Old 01-15-2003, 08:01 AM   #1
DSC
New Title
DSC is an unknown quantity at this point
Camber, Caster, and toe...getting alignment to custom specs
I'm taking my car to get aligned in a couple weeks and was wondering what specs you all run? What is the max negative camber you can run on a stock setup? Can anybody recommend a good setup for camber, caster and toe front and rear?
Should the alignment be done with a 140lb (my aprox weight) weight in the drivers seat or should it be done with no weights?
Any info or tips you all have on this would be greatly appricated
DSC is offline   Reply With Quote
