07-14-2008, 12:27 PM | #1 |
My gt2871r .64 makes over 400 rwhp!
finally got my car to the dyno this weekend. did 4 runs.
first was of the acuator at 10 then the 2nd was at 16 psi the last run was set at 20 psi with a amll spike to 24 right near the end of the pull. here is the dyno chart. stock block redtop sr20det my mods include: z32 maf 740cc injectors BC valve springs new valve seals Bc 264 cams greddy intake manifold greddy ls intercooler hks bov megan racing exhuast manifold gt2871r .64 turbo 52 trim meggan racing o2 housing top speed down pipe 3 inch ebay cat delete and cat back exhuast. enthalpy tuned ecu. that i picked up on here that was tuned for the same mods i have. i am getting ahold of scott to geta reflash and get my afr worked out at idle and cruising too. i think i have a leak after my maf before my turbo. which i need to fix because the idle is fluctuating more then normal. this is in my 93 s13 which i am geussing weighs i nat about 2600 pounds
My Twin Scroll Gt30r Sr22det Build Last edited by idahotuner; 07-14-2008 at 04:25 PM.. |
07-14-2008, 12:33 PM | #2 |
maybe you dontneed a reflash. maybe that leak after your maf before you turbo is what is throwing your car off. running lean. plug that up and see what happens before go out and spend money you dont need to. good job with the numbers tho.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
07-14-2008, 12:37 PM | #3 |
thanks man. no i fixed the leak before we dynoed it. but it has just came lose again. i need to get some coublers that are fiberglass reinforeced for where the intake pipe conntects to the turbo.
and i want to get a 2 step rev limitor porgramed in if i can. i know he is working on them and i sent him and email to find out.
My Twin Scroll Gt30r Sr22det Build |
07-14-2008, 01:08 PM | #5 |
you can see on that chart my afr's they are better once i get under boost but before they arnt.
lol hidden mods? haha i have an avc-r boost controller. and i have no ps and ac which free up some power but other then that not really.
07-14-2008, 02:14 PM | #7 | |
Duh right in front of me. What is that about 12.5? Lol, yeah I said "hidden mods" cuz the retards around here don't believe those numbers to be possible on that turbo (I have a .86). Thanks for the motivation to go get dialed in! |
07-14-2008, 02:35 PM | #8 |
thanks s0apgun. i have a few othe small supporting mods. but that is just the engine. i spent alot of effort getting the car to be able to ahndle the power.
obeewon: i agree tons of people say it isnt possible. and i have found 240 people are alot more conservitive then most other people when it comes to numbers and amoutns of boost they run. alot of other people are running 24 psi on pump gas witha gt2871. i did alot of seaching t see what would work together in the same rang. and i am happy with this build. i met my goals. the guys at the shop said that with and adjusted timing map and fuel map i should be able toget even more. but we will see.
07-14-2008, 03:16 PM | #11 |
fp 20g is the mitsubishi turbo right? i liek garret turbos lol but then they are the only ones i have used. after i run this build for a while (like a year or so) i will go top mount twin scroll witha built block.
07-14-2008, 03:48 PM | #12 |
nice excellent numbers idaho, i just got my motor back together and running also and we have a similar set up, gt2871r .52 trim, 740cc, greddy intake, and enthalpy tune i can't wait to break it in and go see what i can make.
07-14-2008, 04:05 PM | #13 |
thanks guys. i should have mentioned some where up there that thisis o nthe stock block
07-14-2008, 04:15 PM | #14 |
yeah thats what makes it even more sweet haha
wish i could do that with a ka, but 300whp will have to suffice i would just be happy with the 400hp, guys at the shop want more but i'd be scared for the block after 400hp lol love this turbo |
07-14-2008, 04:21 PM | #15 |
This is very close to my setup, only I'm thinking about keeping the stock IM for awhile. I am not looking for that much power but, it's nice to know it's capable.
07-14-2008, 04:21 PM | #16 |
a solid drive shaft is needed now though. cause i think my u joints are going out lol.
one thing for sure my big ugly 275/40 tires and HLSD sure get the power to the ground on the streets
07-14-2008, 04:23 PM | #17 |
yes i was very happy i went in there hopping for 380 at the wheels at around 20 psi. figuredi would get my reflash them come back and get more power. lol now i am worried i will geta reflash and loose power. but it will run cooler and be safer then.
07-14-2008, 04:28 PM | #19 |
^ lol i packed the graph around fora day showing everyone. so i spilt some water on it and got some bbq chips on it haha. thats what those smudge marks are that i think your reffering too.
oh i was editing my post when you were veiwing
07-14-2008, 04:54 PM | #20 |
Man w/ CTSV & a Car Seat
Why do you need a re-flash for? If you only need to tweak the fuel map a bit, just slap a SAFC on top to tweak it a bit. I doubt scott will change much to the timing map so no point of reflashing it. Also, curious what dyno you used...
07-14-2008, 05:01 PM | #21 |
well we will see here. maybe i will pick up a safc and just mess with it some i would lieka 2 step programed in though. i am waiting for him to get back to me about it.
the dyno used was a Dynocom 1800
07-14-2008, 05:09 PM | #23 |
yeah i had to chose between two dynos with in a 2 hour radius. and the other one wasnt able to put a load on the car. so i went with this one. plus everyone recommended these guys over the other place
07-14-2008, 06:01 PM | #24 |
I ran my turbo at 22psi before I had an oil problem(not related) I would say 22-24 is the sweet spot. (.86)
This also shows how much more aggressive enthalpy is than JWT. I personally had a very bad expirience with them but he still does good things. |
07-14-2008, 06:06 PM | #25 |
WAT? local board member codyace puts out 400+whp with jwt tune and was one of the first to break 400whp with a gt2871r .64. JWT tunes are fine!
http://allies-drift.blogspot.com/ |
07-14-2008, 06:11 PM | #26 |
Yeah, I know. Look at ACE's dyno and look at Idaho here. There is a clear difference.
Im not saying anything is wrong with JWT. But you can even go on Enthalpy's website and see side by side comparisons between the two. There is just alot of juice left with conservative JWT tunes. Not knocking Jim Wolfe at all. Oh yeah Import Intell was running 412 on his for at least a year before I saw Aces dyno, he also tuned a few others over the 4 mark. |
07-14-2008, 06:21 PM | #27 |
Yeah im suprised thats cody hasnt chimed in on this yet.good #'s man should be alot of fun.oh by the way what exhaust mani are you runnin?
" NEO VVL BABY FTMFW!" Originally Posted by shagspeed Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines |
07-14-2008, 06:21 PM | #28 |
Nevermind...duh!!
07-14-2008, 08:01 PM | #29 |
I have the EXACT same setup but arc fmic, nurspec exh (not really going to make a diff) and I dont have the intake manifold, I can not wait to get the cams and bigger injectors in, my goal is 400. This makes me feel much better.
I was going to, but I can not think of a sig less than 75 characters. |
