![]() Join Date: Feb 2005
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Master Guide For Buying Wheels!!
This thread is for people to BREAKDOWN exactly what Tire and Wheel combination they have? But this will be different than most other posts.... you'll see what I mean in a moment....
Now i've looked at many many threads on wheels, tires, rims, and suspension pictures and so on but there is not one that will have it all or what I need, for EXAMPLE... I'll see a post where someone says they have an S14 with 17" but no offset given? or 17" with offset but no tire size? or 17" with offset and tire size but no picture? or 17" with offset, tire size and picture! but not the right angle on the picture to see how flush or stretched or whatever and no suspension setup. See what I mean!! ![]() Also I started thinking that this thread can actually answer a lot of questions I never thought could be answered like you've seen these ones ..... "What coilovers are everyone using" and "Best Rucas, Tie rods, and so on to use" WELL DUH! If there are so many pages and pictures of what people are using what do you think could be the most popular to use? You could almost build stats out of it for fun? Also if you have posted in here in the past and have a new setup add on to this with your new specs! And you get to whore out some pics too. Just trying to help control new threads and PM sent questions. So here is a formula to follow to help people get the real perspective on wheels so if you could post all of this information using the numbers given or whatever you can fill in, but try to add it back in later when you have time. Good luck trying its alot!! But should help people from searching hundreds of threads that take up all your time to read through. NEW QUESTIONS ADDED. 1. S13/S14/S15 = 2. Suspension Setup/Brands = 3. Wheel/Rim Size front & back = 4. Brand of Wheel/Rim = 5. Offset front & back = 6. Spacer Size = 7. Tire Size/Brand front & back = 8. Alignment Specs = 9. Clear Zbrakes & what size brakes = 10. Fender Modifications: rolled/pulled = 11. Picture.. from the side & down the side = 12. Over Fenders Brand & mm Size = 13. Tire Pressure front & rear Track/Daily Driving = 14. Lip size front & Back = Thanks everyone! THIS could be the Master Guide? Also should be a STICKY ?? If you think about it.
Last edited by samms95s14se; 03-15-2009 at 03:28 AM.. Reason: New questions added to the list |
![]() Join Date: May 2002
sounds like a fun thread.
mods delete people who dont respond correctly no "hey what" qs. only pics to reply make me a mod and i'll rule this thread w/ an iron fist PM PEOPLE IF YOU HAVE A QUESTION add number 7, alignment!! and here's my beater..prekouki 1) s14 1995 2) too much, you only need to know Tanabe DD coilovers, -3 degrees camber 3) 17x9, 17x10 Desmond Regamaster 4) 9 +18, 10 +20 5) 215/45/17, 235/40/17 6) alignment at time pics taken: -2 camber front, -3 rear (changed now) ![]() ![]() 8) clears front and rear z32 brakes 9) rear fenders hammered about 10mm-15mm if that...fronts rolled (hammered now). setup also works perfect for 18x9.5 +12 (Work Emotion) with a 235/40/17 |
![]() Join Date: Jun 2002
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
8] clear zbrakes and what size brakes and if spacer needed
9] fender modifications: rolled/pulled how much sorry sold all my wheels savin for VS-KFs you can delete my post after you entered #8/9 in |
Wow! no one but Dousan PG has any specs and pictures! and by the way GREAT job on the info and NICE pics!!! thats how you do it. So everyone wants to continue to ask random wheel and tire fitment questions just to see people reply back SEARCH?? and go back and forth for ever????
Can we get some members who posted pics in the picture threads to help out on this? Remember you can edit back in information that you don't have right now later, just skip numbers if you have to. Ok let's try this....One More Time!!
#5 | |
it's NOT a show car!!
