Old 02-02-2012, 10:57 PM   #1
nissan-fanatic
nissan-fanatic's Avatar
nissan-fanatic is an unknown quantity at this point
changed my rear brakes and now got this smell
Ok I changed my rear brake pads and rotors yesterday and today I noticed my rear driver side tire(I'm assuming its the tire) smells like I been doing burnouts on it. In other words like burnt rubber. After letting the car sit for awhile, I go back and still smells the same way. All the other tires don't smell like that. Wat can it be?
I like to handle my s14 like I do my woman... Sideways
nissan-fanatic is offline   Reply With Quote
Old 02-02-2012, 11:02 PM   #2
bussitcustoms
bussitcustoms is an unknown quantity at this point
Check and see if that rotor is significantly hotter than the other side after driving the car. Sounds like a seized caliper.
bussitcustoms is offline   Reply With Quote
Old 02-02-2012, 11:11 PM   #3
Eazy_tom
Eazy_tom's Avatar
Eazy_tom is an unknown quantity at this point
New pads have to bed, its normal.
Eazy_tom is offline   Reply With Quote
Old 02-02-2012, 11:24 PM   #4
jesse_s13
jesse_s13's Avatar
^win....lol
jesse_s13 is offline   Reply With Quote
Old 02-03-2012, 07:13 AM   #5
nissan-fanatic
I got ceramic pads if that helps
Old 02-03-2012, 08:01 AM   #6
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
as long as you were able to twist in the caliper piston the smell you are smelling is the top layer of the pad burning up, which is completely ok...the thing you should be doing is drive it then look at the rears does one side have more brake dust than the other if it does then the side that you have is the side that is seized/broke
S-Nation S13 is offline   Reply With Quote
Old 02-03-2012, 09:14 AM   #7
nissan-fanatic
If its seized or broke... Does that mean I gotta replace the caliper?
Old 02-03-2012, 09:20 AM   #8
nighthawk48
Trader Rating: (26)
nighthawk48 is an unknown quantity at this point
Feedback Score: 26 reviews
yes.
blahlength
nighthawk48 is offline   Reply With Quote
Old 02-03-2012, 09:32 AM   #9
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
The stock rear calipers suck. It always seems to be the driver rear that goes first. At least for me in the 5 s chassis I've owned. I did the rear z32 conversion and am so happy with it.
SnakeKack is offline   Reply With Quote
Old 02-03-2012, 09:49 AM   #10
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
^meaning the back calipers need to be twisted open unlike the front that just need to be squished open. I've known a few people that busted the rear's by going ape on them.
OP, check your brake fluid, make sure you are not losing any as well.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 02-03-2012, 10:42 AM   #11
nissan-fanatic
U must be crazy thinking for me to touch the rotors. But I did notice the rear driver side caliper is much hotter than the rear passenger
Old 02-03-2012, 11:01 AM   #12
reaxion
reaxion's Avatar
reaxion is making a name for him/her selfreaxion is making a name for him/her self
Send a message via AIM to reaxion
if the piston isnt the issue, did you lube the slide pins and clean/lube the hardware?
reaxion is offline   Reply With Quote
Old 02-03-2012, 11:10 AM   #13
240jake
240jake is an unknown quantity at this point
Just went through something similar so heres my 2cents.
Mine started doing this when the brake booster started to go out and then finally went out, first it was just the rear drivers side(furthest caplier from the abs in my case), then all 4 just started locking up completely while driving!
First id pull the caliper and pads off, clean the shit out of it with brake cleaner, then make sure to lube the pins and use the correct brake tool to turn back in the piston when you go back together.
Go ahead and bleed the whole system as well, a pneumatic brake bleeder is recommended for that.
If that dont take care of it then youll want to look into making sure your booster is working right by checking its vacuum(pedal should drop significantly when you start the car) and replace your caliper if all else fails.
good luck man.
240jake is offline   Reply With Quote
Old 02-03-2012, 11:16 AM   #14
Edwin562
Edwin562's Avatar
^^This, OP make sure you inspect everything again and check for anything is out of the normal.
Old 02-03-2012, 12:59 PM   #15
nissan-fanatic
good luck man.
Wow... Ur wheels locked while driving! That's some scary stuff! I think its the pins that need to be lubed cuz they were dry. Didn't put any grease cuz I didnt have any. I will do it asap. Also isn't one of the gaps on the piston suppose line up with some little bump thing on the pad?
Old 02-03-2012, 08:20 PM   #16
nissan-fanatic
I just fixed the piston on the caliper on the rear driver side. It wasn't on right and also greased the pins. I'll see how it works tomorrow
Old 02-03-2012, 09:04 PM   #17
lflkajfj12123
fahbreeze mah du
Old 02-03-2012, 09:04 PM   #18
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
Bead/Brake thoze pads in =]]]
Renelovesnike is offline   Reply With Quote
Old 02-03-2012, 10:16 PM   #19
nissan-fanatic
I put grease on the pads too...
Old 02-04-2012, 10:11 PM   #20
nissan-fanatic
problem fixed guys... thanks for the help
Old 02-04-2012, 10:14 PM   #21
Bubba
Bubba's Avatar
Bubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-known
grease on the pads???
Walking away now. Hope everything works out for ya.
Good at wrenching, terrible at electrical. Lord help me... HAHAHA
Bubba is offline   Reply With Quote
Old 02-05-2012, 05:08 PM   #22
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
grease em if you got emm hahah
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 02-05-2012, 05:30 PM   #23
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
this made me lol
herbieS13 is offline   Reply With Quote
