Old 09-09-2005, 07:16 PM   #1
Nismo180
Nismo180's Avatar
Nismo180 is a well-known jackass
GT2871R fitment
Anyone have a GT2871R on a Stock replacement manifold? I'm trying to find out if it'll fit any manifold or if there is some contact on some of them. I know WRCmilla's GT30something turbo would only work if the #1 runner was bent up a little so the Silkroad style ones would work, but not the SSautocrap one. Anyone know if the GT2871R would fit on say the DCsport mani?
Nismo180 is offline   Reply With Quote
Old 09-09-2005, 07:29 PM   #2
eyustfu
eyustfu is an unknown quantity at this point
the turbo will fine on the stock mani, many people have theirs set up this way.. the DC sport one should clear too
eyustfu is offline   Reply With Quote
Old 09-09-2005, 08:04 PM   #3
Nismo180
Nismo180's Avatar
Fantastique! Much appreciated.
Old 09-21-2005, 08:29 PM   #4
Rich Druash
Rich Druash is an unknown quantity at this point
I have a Gt2871R on a jgy customs equal length stock replacement. I had to modify the wastegate actuator to make it fit. I flange and downpipe both fit up, but when you clock the turbo to the right position the wastegate actuator will be right in the way of the turbo outlet that goes to the hot pipe. I fliped the plate backwards, drilled to new holes, and extended the arm(since the plate is offset and when you flip it backwards it won't reach) It's funny because every company said it was a perfect fit, Finally one of the Techs at Heavy Throttle told me they had the wastgate actuator had to be modified, I was about to loose my mind after spending $1200. I might be able to send you some pictures if you want.
Rich Druash is offline   Reply With Quote
Old 09-21-2005, 09:58 PM   #5
Wahl 36
Wahl 36 is an unknown quantity at this point
I went through the samething!
Yes I'm new, but that doesn't mean I'm a newbie
Wahl 36 is offline   Reply With Quote
Old 09-22-2005, 12:03 AM   #6
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
yea definitely post pics of the modified bracket... It help mucho when i do mine eventually... thanks
Life is good in the bay.
Eternal_240Sx is offline   Reply With Quote
Old 09-22-2005, 12:44 AM   #7
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
T25, T3, and T28s are the same flange, IIRC!
SochBAT is offline   Reply With Quote
Old 09-22-2005, 12:47 AM   #8
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
I would like to see said pictures of modificated turbo
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 09-24-2005, 04:17 AM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I did the same thing. Im running the MR manifold. I had to clock the turbo roughly to the same spot as a stock T25 and running stock lines. the actuator was fun cuz it was like a lego project. Like said above, if you re-clocked the turbo *which you will have to* the actuator will be right on the way of the turbo outlet. So i had to flip the bracket and re drill some holes on it to remount the actuator on it. Downside now is that the part that opens the turbo valve at the other side of the actuator will be short cuz of the off-setted bracket. Upside...you can extend it to reach. took me a bit to figure out wut to do, i was gonna make my own damn bracket but then i got lazy.
Then i had one of the J rubber intercooler connectors off a skyline intercooler and just used that to hook up to my hot pipe. I should wrap it or something cuz i know thats a melting incident waiting to happen. Ill take some pix sometime and post it up so people will have an idea.
CLICK HERE!!!
Old 09-24-2005, 10:44 AM   #10
Mike Wazowski
Mike Wazowski has a little shameless behavior in the past
The GT2871R fits very well with the Full-Race stock mount.
Mike Wazowski is offline   Reply With Quote
Old 09-25-2005, 07:20 PM   #11
fliprayzin240sx
I took some pix and now remembered wut i did, since i flipped the bracket, the actuator is actually gonna be too short to reach. So i got longer studs for the bracket and used washers as spacers.
CLICK HERE!!!
Old 09-25-2005, 07:49 PM   #12
veilside180sx
veilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to allveilside180sx is a name known to all
T2 based exhaust housings are T25/T28
T3 is a different footprint(flange)
veilside180sx is offline   Reply With Quote
Old 09-26-2005, 09:33 PM   #13
powerls
powerls is an unknown quantity at this point
how about some pics of the intake for a T2 flanged 2871? I know it will require a custom set up, but I would like to everyone else setup. Also, anyone know of a company that makes a drop in intake for this setup?
powerls is offline   Reply With Quote
Old 09-30-2005, 08:44 PM   #14
massscene
massscene's Avatar
massscene is an unknown quantity at this point
you know from first hand experiance???? this is the setup I am tryin to get. please let me know what you know? power, fitment, problems, praise?
Black S14 Base Model Converted to SE w/ extra goodies.
massscene is offline   Reply With Quote
Old 09-30-2005, 08:55 PM   #15
b00st2R
b00st2R is an unknown quantity at this point
will the actuator need to be modified if using a stock manifold?
b00st2R is offline   Reply With Quote
Old 10-01-2005, 10:45 AM   #16
Wahl 36
If you clock the exhaust and intake side you shouldnt have to mess with the actuator. mine went about 30 degrees counter clock wise and the exhaust side clears, and the intake side ends up facing down toward the motor mount but it clears up the clearance issue.