![]() Join Date: May 2003
![]() Daily Pimpin' ![]() 1. S13/S14/S15 = s14 2. Suspension Setup = a lot of stuff 3. Wheel/Rim Size front & back = 18/19 4. Brand of Wheel/Rim = Chrome Work VS KF 5. Offset front & back = Perfect 6. Spacer Size = None 7. Tire Size front & back = 225/40/18, 245/35/19 8. Alignment Specs = camber -2.7f, -2r, 7.5 caster, 0 toe 9. Clear Zbrakes & what size brakes = of course 10. Fender Modifications: rolled/pulled = slight roll no pull by mr. Dousan Track Shoes ![]() ![]() ![]() ![]() 1. S13/S14/S15 = s14 2. Suspension Setup = a lot of stuff 3. Wheel/Rim Size front & back = 18x9, 18x10 4. Brand of Wheel/Rim = Burning Black Work VS KF 5. Offset front & back = Perfect 6. Spacer Size = None 7. Tire Size front & back = 225/40/18, 235/40/18 8. Alignment Specs = camber -2.7f, -2r, 7.5 caster, 0 toe 9. Clear Zbrakes & what size brakes = of course 10. Fender Modifications: rolled/pulled = slight roll no pull by mr. Dousan
NAKAMA | ROOTS RUN DEEP |
Man w/ CTSV & a Car Seat
2. Suspension Setup = CRAP: Eibach sportlines/tokicos 3. Wheel/Rim Size front & back = 17x10 all around 4. Brand of Wheel/Rim = 5-zigen FN01R 5. Offset front & back = +12 all around 6. Spacer Size = None 7. Tire Size front & back = 245/40 front 255/40 rear 8. Alignment Specs = -.9 fronts -1.5 rear 9. Clear Zbrakes & what size brakes = clears 30mm Z brakes 10. Fender Modifications: rolled/pulled = ghetto pulled fenders all around ![]() |
Bringing this thread from the dead, I think a MOD should clean it up and sticky it. Anyways here it goes
1: S13 2: Megan Coilovers 3, 4, & 5: 17x8 +35 Zigens FN01R 6: 10mm front and 15mm rear spacers 7:235 40 17 Azenis ST115 all around 8: -2 camber front & -1 rear 9: Clears Q45 and Z32 brakes 10:rears rolled I did not have the tires for the rear when I took the pics, but they look as flush IMO as the front ![]() Here's a pic from the side so you could tell my ride height more or less ![]() Last edited by AmuroRay555; 02-23-2006 at 10:30 PM.. |
Admin Asshole
![]() Join Date: Mar 2002
This won't get the coverage it needs being in the Tech Section. Moving it to Chat.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
1. S13/S14/S15 = S13 Hatch
2. Suspension Setup = Silk Road RM/A8 3. Wheel/Rim Size front & back = 15x7.5 4. Brand of Wheel/Rim = SSR Reverse Mesh 5. Offset front & back = +7 6. Spacer Size = none used 7. Tire Size front & back = 195/50/15 8. Alignment Specs = Front: 3.5 degrees camber/0 toe/7 degrees castor Rear: A lot of camber (prolly 2.5-3)/0 toe 9. Clear Zbrakes & what size brakes = Have stock brakes, won't clear Zs 10. Fender Modifications: rolled/pulled = Rear fenders rolled slightly, but no need unless you run 60 profile tires 11. Picture.. from the side & down the side = Second pic, rear wheels are 16x8+32 ![]() ![]() 1. S13/S14/S15 = S13 Hatch 2. Suspension Setup = Silk Road RM/A8 3. Wheel/Rim Size front & back = 15x7 4. Brand of Wheel/Rim = Riken Mesh 5. Offset front & back = +2 6. Spacer Size = none used 7. Tire Size front & back = 205/60/15 8. Alignment Specs = Front: 3.5 degrees camber/0 toe/7 degrees castor Rear: A lot of camber (prolly 2.5-3)/0 toe 9. Clear Zbrakes & what size brakes = Have stock brakes, won't clear Zs 10. Fender Modifications: rolled/pulled = Rear fenders rolled slightly, but no need unless 60 series tires 11. Picture.. from the side & down the side = Only on front, can't find any pics of them all around ![]()
PROCEED Grip Gambler |
1. S13
2. flta2's 3. F 18x9 R18x9 4. Nissan ? BNR34 OEM 5. F +30 R +30 6. F 15mm R 15mm 7. F 225/40 st115 R 225/40 st115 8. F -3 camber, 7*caster R -2.2 camber 9. stock brakes 10. F rolled R rolled and pulled (about 5mm) 11. ill get some new pictures soon, these will do for now ![]() ![]() |
1. S13
2. Apexi N1 PRO 3. 17x9 front and rear 4. Veilside Andrew 5. +17 front and rear 6. no spacer 7. 215/45/17 front and rear 8. -2 F, -2.4 R 9. Clears Z32 10. Just rolled with a hammer, now they are pulled in the rear and some fatter tires will go on ![]() ![]() ![]() ![]() |
![]() Join Date: Feb 2003
1) s13 coupe
2) Tein HE 3) 16x7.5 4) Volk SF mesh 5) +22 6) 25mm kics bolt ons 7) 205/50/16F 225/50/16R(pictured, but normally 205/50's all 4) 8) -2.8f -2r 9)clears Zbrakes with spacers, does NOT clear Z brakes without the spacers 10) rear fenders pulled about 15mm, fronts rolled\ Rear with buldging 225/50's: ![]() ![]() Front pics w/205/50/16's ![]() ![]()
![]() Join Date: Jul 2004
s14
MR C/O 17x9+15 225 45 17 17x10+12 245 45 17 Falken st115 5Zigen FN10RC What ever you get from a 3" drop front, and 4" drop in rear. 26mm clear z brakes, these suckers will clear 50mm brakes ![]() Rears are pulled .75" ![]() ![]() |
#14 |
![]() Join Date: Nov 2003
1. S14
2. Tanabe sustec pro 3. 17x9 , 17x9 4. ADVAN SA3R 5. +22 , +22 6. none 7. 235/40 , 245/40 8. camber -2 front, -2.5 rear 9. Clear any breaks 10. no roll or pull ![]()
![]() Last edited by p11driver; 09-17-2005 at 03:16 AM.. |
#15 |
My old white car...
