offset if you can however you will be pushing clearance wise with those sizes. considering I had a similar setup, tein he + 300zx 30mm calipers in the front on my s13 and my 16x7 advan sa3 with ~+35 cleared with some space.
MasterOFDrift is offline   Reply With Quote
