Old 07-19-2005, 07:24 PM   #1
jedc
jedc is an unknown quantity at this point
Send a message via AIM to jedc
J30 Rear 5-Lug Hubs/E-Brake Assembly Etc.
I am selling a set of rear J30 spindles, hubs, lower control arms and e-brake assembly. This is a direct bolt on for an s14. S13 requires changing the bushings in the lca to s13 type or just grinding down the J30 ones, however this is the perfect time to install some energy suspension bushings in them. The J30 e-brake is similar to the z32 type with the drum setup. I haven't done any exact measurements but I know the e-brake cables are a little too long for an s13 so they should be pretty close on an s14. You can always modify them for an s13 though like the guys with the z32 rear brake setups. There was another guy who used this same stuff on his s13 here on zilvia. I can answer any questions you may have. I would like $100 plus shipping for all of this.
jedc is offline   Reply With Quote
