Old 12-04-2007, 04:42 PM   #1
SOCAL240
SOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura about
trouble shootin video of SR ignitor
okay so i felt i was getting a bad connection from the ignitor so i took the tape apart and found that the wires pretty f'd up both wires were soldered
idk if thats how u say it but yea so i took clipped it off and put it back together i thought that would fix the problem but the funny thing is that
THE ENGINE SHAKES AND MY SHIFT KNOB WOBBLES AND MY CAR SOUNDS LIKE A SUBI BUT when i play around with the ignitor ( i move it around) the annoying sound stops and the engine / shift knob stop shaking
i drive the car around and it feels like it runs like shit
any input on this greatly appreciated
heres the video ( you may not see the engine shaking but it was and if you play close attention theres a moment where i play around with the ignitor and it stops sounding like a subi)
heres the vid.
[ame]http://www.youtube.com/watch?v=oIhXwGcuutk[/ame]
sorry i will try to get the video pasted onto here it just hasnt finished loading thanks guys
SOCAL240 is offline   Reply With Quote
Old 12-04-2007, 04:47 PM   #2
smelly240
smelly240's Avatar
ur igniter wiring is probably crappy
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 12-04-2007, 04:54 PM   #3
SOCAL240
how can i get that fixed??
is there anywhere where i buy the wiring or can i just take it to a shop and have them do it for me?
thanks
Old 12-05-2007, 06:10 PM   #4
smelly240
smelly240's Avatar
just check continuity for the igniter to ecu and igniter to the coil packs... while moving it around... also double check the grounding on the coil pack harness
Old 12-05-2007, 07:43 PM   #5
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
just find where the conection is bad and solder it.... you have an sr. Time to become mechanically inclined.
jskateborders is offline   Reply With Quote
Old 12-05-2007, 08:44 PM   #6
SOCAL240
Thumbs up
turns out my wires are fine and i may have a bad igniter not sure though
how would i know if i have a bad ignitor??
in the mornings around 8am when i head out to school the car runs better but once ive been running the car it starts to run like shit again
may this be because of a faulty ignitor?
thanks
Old 12-15-2007, 01:27 AM   #7
thedecapitator
thedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choices
^^ bump i have this same prob.
thedecapitator is offline   Reply With Quote
Old 12-15-2007, 02:47 AM   #8
cotbu
cotbu's Avatar
clearly the wiring, the igniter has no moving parts. bolt it down, check ecu for codes then redo wiring. the ground can be run directly to the chassis.
your looking for code 21 - Ignition Signal.
I have mine grounded to the chassis, and broke the ground when removing the intake manifold. It would not start at all.
Old 12-17-2007, 07:22 PM   #9
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
who did your harness? Looks terrible. go to auto parts store and buy some wire and solder. Fix that ISH!
RedtopTech is offline   Reply With Quote
