Old 03-16-2007, 01:40 PM   #1
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
Damn KA Bogging
i have a mad bogging issue. i bought a 93 240 hatch that sat for a year before i bought it. i replaced plugs, hotwires, fuel filter, cat, o2 sen, maf, air filter by KnN w/ CAI, removed egr, ran 3 bottles of sea foam, rotor button, whole distributer assembly, and i think thats it. some times it dies if cold and i just cranked it. it will idle high like 1000-1200 until fully warmed up. its so embarrassing b/c sometimes when i go after a stop in 1st gear it will straight up bog out like im dumping clutch like a newb, itl do it between 2-2700rpm. i cant floor it at all in neutral or it will totally bog and start diieng. i cant figure this shit out. please please let me know what you think its gonna make me insane and end up hating KA's.
twofortyrida1388 is offline   Reply With Quote
Old 03-16-2007, 01:55 PM   #2
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
maybe your iacv valve is clogged.
s13gold is offline   Reply With Quote
Old 03-16-2007, 01:55 PM   #3
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
What does the ECU think the problem is? If you ask nicely it might tell you.
MELLO*SOS is offline   Reply With Quote
Old 03-24-2007, 04:08 PM   #4
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
LOL that is something I would say!!!!!
BigVinnie is offline   Reply With Quote
Old 03-16-2007, 05:14 PM   #5
twofortyrida1388
funny guy thanks for input.
Old 03-16-2007, 05:49 PM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
So have you pulled the codes from the ECU yet? Might point you the right direction and only take a couple minutes of your time. GL
Old 03-16-2007, 06:04 PM   #7
twofortyrida1388
its 8pm here and dark. im shure its not throwing codes because the engine light works and has never came on. I need to hit the sack kinda early because Im gonna go burn up some tires at the track tomarrow. thanks though i will def let you know tomarrow.
Old 03-24-2007, 04:11 PM   #8
BigVinnie
BigVinnie's Avatar
FYI the engine light doesn't always come on.It depends on the code. Mostly for smog emissions is when the light comes on.
I remember when I had to fix my speed sensors that the last jack ass ripped out. No engine light, but the ecu threw out the codes.
Old 03-16-2007, 06:07 PM   #9
twofortyrida1388
damn i killed a word or 2
Old 03-16-2007, 06:34 PM   #10
drftwerks
Vac Leak
Yay
giantroboteyes.wordpress.com/
Old 03-16-2007, 07:54 PM   #11
twofortyrida1388
thats what i thought but a fellow 240 buddy and i checked everything thing out and came up with nada. keep it coming though cuz im ready to fix this agrivating damn problem.
Old 03-16-2007, 10:22 PM   #12
switchflip
switchflip is making his/her stupidity well-knownswitchflip is making his/her stupidity well-knownswitchflip is making his/her stupidity well-known
i had a same prob but it was the maf mine is kinda gets lose when i hit a good bumb i just plug it back in and it acts normal
switchflip is offline   Reply With Quote
Old 03-16-2007, 10:57 PM   #13
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
Well I too am in the same boat just bought a 90 coupe SE model that the previous owner parked cause of the same issue....I keep being referred by friends back to airflow and fuel flow...I changed fuel injectors, fuel pump, fuel filter, coil pack, distributor, MAF, TPS, O2 sensor, exhaust keep in mind the parts came off of a perfectly good running KA. Picture below....I hope we can both find a solution???
davirene is offline   Reply With Quote
Old 03-16-2007, 11:16 PM   #14
johngriff
johngriff's Avatar
ROFL.
A mechanic could probably help you if you are that inconvinced.
It sounds like you are getting air in after the maf. Intake Mani gaskets, and piping between maf and T/B. What is the Vacum @ Idle?
[email protected]
Old 04-05-2007, 01:45 PM   #15
240sxhed
240sxhed's Avatar
240sxhed is an unknown quantity at this point
Originally Posted by johngriff
ROFL.
I had the same problem...it did infact turn out to be air getting in after the MAF. One of the off shoots of the plastic intake piping was extremely loose (near the passenger side of the radiator) tightend that up and problem dissapeared for now
1989 240SX SE fastback KA24DE.
