Old 08-08-2014, 10:33 AM   #1
timlatshaw
timlatshaw's Avatar
timlatshaw is an unknown quantity at this point
s13 Rubbing Tire on Coils
Hi guys I am rubbing tire on my coil overs and I was wondering if spacers would fix the problem. Also what kind of spacers would be best, because I want them to last awhile.
timlatshaw is offline   Reply With Quote
Old 08-08-2014, 10:36 AM   #2
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
Spacers would push out your wheel therefore fixing your problem, as long as you purchase a spacer that is wide enough. If I had to guess 5mm is enough for most people if its barely touching.
You want a hubcentric spacer. Only buy hubcentric ones period.
And last but not least dependig on your coilover theres a little black plate that depending on the orentation of how you install them. It moves the coil closer or further from the wheel. That can also help your issue.
Good luck.
e30gangsta is online now   Reply With Quote
Old 08-08-2014, 10:37 AM   #3
timlatshaw
timlatshaw's Avatar
Thank you so much!
Old 08-08-2014, 10:38 AM   #4
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Yes.
http://www.ebay.com/itm/HUB-CENTRIC-...0369b7&vxp=mtr
You need 4x114.3 hub centric spacers with a 12x1.25 thread pitch. I have these in 15mm.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 08-08-2014, 10:46 AM   #5
e30gangsta
Originally Posted by 5280VertDET View Post
Yes.
Thread pitch shouldnt matter as they just slide on. Also that space would work only if he is 4 lug.
Goodluck.
- G
Old 08-08-2014, 10:49 AM   #6
timlatshaw
timlatshaw's Avatar
I am 4 lug
Old 08-08-2014, 10:50 AM   #7
5280VertDET
Goodluck.
- G
True, but I tried some 7mm spacers with factory studs and they didn't thread; even if they did I wouldn't be comfortable with the amount threading that was compromised.
The thread pitch matters if he doesn't want to buy new lug nuts for bolt on spacers, there is a lot of 12x1.5 bolt on spacers.
Old 08-08-2014, 11:44 AM   #8
Bullitt_180sx
Bullitt_180sx is an unknown quantity at this point
A 5mm slip on should fix the problem. Don't run anything bigger than 5mm on stock studs. You shouldn't need bolt on spacers at all.
Bullitt_180sx is offline   Reply With Quote
Old 08-08-2014, 12:13 PM   #9
Bushido
Bushido's Avatar
i've ran 7mm slip ons in the past. not a whole lotta thread engagement with a stock stud, but nothing bad ever happened...
Old 08-08-2014, 12:23 PM   #10
simmode1
simmode1's Avatar
I've always heard 7mm was the safe limit for slip-on spacers. But I'd rather just buy wheels & tires that fit.
"Simplicity is the key to brilliance." - Bruce Lee
Old 08-08-2014, 04:18 PM   #11
Bullitt_180sx
Most people don't have the ability to buy wheels sized to a specific millimeter. "Fit" is also a broad term. I feel a spacer anywhere from 3-7mm is very acceptable. I personally wouldn't run any bigger than 5mm on stock studs because I too ran 7s and one day on the way to work I lost 5 out of 8 lug nuts on the rear (3 off one side and 2 off the other). Car started shaking really bad so I pulled over. It's a scary feeling finding one lug nut holding on a wheel. On top of that, that lug nut loosened up enough to turn by hand and only had 2 threads under it until it came off. I live in a high construction area though.
Old 08-08-2014, 05:12 PM   #12
timlatshaw
timlatshaw's Avatar
I appreciate all the feedback
rubbing, spacers, spacers 4 lug
