![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
![]() Hey I got a 97 240 and i wanted to know if anyone on here has the ground control coil overs and what shocks youre using. Is this a good kit or should i just buy springs like the eibach sportlines? Ill propably go with tokico struts. How low can you go with the ground controls and how do they ride compared to springs??
![]() Join Date: Aug 2003
say nooooooo to drop zone.
weak and bouncy shiet. someone will eventually tell you to use the red search button on this board. use the search to find out more about ground control kits and etc,. good luck |
from Canada, eh!
![]() Join Date: Sep 2001
I have Ground Control with custom springs: (425lbs /_375lbs 8" instead of 7" spring) and I love them... Very comfy with KYB AGX...
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#7 |
from Canada, eh!
I don't know. I haven't tried and I'm not into low-riding.
#8 | |
on strike three.
![]() Join Date: Mar 2003
#9 |
from Canada, eh!
The thing with Ground controls that make them "better" than other sleeved coilovers is that when you buy them from Ground-Control, you choose your spring rate.
#10 |
Most people shouldn't really have that much control over things like that. When a lot of people that I've spoken to about cars see "coilovers" they think "hey, i can make my car REAL low without paying a lot of money for things like airbags or hydraulics, but it's better than just cutting my springs".
I suspect that mike's concern is more with lowering his stance than cornerweighting and things like that. |
#12 |
i just got my ground controls with recommended spring rates and koni yellows which ill be installing this weekend (saturday) ill let you know how it feels when im done. =)
#13 |
from Canada, eh!
REcommended spring rate is garbage for rear: 250lbs
and the worst part of the rear springs is that they are too short. the highest setting makes it look like a 1.5" drop... which is a lot on the rear. 1" in enough to me in the rear. I did not disable the hicas and I don't see why I should. I like it and i'm not into drifting.
#14 |
eyescream youre right i just wanna lower stance(for looks not autocrossing) so instead of spending $230 on springs i was thinking about the coil overs since their only a couple hundred more and i could set them exactly how low i want it...(not 3in by the way) I wanted to find out if it was gonna ride like a tank with them or not
#15 |
from Canada, eh!
For street, the recommended setup is ok...
as for camber issues, I'm not dealing with it, for the moment. I don't mind having a bit of negative camber..
#16 |
well they asked if i wanted a specific spring rate but i didnt know what i needed so i just got recommended. yea i love my hicas but i think im gonna have to disable it cause im trying to get into the drift scene.
#17 |
I *highly* recommend you get new shocks if you get coilovers, mike.
Out of curiousity, rps13sh, what rates front and rear did ground control recommend for what you were gonna do with the car? I can't decide what a good spring rate would be, and I'm not sure i'm happy with my suspension techniques and want something stiffer. |
#18 |
from Canada, eh!
Ground Control offers 425/250 lbs springs, which, imo, is too soft for the rear. Also, their rear spring is too short and it takes out the 'adjustment' feature Ground Control offers. I suggest you get a 8" long, 2.5" diameter 350 or 375 lbs spring for the rear. The car is more neutral that way.
#19 |
![]() Join Date: Aug 2002
ground controls are decent coilovers.
if all you want to do is drop your ride, just get springs and shocks. but for the price, you might as well splurge and pay a few hundred dollars and get some coilovers. well, that's my opinion. coilovers offer stiffer rates and adjustability. most spring kits are just lower and dont offer as stiff rates. i would go with coilovers if you plan to go tracking. they are adjustable which is a plus.
#20 |
tein S.Tech!!!!!!
delicious!! ![]() i love them ![]() nice and stiff!! ![]() well i like them...they feel real good not bouncy i can definately feel a difference in cornering...less Gs...feels like it to me anyway...but i also have nismo bushings(hard) so that may also contribute to the nice ride
lemme have a dollar |
#27 |
from Canada, eh!
My Ground Controls with AGX are very good... Better than a shock+spring setup..
#28 | |
hey, just curious, how did you come up with those figures when you ordered your springs? I've got my set-up coming along and I'm placing well in auto-x, I'd just like to be a little more scientific about picking parts.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
#29 |
![]() Join Date: Nov 2001
If you want you can use mass/damper frequencies to figure out what springs you should run. This: http://www.240sx.org/links/installs/...efinition.html
and the spring selection page (next one) will tell you everything you need to do. I have made up a spreadsheet on excell that has all the spring rates I can find and their equivilent ride frequency. Most of the aftermarket stuff is close to 2hz. The Tein HA's are 2.13f/2.02r and the pro-kits are about (cause they are progressive) 1.53f/1.40r. Having a little lower frequency in the rear helps with traction a little bit. If you are running an aftermarket bar in the back, then you are already probably having problems with rear wheel traction out of the corners. so if you raise the rear spring stiffness, that reduces the effectivness of the rear bar and gives you more traction. It's all a balance point, but for the 240, I would stick really close to 2hz for performance street and closer to 2.5hz for racing. Oh yeah, stock is 1.23f/1.28r All these were calculated useing 728lbs/corner on the front and 672lbs/corner on the rear. email me at nord0306 at umn.edu if you want a copy of the spreadsheet
Adam '89 coupe KA24DE+T 14.1 @ 104 MPH '88 Celica All-Trac turbo stock, but no more ecu codes!! |
