![]() So I got new 17's and maxed out my KTS's. My only concern is that i'm going to rub through the wiring harness and already started to. I found the "how to re-route harness" but it mentioned that "S13 guys are lucky that they can tuck the harness up into the fender and pull a piece of sheet metal over to protect it". i was wondering if anyone had any pics of the S13 harness tucked, i worked on mine tonight but its just worst than before.
![]() Join Date: Feb 2004
easiest thing ever - they say it's a quick fix, but i haven't had any problems or needed to replace the zipties forever...knock on wood.
http://www.sillbeer.com/fenderharness.php |
I snap, i had the wrong idea in my head. gonna start bright and early tomorrow. Thanks guys.
P.S. any suggestions for that "ridge" of metal that hangs down over the middle of the fender? |
![]() Join Date: Jan 2004
Which way is the best way to bend that "ridge"? Inward our Outward? Also there is another seam directly behind the wheel (towards the back of the car) my tires seem to rub there too. Which direction do you bend that funker?
![]() Join Date: Nov 2004
Just bang your fender wells like it's a $5 ho.
Push the harness over the seam and ziptie. Or be a pimp and relocate it to the engine bay. I'm sure there are threads already covering this. With more information that just stating that it's easy.
#10 | |
![]() Join Date: Apr 2006
I had to relocate to the engine bay, after repairing half of hte harness, after doing the above method on the site. Just do it right hte first time, and relocate to engine bay. takes like an hour.
2015 Subaru Outback Overlander - Wagonofdoom |
#11 | |
I was only stating that relocating it to the fender for s13's because if done right, it won't hit your wheel. If you can't do it right, or have the time then sure relocate the harness.
#12 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
![]() Join Date: Aug 2005
that link made it look hard. i did mine without even having to remove the fender. Just used vice grips to bend that lip then tuck up the harness and bend it back. took like 10-20 mins
#15 |
Im telling you from experience no less than a month ago
put it in the engine bay, or you will be doing it again
#16 | |
#19 |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
I tucked mine like SANDWICHED in between the fender and the chassis, with a tight ziptie, that sumbitch isn't going anywhere.
![]() Best way to do business with me? Make your best offer FIRST. |
#21 |
its not a matter of it going anywhere
When you are lower, and take a hard turn, it goes up into the fender well and rubs the harness. no matter how high you have it I am so low, even after heating and banging in the very top, im still making it silver (IE rubbing liek a mother fucker) your preventing damage from your tire to the harness How to do it, removed the lower steering column panels, unplug everythign to the big ass white plug. Pull through the firewall, and then reroute. over the fender in the engine bay. Separate into two bundles and electrical tape it so it will be flatter.
#23 |
yeah let me go get one for ya.
#24 |
here ya go
looking at the fender innards from the outside ![]() from the back left of hte engine bay (looking at the car) ![]() adn in the engine bay ![]()
#26 |
Man w/ CTSV & a Car Seat
You basically go under the dash board and find all the plugs for that harness and disconnect them. You pop them out to the wheel well and route the whole thing on top of the strut tower. Only thing is you have to make sure your hood wont be smashing on to the wiring. Most people will unwrap the wiring and kinda flatten them and then rewrap them flat with electrical tape.
#29 |
![]() Join Date: Apr 2004
He has nothing on me
![]() The difficult part is getting the SMJ box to go through the triangular section. You have to cut it with tin snips or a dremel. I hate the SMJ box so I will completely eliminate the box the next time I rewire the car. |
