Old 12-19-2001, 09:40 AM   #1
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
just to let u know, they came in (these are S14 guages). &nbsp;I'll take pics and install soon <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=':D'>
AceInHole is offline   Reply With Quote
Old 12-19-2001, 10:03 AM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
#Moderation Mode
<a href="http://www.zilvia.net/forums/cgi-bin/topic.cgi?forum=1&topic=1604" target="_self">Moved here</a>
S13Grl is offline   Reply With Quote
Old 12-19-2001, 11:50 AM   #3
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S13Grl on 10<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>3 am on Dec. 19, 2001
#Moderation Mode
&lt;a href=&quot;http://www.zilvia.net/forums/cgi-bin/topic.cgi?forum=1&amp;topic=1604&quot; target=&quot;_self&quot;&gt;Moved here&lt;/a&gt;
</td></tr></table><span id='postcolor'>
cool.... figured since it was leading to a write up on an install it should go in the tech forum tho. &nbsp;uploading pics now. &nbsp;they came out pretty nice.
Old 12-19-2001, 11:51 AM   #4
S13Grl
Married to the Mob
S13Grl's Avatar
if you'd like, i'll transfer it back there
Old 12-19-2001, 12:15 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
my sister was supposed to give me her hi res camera since her boyfriend had a better one than she did... she's since broken up with him and won't give me hers. &nbsp;mine sucks, but here's what they sent me:
and the finished product:
the install wasn't bad. &nbsp;there were some clearance issues like with the EL connectors:
You can also see I lost one of the screws (although I'm decent enough at taking the dash apart so if I ever find it I can screw it in <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'> &nbsp;)
anyways, the wiring was easy, I just spliced it into the dimmer switch, which was the closest power/ground anyways:
red/blue is positive
black is obviously negative
niftiest part is I didn't have to remove the needles. &nbsp;just slide the gauges onto the odo reset and time adjustment poles, rotated the needle so I could get it to slide into the gauge, and slid the gauges in.
notched the case to run the indiglo wiring so I wouldn't have to remove my bulbs and run the wires through that hole.
the instructions were pretty crappy. No pictures, and they're pretty vague (they generalize so they can ship it with every set they sell, non-car specific.) &nbsp;I glanced at it, and laughed at the part where it said : &quot;If your gauges are backlit only, you may want to leave your bulbs intact (I actually did this too), this will illuminate your needles, and looks cool at night with the indiglo faces lit.&quot; &nbsp;The instructions also suggested to wire the power from the parking lights.... oh well, so much for trusting instructions written in Comic Sans...
The gauges look pretty nice. &nbsp;They aren't as bright as I thought they'd be, but it isn't dark out so it's not like I can tell that yet. &nbsp;When it's dark out I'll get a lit shot.
My only complaint is that I can hear them whining or whirring or something... it's no big deal, as soon as the car is started it's completely undetectable. &nbsp;I'll have to see if I wired something wrong (which I doubt) or if it goes away. &nbsp;It might just be power draw off the dimmer switch.... so maybe I should try hooking it up to a more solid power source....
Old 12-19-2001, 01:08 PM   #6
yenpit
yenpit is an unknown quantity at this point
who makes em??
yenpit is offline   Reply With Quote
Old 12-19-2001, 02:05 PM   #7
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
what color are the needles
whateverjames is offline   Reply With Quote
Old 12-19-2001, 02:41 PM   #8
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from whateverjames on 2<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>5 pm on Dec. 19, 2001
what color are the needles</td></tr></table><span id='postcolor'>
I got the gauges from <a href="http://www.indiglogauges.com
The" target="_blank">http://www.indiglogauges.com
The</a> needles are stock, and they light red. &nbsp;I replaced all the dash bulbs with red wedge bulbs, so they're a much deeper red.
Finally got some lit pics:
guages on lowest setting
gauges on highest setting
Old 12-19-2001, 02:43 PM   #9
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S13Grl on 11:51 am on Dec. 19, 2001
baah... it's ok!!! &nbsp;I was just apologizing for thinking it should go in the tech forum. &nbsp;I guess it's more of a chat thing since it's not a performance mod??? &nbsp;I dunno. &nbsp;Place it at your discretion <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
Old 12-19-2001, 03:54 PM   #10
yenpit
thanks ace! looks great <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 02-14-2003, 07:15 AM   #11
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
I have those exact same indiglo gauges in my 240. I got mine off of E-Bay for about $35. I haven't seen any on there for a while. But just letting you know . Sliding the guages over the needles WERE NOT fun at all. However, they look extremelt good and I'm glad that I did it.
240silvia is offline   Reply With Quote
Old 02-14-2003, 08:00 AM   #12
SimpleS14
SimpleS14's Avatar
ddaayyyuumm why did you bring this thread back from the dead?
BTW....I have the reverse guages that look much better for only $20 SHIPPED. I actually have the ones you have, but they are just laying around. It's for sale to anyone that wants them.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 04-26-2003, 11:55 AM   #13
ALTRNTV
to the person who installed the gauges... did the gauges come with a red wire and a ground wire, because i dont know where to connect the red wire to, and theres like a million wires in there i can connect it to, which one do i hook it up to?
ALTRNTV is offline   Reply With Quote
Old 04-26-2003, 07:39 PM   #14
SimpleS14
SimpleS14's Avatar
Those gauge come with a red and black wire (ground)....but see.....his car is a S14 and so is mine. We just connected the two wires to the dimmer switch. But I have no idea how to work on a S13...sorry.
BTW.......anyone with a 95/96......I HAVE THOSE GAUGES FOR SALE......CHEAP!!!!
L.H.O.O.Q.
Old 04-26-2003, 07:40 PM   #15
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
:cough cough: ricers :cough cough:
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 04-26-2003, 08:42 PM   #16
mrmephistopheles
mrmephistopheles's Avatar
So you revived a 1.5 year old thread to say "I did that too!"?
WHAT... THE.... ****....
Old 04-26-2003, 08:44 PM   #17
mrmephistopheles
AND YOU REVIVED IT AGAIN!!!
WTF?!! Could you not just hit the SEND PM button?
*megamoderatorbitchslap*