1) S13 coupe 2) KYB AGX/RS*R Race/HKS pillowball mounts 3) 16x7.5 4) Kosei K1 5) ET32 front and rear 6) none 7) 225/50R16 8) always changing, cleared everything with every alignment setting I threw at it 9) clears EVERYTHING 10) stock bodywork ![]() conservative setup. but I liked it a LOT. very versatile. |
#16 |
1. S13
2. KTS Coils 3. F 18x8.5 R 18x9.5 4. Enkei NT03+M 5. Offset F +38 R +27 6. Spacer F +30 R +30 (new offsets F +8 R -3) 7. Tires F 225/35/18 (soon to be 245/35/18) R 275/40/18 (soon to be 275/35/18) 8. No alignment specs 9. Clears Z brakes 10. +15mm Front +50mm Rear ![]() ![]() ![]() ![]()
#17 |
![]() Join Date: Jan 2004
1. S14
2. Tein FLEX coilovers, RUCA's, Rtoe arms 3. 18x9 F 18x10 R 4. Volk Racing SF Challenge 5. Offset front & back = +10, +11 6. I dont need no stinking spacer 7. 235/40/18 F 255/35/18 R AVS Sports (run a bit wider, like a 240/260) 8. -3 camber F, -2 camber rear 9. Z Tuner Z32 kit 12.3in rotors clears no spacer 10. Front +20mm over fenders, rears pulled ~25mm
#18 |
1. S14
2. Tein HE (reasonably low, not "slammed") 3. 17x9 (all 4) 4. Enkei RPM2 5. Offset +40 6. 15mm spacer at all 4 corners (effectively +25 offset) 7. 235/45/17 (F), 255/40/17 (R) Kumho MX 8. -2.5 camber (F), -1.8 camber (R) 9. Z32 brakes (all 4 corners, wheel clear with or without the spacers) 10. Front fender untouched, rears *barely* rolled. 11. No good pics of the height/clearance, but here goes anyway: ![]() - Brian
www.KA24DEvelopment.com |
#19 |
2. Suspension Setup =SilkRoad RM/A8 3. Wheel/Rim Size front & back =15x6 4. Brand of Wheel/Rim =Infiniti G20 5. Offset front & back =45 6. Spacer Size = None Yet... 7. Tire Size front & back =205/60/15 8. Alignment Specs = 9. Clear Zbrakes & what size brakes =Haha, No!!! 10. Fender Modifications: rolled/pulled =Haha, No!!! Again!!! 11. Picture.. from the side & down the side = ![]() ![]() P.S. I know they're baby, but a lot of people can't decided if they want the "type x" look, this should help them. I'll be the guinea pig. These are just temporary till i can get some work equip 03's |
#20 |
Just thought I would bring this back in case anyone missed it the first time around. I know we all don't check the forum every single day or at least I dont.
