Old 10-08-2003, 04:59 PM   #1
niss
niss is an unknown quantity at this point
help, car vibrates between 60-65 mph
ok, for about 1 week now, my car starts to vibrate at aroud 60-65mph. I thought is was the tires, so i swapped them out yesterday. same thing. i dont believe it is the suspension since the vibrating stops after i reach 65mph. if it was the suspension, it would get worse with speed (i think). all 4 rims are in perfect shape. any idea/suggestions would be great. thanks.
niss is offline   Reply With Quote
Old 10-08-2003, 05:03 PM   #2
gotrice240sx
gotrice240sx is an unknown quantity at this point
my car does the same thing but only my steering wheel shakes, but it stops after i get up too 70mph i think i have to balance my wheels
gotrice240sx is offline   Reply With Quote
Old 10-08-2003, 06:01 PM   #3
llcs-13
llcs-13 is an unknown quantity at this point
If it is in the seat of your pants, it is warped rear rotors (too much hand brake use?)
If it is in the steering wheel, warped front rotors. Our rotors warp easy from a few heavy brakings.
This is Cue #1
llcs-13 is offline   Reply With Quote
Old 10-08-2003, 06:06 PM   #4
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
Guess it could be the alignment.
Or maybe the wheels aren't balanced. Even if the rims look in great shape, maybe a weight fell off.
Greg Fischer
[email protected]
'97 240SX SE
'98 Ford Explorer XLT
gfisch is offline   Reply With Quote
Old 10-08-2003, 06:21 PM   #5
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
search, there is a TSB on this. it can be fixed but it requires shimming the steering column IIRC...
also it could just be your alignment.
andrave is offline   Reply With Quote
Old 10-08-2003, 06:31 PM   #6
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Also, even thought it is at a high speed and would be noticed at any speed, check the tires for impact bumps, loose lug nuts, seized calipers and the things that the other guys suggested.
zero.counter is offline   Reply With Quote
Old 10-08-2003, 08:22 PM   #7
niss
if it were the front rotors, that would be during breaking only, right? my car is shaking when i am off the brakes as well as on the brakes at the speed listed above. lugs seem to be cool, tires look correct, and i just had them balanced. any other ideas? thanks again.
Old 10-08-2003, 08:30 PM   #8
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
I had that exact same thing happen with my car when I bought it. I replaced my suspension with a nice spring and shock combo and it went away. By the way, I'm selling mine if you actually decide to get a new suspension.
Flybert is offline   Reply With Quote
Old 10-09-2003, 08:32 PM   #9
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
A broken belt on a tire can do that...but you said you ruled out the tires ...so I would guess worn suspension. My ball joints are leaky and I think my TC bushing are shot also....and at certain speeds there is a good 1-2 inches of play in the steering.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 10-10-2003, 09:42 AM   #10
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Well i have the vibration happen only around 2700 rpm like about 60-65 mph but after that the vibration dissappears. Its only felt through the gas pedal and is very irritating and i think the solution to it is worn ground wires need to be replaced. Also it makes this buzzing sound from behind my dash somewhere, it sounds electrical. Or can it be the motor mounts?
SilviaSR20DET is offline   Reply With Quote
Old 10-10-2003, 10:32 AM   #11
andrave
andrave's Avatar
sound from behind the dash is probably just trim pieces or assorted dash bits rattling against each other because of vibration from either the road or the engine.
gotta remember how old the chassis is that you are working with. I'd say first off take your car in to be checked out and aligned. If any of your stuff is blown, replace it first (tc rods, bent control arms, tie rods, tie rod ends, shocks, etc) and then get it aligned. If the problem persists than pursue the TSBs solution of steering column shims.
And if the interior continues to rattle then take the dash apart, figure out where it is rattling, and tighten it up with some sound deadening material or something.
or just quit whining and deal with it!
