Old 12-04-2005, 03:50 PM   #1
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
correct brake set-up facts
i've been thinking about it for a while now and i was wondering, since so many people seem confused about what setup works. i was wondering if persons with the knowledge of what brake components go together from the factory sizes and/or part numbers. like what combination brakes, master cylinder, booster come equiped together from nissan.
for myself i want to know which master cylinder and booster went on silvia K's S14s and 200sx S14s with touring packages in Europe. since they came with the four piston calipers in the front (not sure if they were 26mm or 30mm), and the same rear brakes as we have stock.
I'm not interested in opinions based on peoples individual setups, only the facts.
sncs14 is offline   Reply With Quote
Old 12-04-2005, 03:54 PM   #2
OptionZero
OptionZero's Avatar
search for brake threads by sykikchimp.
Old 12-04-2005, 04:12 PM   #3
sncs14
sncs14's Avatar
bingo
thanks optionzero. so many people ask brake questions it was hard to look for it in the search.
for anyone else interested
http://www.zilvia.net/f/showthread.p...ghlight=brakes
Old 12-04-2005, 04:13 PM   #4
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
all info you'd ever need
http://importnut.net/300zxbrakeswap.htm
if you want more .... do click that odd looking button some people call search
Al_S14 is offline   Reply With Quote
Old 12-05-2005, 07:47 AM   #5
sncs14
sncs14's Avatar
Oh the irony. http://www.zilvia.net/f/showthread.php?t=96032
Old 12-05-2005, 08:18 AM   #6
docrice
docrice's Avatar
docrice is an unknown quantity at this point
Send a message via AIM to docrice
Just FYI, if you want to do a Silvia/200sx master cylinder, you're gonna have to bend the lines around quite a bit since they come off the other side of the MC (RHD, ya know?). Of course for non-abs s14's you already have to bend the shit out of the lines to line up with the 300zx MC...the only problem I can forsee is not having long enough lines to get around to the other side of the RHD MC. Have to look into that one, but I think you'd be alright. Whether or not it's worthwhile to spend all that money on that MC when you can get a 300zx one that works pretty well? Couldn't tell ya. It would be nice to find proportioning specs for both though...
I can tell you that I'm running a 300zx MC on a full front/rear Z brake setup and it feels phenomenal, and I haven't heard any complaints from those running fronts only and the Z32 MC...
docrice is offline   Reply With Quote
Old 12-05-2005, 11:20 AM   #7
HyperTek
asad on Freshalloy did a great write up on brake setup for the 240sx, really great, but its a time killer on reading =(
Keep it Classy
Old 12-05-2005, 12:47 PM   #8
sncs14
sncs14's Avatar
docrice, i have the iron 30mm z brakes up front with stock kouki s14 brakes in the rear and the nabco 17/16 bmc. i had the stock 7/8 mc for close to two years before i swapped it for the 17/16 half a year ago(yes, bending the hard lines was a PITA). it is a great improvement, but i wanted to run the setup the way it was supposed to be ie correct mc, and booster for non-ABS kouki S14. then decide which feels better. it is my understanding that some of the European 200sx were left hand drive, so there should be a correct bmc somewhere. i just need to figure out exactly what the part # is.
hypertek, i'm going to look into the FA writeup if i can find it. thanks
Old 12-05-2005, 12:57 PM   #9
docrice
docrice's Avatar
If you go to the technical section of Zilvia, there is a FSM for SR-equipped S14's (Silvia/200sx). I haven't looked at it in a long time, but it may have some information in there for ya... I totally understand your interest in pursuing this. Still want to find a master list of the different MC's and their biases...
Old 12-05-2005, 01:43 PM   #10
sncs14
sncs14's Avatar
holy shit i can't believe i didn't think of that. i have the us and european FSMs in PDF format saved i'll look right now
Old 12-05-2005, 01:53 PM   #11
docrice
docrice's Avatar
Yeah give it a try and let us know how it turns out...I'm sure it's information that others would be interested in.
Old 12-05-2005, 02:34 PM   #12
sncs14
sncs14's Avatar
ok
US specs:
bore diameters: M/T 7/8, A/T15/16
split point: same for both M/T & A/T models= 427psi X .04 reducing ratio
brake booster model/size: M/T M23/9.08in., A/T M195T/primary 8.07
in.,secondary 7.09in.
SR20DET specs(s14 Silvia & 200sx EU,AUS):
bore diameters: w/out ABS 15/16, w/ ABS 1"
split point: same for w/out ABS & w/ABS=569 psi X.04 reducing ratio
brake booster model/size: w/out ABS M23 or G23/ 9.06in., w/ ABS M195T/primary 8.07in., secondary 7.09in.
in summary i guess i would need the 15/16" bmc with the split point of 569psi X .04, and either the M23 ,G23, or M195T boosters. now i just need that part number for that LHD bmc.
Edit: from skikichimp's thread "'86 Z31 Non-turbo MC part number is: 46010-04P00". can anyone verify that that's the bmc i'm looking for?
Old 12-05-2005, 05:33 PM   #13
Al_S14
Al_S14's Avatar
lmao yeah i pissed of a good bit of peop[le that day
Old 12-06-2005, 06:08 AM   #14
docrice
docrice's Avatar
did you find the specs on the z32 MC by chance? I only ask because the split point and proportioning numbers (for the SR20 S14 chassis) sound similar...
Old 12-06-2005, 08:56 AM   #15
sncs14
sncs14's Avatar
according to AKADRIVER,"2.94 kPa = 498 psi. This is the Z32 split point"
not sure which size mc he was talking about though
Old 12-06-2005, 11:16 AM   #16
docrice
docrice's Avatar
ok, wasn't sure...i'm gonna try and find some specific details one of these days just for kicks...
Old 12-13-2005, 08:54 AM   #17
sncs14
sncs14's Avatar
found z32 info:
bore diameters: w/out ABS 15/16, w/ ABS 17/16
split point: same for w/out ABS & w/ABS=498 psi X.04 reducing ratio
brake booster model/size: M215T primary 9.06in., secondary 8.07in.