Later,
#21 |
2. Suspension Setup = Zeal B6 (clears front coils by about 6mm) 3. Wheel/Rim Size front & back = 17x9 all around 4. Brand of Wheel/Rim = Titanium Bronze 5Zigen FN01R-C 5. Offset front & back = +20mm all around 6. Spacer Size = front 6mm (to clear coils), rear 10mm 7. Tire Size front & back = 215/40/17 falken fk451 8. Alignment Specs = front -2ish, rear -3ish 9. Clear Zbrakes & what size brakes = clears tt z brakes by like ~2" 10. Fender Modifications: rolled/pulled = rolled all around 11. Picture.. from the side & down the side = |
#22 |
![]() Join Date: Apr 2004
1. S14
2. H&R Springs, Stock struts 3. Front 17 x 8.5 Rear 17 x 9.5 4. M2-Hanabi DT-05R 5. Front offset +25 Rear offset +30 6. No Spacers 7. Front tire 245/40/17 Rear tire 255/40/17, Yokohama AVS ES 100s & Falken ST115s 8. ? 9. Clears stock brakes 10. Front fenders are rolled ![]() ![]() ![]()
#23 |
![]() Join Date: Sep 2002
Will be getting new wheels on soon (trying to sell new 17x8 FNs), but here are these for reference.
1. S13 2. D2 Coils (9/7 rates), pretty low 3. 17x7 4. Lenso Superlight (out of production) 5. +38 Offset 6. 5mm spacer all around 7. 215/45/17 Toyo Proxes FZ4s 8. -1.3 camber (F), -1.0 camber (R) 9. 30mm Z32 brakes on front (have to have spacer) 10. Front and Rear rolled just in case ![]() ![]()
'11 M56S '12 QX56 (wife's) |
#24 |
2. Suspension Setup = Silk Road RM/A8 3. Wheel/Rim Size front & back = F: 15x6.5 R:15x7.5 4. Brand of Wheel/Rim = F: Longchamp XR4 R:SSR Reverse Mesh 5. Offset front & back = F: +11 R: +7 6. Spacer Size = none used 7. Tire Size front & back = 195/50/15 8. Alignment Specs = Front: 3.5 degrees camber/0 toe/7 degrees castor Rear: A lot of camber (prolly 2.5-3)/0 toe 9. Clear Zbrakes & what size brakes = Have stock brakes, won't clear Zs 10. Fender Modifications: rolled/pulled = Rear fenders rolled slightly, but no need unless you run 60 profile tires 11. Picture.. ![]()
#25 |
1. S14
2. MR C/O Nismo TR Bushings 3. 18x9 18x10 4. Work Termist TM1 5. Offset front & back =?? leaves a nice dish though 6. Spacer Size = 0 7. Tire Size front & back = 225 40 18/245 40 18 8. Alignment Specs = None at the moment 9. Clear zbrakes front and rear 10. Front rolled, rear pulled 11. Picture.. from the side & down the side = ![]() ![]() |
#26 |
![]() Join Date: Mar 2004
1. S13 Hatch
2. Stock Supension 3. 17 x 9 front and rear 4. Falken Hanabi 5. +20mm front and rear 6. no spacer 7. f 225/40/17 r 235/45/17 8. Stock alignment 9. Tons of space so, I'm sure they will clear Z brakes. Just don't have them yet. 10. Will roll rear soon as possible. Rubs during hard cornering. Must roll before droping. ![]() ![]() ![]()
LSX Kouki Project, swap completed in Dec 09 |
#27 |
Just thought I would bring this back. Good piece of info for those looking for wheels. Anyone got a s14 with 18x8.5 F and 18x9.5 R with a Tein Flex/Super Drift C/O setup? Would like to see pics of that! Looking for the best offset/tire sizes. Thanks.
#29 |
![]() Join Date: Mar 2003
1. S14
2. cusco comp zero 2, battle version arms 3. 18x9 F 18x10 R 4. Rays Gram Lite 57pro Face 2 5. Offset front & back = +22, +22 6. no spacers 7. 225/40/18 F 245/40/18 R Fuzion zri 8. -1 camber F, -3 camber rear 9. z32 brakes front, se rear 10. front rolled, rear rolled and pulled 5-7mm ![]() ![]() |
#30 |
![]() Join Date: Apr 2003
1. 1993 s13 coupe
2. KYB AGX shocks / Espelir Active Super Down Springs 3. 15x7 front and back 4. Konig Rewind 5. +0 offset front and back 6. No spacer 7. Falken Zieks ze-512 195/60/15 8. No deliberate alignment, whatever camber the drop gave me *needs alignment bad though* 9. Unsure about Z-Brake clearance, stock s13 brakes 10. No fender mods *rear could be pulled a wee bit* ![]() ![]() ![]()
