Old 04-29-2006, 09:15 PM   #1
Sliding Ninja
Sliding Ninja's Avatar
Sliding Ninja has a little shameless behavior in the past
Smile how do i adjust the valves in my motor
i need to know
Sliding Ninja is offline   Reply With Quote
Old 04-29-2006, 10:05 PM   #2
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
what motor>?
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 04-29-2006, 10:13 PM   #3
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Diddo!!!!!!!
NIK90s13 is offline   Reply With Quote
Old 04-30-2006, 05:52 PM   #4
dopeassjackson
dopeassjackson is a well-known jackass
well if its in a 240sx you probaly have hydrolic lifter that dont need adjust ment.
dopeassjackson is offline   Reply With Quote
Old 04-30-2006, 06:31 PM   #5
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
yep ka and sr have hydraulic lifters, There is no adjustment, if you have done head work you may need to bleed the lifters.
g2ic02 is offline   Reply With Quote
Old 04-30-2006, 07:54 PM   #6
kandyflip445
kandyflip445's Avatar
What? KA's have shims.....
My 240 vBgarage
Old 04-30-2006, 08:56 PM   #7
infinitexsound
the shims sits on the bottom on the valve spring.... ur best bet is just lashing it under the cam with a feeler gauge and re torque it... to oem specs.
Old 05-01-2006, 03:59 PM   #8
93 240sxfastback
93 240sxfastback is an unknown quantity at this point
You can't adjust them. If you wanna change the duration they open for just change your cams.
93 240sxfastback is offline   Reply With Quote
Old 05-01-2006, 09:23 PM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
Word! Nuff said.. but make sure you get a torque wrench that goes down low enough to torque them properly.
Old 05-02-2006, 09:41 PM   #10
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
How hard/easy is this to do?
Neejay is offline   Reply With Quote
Old 05-03-2006, 01:37 AM   #11
NemeGuero
No more nissan.
NemeGuero's Avatar
Can you use a torque wrench?
Old 05-03-2006, 09:28 AM   #12
Neejay
Neejay's Avatar
Well yeah, but Im talking about the process...I've seen it done on my civic when I had it a looong time ago, but not totally sure...
Old 02-15-2007, 02:35 PM   #13
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
WTF are guys talking about??!?!? There are things called "lifters" or "bucket tappets" that fit over the valve spring. Then on top of them there are shims. These shims ARE replaceable and that is how you cahnge the clearance between the cam and the spring!
shayrgob240 is offline   Reply With Quote
