Old 08-14-2006, 10:47 PM   #1
baka_na_kuruma
baka_na_kuruma's Avatar
baka_na_kuruma is on the path to ruinbaka_na_kuruma is on the path to ruin
s14 Squeek, squeek
Hi guys,
I was driving yesterday; a piece of blue washer broke in half and fell from the clutch area (after depressing clutch). Ever since then, my clutch makes a squeeking noise upon depressing the clutch . It's starting to get on my nerves . Can anybody help me identyfy the part that broke off (small baby blue washer the size of the letter "O" on the keyboard). Or a sulution to the problem. Thanks, Mario
baka_na_kuruma is offline   Reply With Quote
Old 08-15-2006, 11:44 AM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Are you talking about the clutch pedal area? Dunno what it could be but I've stopped by clutch pedal from squeaking before by cleaning the gunk the builds up and spraying the spring with WD40.
Old 08-15-2006, 11:44 AM   #3
aznpoopy
aznpoopy's Avatar
here ya go. try a search next time.
http://www.zilvia.net/f/showpost.php...56&postcount=8
Originally Posted by idlafie
Sqeaky clutch is due to busted plastic clutch pedal bushing, Part #DAT4653435F10, list price as of 09/2000 - $7.25. This little plastic bushing goes between the metal clutch pedal arm and the clutch pedal return spring. When the plastic bushing breaks, the clutch pedal return spring starts to squeak against the metal clutch pedal arm EVERY time you press & release the clutch pedal. Gets to be annoying really fast.
Replacing that stupid little bushing is a bitch as you have to disconnect the clutch pedal arm from the master clutch cylinder push rod. Once you disconnect the clutch pedal arm from the push rod, then you have to crawl underneath your dash & somehow pop the clutch return spring loose from the clutch pedal arm. One you do that, then you place that stupid plastic U-shaped clutch pedal bushing in the spot where you pulled the clutch return spring from. Then all you have to do is put the clutch return spring back on WITHOUT letting the plastic clutch pedal bushing from falling off. Major pain in the ass.
Don't ask me how I know all this...
ID
'95 SE with replaced clutch pedal bushing
aznpoopy is offline   Reply With Quote
Old 08-15-2006, 12:08 PM   #4
kandyflip445
kandyflip445's Avatar
Cool!^ I always just thought it was normal cause the car was so damn old.
My 240 vBgarage
Old 08-15-2006, 02:03 PM   #5
baka_na_kuruma
Manonegra,
I used WD-40. It helped but squeek retuned after a few depression.
Aznpoopy,
Thanks for the information. It's exactly what I was looking for....I hope. I will do my best to utilize the search button next time.
Thanks for the help, Mario
Old 08-15-2006, 07:08 PM   #6
coreansurfer
coreansurfer's Avatar
coreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfection
ah, so thats whats wrong with my clutch
Originally Posted by avs0730 View Post
if I stupid why is people pm about the car
coreansurfer is offline   Reply With Quote
Old 08-15-2006, 07:50 PM   #7
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
interesting info. I was going to spray it down w/ some wd but I'll have to see if I still have the bushing in there.
shayrgob240 is offline   Reply With Quote
