Old 10-31-2005, 10:42 PM   #1
Supreme
Supreme's Avatar
Supreme is an unknown quantity at this point
Send a message via AIM to Supreme
Cusco brake cylinder stopper
Anyone using this? Any difference made? I just did a rotor/pads/lines change on my 240sx and am not too happy. Maybe I expected more than I shouldve. Anyway I was told that this makes a notable difference, any feedback from those who have/had it?
Supreme is offline   Reply With Quote
Old 10-31-2005, 11:22 PM   #2
FRpilot
FRpilot's Avatar
what is it suppose to do anyways? besides looking pretty in blue?
FRpilot is offline   Reply With Quote
Old 11-01-2005, 12:03 AM   #3
Supreme
Supreme's Avatar
(supposedly) prevents flexing of the mbc, but I wonder myself if its all bling...
Signature Exceeds Forum Limits
Old 11-01-2005, 12:11 AM   #4
FRpilot
FRpilot's Avatar
flexing of the mbc.. from what? the forces of your foot to the pedal possibly moving the bmc.
Old 11-01-2005, 01:19 PM   #5
projectRDM
projectRDM's Avatar
You guys can't be serious. This is one of the most common, well known things about a car, period.
Have someone sit in your car and press the brake pedal firmly and watch the booster/master cylinder. The firewall will flex a little from the pressure. You can visually see it move a little forward, then retract when the pedal is released. Same as if you pressed against a quarter panel with your foot, the pedal is only mounted to hold it in place, the sheetmetal used in the bracket and the firewall are both thin enough to allow for plenty of unwanted flex.
The master cylinder stopper bolts the shock tower (where the steel is a little thicker) and has an adjustable pushrod to press against the cylinder, keeping it from moving. It works, several of the guys I autocross with have built makeshift versions. The only issue with the Cusco is it's for a RHD car, there aren't the same mounting provisions on a LHD car's shock tower for it. It's adaptable, but for the money you can make one that works just as well.
FORMERLY R240NA
Old 11-01-2005, 03:12 PM   #6
AutoRnD
AutoRnD's Avatar
AutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the rough
Send a message via AIM to AutoRnD
the only thing is...
with the flex eliminated..
beware that you may rip the pedal right off..
been there done that...
but then again i am superman =)
www.AutoRnD.com
Nardi, Enkei, Stance, AME Master Distributors for USA
Check Out Our Facebook!
AutoRnD is offline   Reply With Quote
Old 11-01-2005, 03:22 PM   #7
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
Originally Posted by R240NA
You guys can't be serious. This is one of the most common, well known things about a car, period...
+1.
I really watched it when I bled my brakes after doing my Z brakes/Z bmc swap. It definitely moves, quite a bit actually. But like Russ said, all the stoppers I've ever seen are for RHD, not LHD. It wouldn't be that hard to make one, I plan on doing it, just haven't found the time yet. Pop your hood and get someone to sit in your car and give the pedal a firm push, you'll see it.
Bryan
upSLIDEdown is offline   Reply With Quote
Old 11-02-2005, 01:21 AM   #8
Supreme
Supreme's Avatar
I was serious since I did not know (personally) how it worked, but thanks for answering my question
Is a lot of modification needed to make the rhd work on our lhd?
Old 11-02-2005, 08:42 AM   #9
projectRDM
projectRDM's Avatar
Not really. Basically you'll set it where it needs to mount, then drill the tower and use spacers behind it to set it flat against the MC. It's designed to sit flush against the tower and IIRC there's a few ridges in the same place on the other side. Your main concern is to get it as flat against the tower as possible, maybe even go as far as to cut a plate and sandwich the shock tower for more rigidity.
FORMERLY R240NA
Old 11-02-2005, 10:02 AM   #10
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
Originally Posted by FRpilot
flexing of the mbc.. from what? the forces of your foot to the pedal possibly moving the bmc. haha.
the forces of your foot are multiplied by the lever the brake pedal is attached to.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
