Old 09-09-2006, 05:37 PM   #1
drftfan
drftfan is a well-known jackass
rear hub, bearing
How hard is it to swap the rear hub and bearing on the s13? Is it all one unit?
drftfan is offline   Reply With Quote
Old 09-09-2006, 05:52 PM   #2
Irukandji
Yes, it's one whole unit.
Just take off the brakes, rotor, and have a 36mm socket for the axel nut.
4 bolts from the back, and you're done.
Irukandji is offline   Reply With Quote
Old 09-09-2006, 06:17 PM   #3
Agent23
Agent23 is an unknown quantity at this point
1 hour each side with air tools. If you want to separate the bearing from the hub you'll need a press, a set of step plates/ various large sockets and a bearing separator. See section RA-8 in the FSM for an illustration.
Agent23 is offline   Reply With Quote
Old 09-09-2006, 06:21 PM   #4
drftfan
Ok from the pictures I have seen I am not seeing any bolts. I am refering to the rear.
