Old 02-05-2003, 06:08 PM   #1
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Clutch opinions?
Hey. I'm looking for a clutch to handle 350-400rwhp, that will live thru drag launches, and not suck to shift every day.
Any suggestions?
I'm kinda looking at this:
Ebay Clutch
but it doesn't have a torque rating... just an obnoxiously high hp rating. It also claims to be a light pedal.
So.. opinions and suggestions!
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 02-05-2003, 06:12 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
I'm using a SPEC Stage III and it's extremely streetable. Lighter pedal than I used to have (don't know what clutch was in there before... but it was either a stock clutch or a really worn ACT Street). Supposedly it holds somewhere in the neighborhood of 350ft/lbs of torque.
AceInHole is offline   Reply With Quote
Old 02-05-2003, 06:36 PM   #3
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Puck vs. Disk? Sprung hub vs. unsprung? Spec III holds 347 ft/lbs torque. What happens above that? Slippage?
-Jeff
Whatup?
Old 02-05-2003, 06:42 PM   #4
adey
adey's Avatar
adey is an unknown quantity at this point
If you don't mind me semi-hijacking your thread, I'm also in the market for a new clutch... although not a drag clutch.
I plan to do mostly road racing events on this clutch, as well as some drifting, but no drag racing. This is not a daily driver, so heaviness/pedal feel isn't quite so important, but I figure this won't even come into play seeing as I have stock everything.
Specifically, I've been recommended the SPEC Stage II, but other than that I'm at a loss as to what a "good" clutch is and what a "bad" clutch is. What are most of you with stock HP (... no more than 200 crank) running, and how do you like it?
Also, how much should I expect to pay to have a clutch installed?
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 02-05-2003, 08:29 PM   #5
kandyflip445
kandyflip445's Avatar
It says on the Enjuku site that the stage 3 holds 469 ft/lbs of torque. Is this wrong or what?
Old 02-05-2003, 08:44 PM   #6
AceInHole
Autox Technician
AceInHole's Avatar
You're looking at the SR version.
Old 02-05-2003, 08:46 PM   #7
AceInHole
Autox Technician
AceInHole's Avatar
-Jeff
info here
SPEC (Star Performance Engineered Clutches) Stage 3 Clutch Kit for Nissan 240SX 91-98. This is a great alternative to the similar ACT HD clutch. SPEC increases the clamping force of the pressure plate and uses a Carbon friction surface on the disc hold more power, yet maintain the same street manners as a full faced organic disc. This clutch kit is designed to hold up to 347 ft/lbs or torque! This is a complete kit including throw out bearing and clutch alignment tool.
Old 02-05-2003, 08:59 PM   #8
kandyflip445
Oops.... I for got he had a KA-T....my bad.
Old 02-06-2003, 06:43 AM   #9
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
I have the SPEC stage II and wish I would have gone with a stiffer pressure plate. I had a NISMO (I think?) sprung 3 puck and it was one hell of a heavy pedal but I loved the feel
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 02-06-2003, 08:06 AM   #10
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Why do you say that?
Does your clutch slip? Or you just like having a heavier pedal feel?
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 02-06-2003, 09:41 AM   #11
nrcooled
nrcooled's Avatar
I just liked the heavier pedal feel. I felt more responsive and predictable. The feel now is just Ho-Hum. Clutch in, select gear, clutch out....boring. I liked the chatter and the instant grab. (I never thought I would say that)
Old 02-06-2003, 09:46 AM   #12
Foxcolt
Foxcolt's Avatar
interesting, I would have liked to try out your car before you changed clutches.
Sometime in the future I"m gonna go twin plate OS giken I wonder how that's gonna feel
Driftec
Old 02-06-2003, 09:49 AM   #13
nrcooled
nrcooled's Avatar
Probally like Chit .....And you will love it. It's almost Awe inspiring. That immediate grab and go. I can barely chirp 3rd now but before I could break it loose in 3rd. Clutches make a huge difference in performance and use of power
