Old 08-14-2004, 01:42 PM   #1
S13Enthusiast
S13Enthusiast is an unknown quantity at this point
Exclamation Torquing 231 lb\ft Axel Nut
The FSM calls for 170-231 lb\ft of torque for the 36mm main axel nut, how do I torque this to the factory setting? My torque wrench and the ones at the auto store only go up to 140.
Should I just use the Dewalt electric impact wrench Ive been using to tighten it up nice and snug?
How do I measure this amount of force?
S13Enthusiast is offline   Reply With Quote
Old 08-14-2004, 02:31 PM   #2
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
its an axle nut. impact it on, put the pin in, and you're done. that is, unless you don't HAVE pins for your axles (cause S13's do).
MakotoS13 is offline   Reply With Quote
Old 08-14-2004, 02:44 PM   #3
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
just get a two foot breaker bar and stand on it or something. its not rocket science...
"ok i way 180lbs, therefore if i stand with all of my weight 1.25ft from the fulcrum on the breaker bar i will be applying enough torque."
torque = force x distance
so divide 230 ,or whatever you want it torqued down to,by your weight to get the distance to stand on the breaker bar
sometimes simple things work best.
citizen is offline   Reply With Quote
Old 08-14-2004, 02:45 PM   #4
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
HA! I wish I would have known the torque specs when I replaced my hub. I just used my beastly strength a gigantic ratchet and a big pipe to make it longer. The pin has kept it in so far, so hopefully I guessed right.
-Juan
240Stilo is offline   Reply With Quote
Old 08-14-2004, 02:45 PM   #5
rizzle
rizzle's Avatar
rizzle is an unknown quantity at this point
Actually if you go to a major auto parts store ie: pepboys, kragen, autozone. YOu can rent a torque wrench that goes that high. I think my torque wrench goes to like 150-180 or someshit I just went to autozone and rented one for free all they ask for is a deposit ie: credit card but you wont be charged.
rizzle is offline   Reply With Quote
Old 08-14-2004, 02:48 PM   #6
240Stilo
Junkie
240Stilo's Avatar
You're gay for using math....yeah I'm just jealous.
-Juan
Old 08-14-2004, 02:54 PM   #7
MakotoS13
MakotoS13's Avatar
you guys, do you honestly think that nut will come off with that huge pin in place? impossible. and the flip side. do you think that you have enough power to break that axle? hell no.
Old 08-14-2004, 09:15 PM   #8
Bradman123
Bradman123 is an unknown quantity at this point
lol, i had no idea there was such an equation...so it must be rocket science.
EDIT: whats a fulcrom? lmao i shoulda payed attention in school...
Bradman123 is offline   Reply With Quote
Old 08-14-2004, 09:37 PM   #9
Flybert
I impacted mine on when doing my five lug swap and I must have overdone it because the rear end got super hot and I think I was frying my bearings. I loosened it and torqued it to 150. I think the FSM asks for 158-180.
Old 08-15-2004, 04:53 PM   #10
Red
Red's Avatar
Red is an unknown quantity at this point
You go get the right tool for the job... easy!
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 08-16-2004, 07:04 AM   #11
sykikchimp
WOW addicted
sykikchimp's Avatar
I always just torques to 150ft lb's (max on torque wrench), and then turned it another ~1/8 turn past that.
Old 08-16-2004, 09:53 AM   #12
Andrew Bohan
fulcrum is the center of rotation. in this case, the nut.