240sxhed is offline   Reply With Quote
Old 03-17-2007, 04:35 AM   #16
twofortyrida1388
after it warms up it idles perfect about 770. Sometimes it is kinda fine. like it will bog a little bit when floored while driving but other times it like im dumping the clutch and the car acts retarded and bogs the fuck out. i wouldnt think i would have vac leak cuz after warm idle is perfect. I heard if intake mani gasket is bad you can hear a suction very clearly, like it will make a loud noice. I checked all vac lines 2/3 times and came up with nothing.
Old 03-17-2007, 05:47 AM   #17
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
check coolant temp sensor along with the harness plug for it... usually a culprit of KA's acting retarded
Sfourteen
dct223 is offline   Reply With Quote
Old 03-17-2007, 07:14 AM   #18
johngriff
johngriff's Avatar
Heat = expansion.
Effects on gasket? If you want help, you have to perform the proper tests. Put a vacuum gauge on the vehicle. If you dont even own a vac gauge, you should probably take your car to a mechanic.
[email protected]
Old 03-17-2007, 05:52 PM   #19
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Just because the check engine light isn't lit up doesn't mean there aren't codes stored on the ECU. When I had a code 34 for bad KS or KS wiring (killed performance from 3000+) there was no light. I have a short in my ect wiring harness now, and there is no light. Also I had a code for the o2 sensor, and again no light. It takes all of 5 minutes to pull the codes, and you won't even get greasy.
Old 03-17-2007, 06:12 PM   #20
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Yes code 34 will casue the bogging and huge power loss and shitty gas milage and will not illuminate a check engine light alone......i'll give you some good advice to help you diagnois a problem with the knock sensor, first you need a digital volt meter and ground one probe and back probe the other to the knock sensor pin in back of the ecu and with the key on engine off you should recieve 2.5 volts if you have a short to ground it will be closer to 0 volts and here the big headache savings info if you do have a shirt to ground it most likely gonna be found in the black plastic casing just above the fuel rail closly look for a thicker gauge black wire with a very slight bulge in it and thats gonna be your short to ground, this is a shielded wire by the way so when you repair it make sure to separate the shielding from teh actually signal wire when solding it back together.
I have personally fixed 5 S13 KA24DE with this problem with the same short to ground and the same exact location +/- 5 inches.
Old 03-23-2007, 07:13 PM   #21
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Could you show some pictures please just so it's totally clear. Thanks
smily_vigor is offline   Reply With Quote
Old 03-17-2007, 09:11 PM   #22
twofortyrida1388
hey thanks alot man i just back from myrtle beach sc for a drifting comp and i will def checks everything you said said and post up how it went.
Old 03-17-2007, 09:12 PM   #23
twofortyrida1388
i may be just a little tired. grammar is a bit shot.
Old 03-23-2007, 05:06 PM   #24
twofortyrida1388
I turned the ecu around and with ign in on position I turned it clockwise for 2 sec then read the led and it was showing 12. I think that is MAF. but I've replaced the MAF and the Maf wire is fine. WTF????:hammer:
Old 03-23-2007, 05:13 PM   #25
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Unhook the battery for a while to erase the code from your ECU. Then go for a quick drive and check them again. If you're still getting codes, something is still wrong.
Old 03-23-2007, 06:27 PM   #26
twofortyrida1388
thanks will do right now.
Old 03-23-2007, 06:28 PM   #27
twofortyrida1388
damn forgot to post that. but i unplugged battery for like 5-10 minutes and still nothing. The bitch still bogs the fuck out. what next??
Old 03-23-2007, 07:10 PM   #28
smily_vigor
Man i'm having the exact same problem. It bogs and jerks all out of the blue. Especially when i'm driving around normal then I come to the light, when I go to take off the car bogs and jerks a lot with no power and it basically almost shuts off. Even when I floor it when it's doing this nothing happens. I have to stop for a sec then go, then the car goes back to kinda normal. In genral though the car seems really dead like i'm loosing power somewhere or something. Can someone help us out cause this problem is really getting annoying. I'm going to check for codes and also check the knock sensor like the dude was saying.
Old 03-23-2007, 08:01 PM   #29
twofortyrida1388
that shit is no joke. it is damn embarrassing. after driving for a while and hit a light. you start going bog kick bog kick, flooring it almost kills it then people are going around you and the only thing you can do is take foot off gas and press clutch and rev it up to like 2500 and slowly let off it.
Old 03-23-2007, 08:19 PM   #30
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
have u checked for codes again yet?
ladiesman8527 is offline   Reply With Quote
