Old 06-18-2008, 04:12 PM   #1
Master Chief
Master Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to all
My Oil cooler setup on an S14...
Hi all, i thought i would share what i did, as it took some reaserch and i hope this will save someone, the trubble in the future.
Basicly with the new engine i wanted to drop the whole inefficient OEM Water cooled Oil cooler, that comes original on some Euro market models, and others.
I decided to use the oportunity to move the Oil filter to a better location for quick changes as well.
The oil cooler location was hard to decide on. There was either the Passanger wing (instead of the washer bottle), or between the RAD and the FMIC.
As i wanted to keep the lines as short as possible, and allso keep the stock under covers i opted for the wing at the end.
Here is what parts i used and what i did.
From RHDJAPAN :
Tomei N2 oil block, with 10AN fittings. - 228$
Greddy/Trust/Grex Thermostatic filter oil plate. - 163$
From anplumbing.com:
SETRAB #625 Oil cooler - 25 Rows with 10AN fittings. - 206$
6 X Streight 10AN Swivel-Seal fittings, part #800110. - 63$
1 X 45 Deg. 10AN Swivel-Seal fitting, part #804610 . - 23$
1 X 90 Deg. 10AN Swivel-Seal fitting, part #809110 . - 23.5$
10 feet of 10AN Perform-O-Flex braided hose, part #410010.
I had plenty of left overs, but since it was my first time working with braided hose, i wanted some spairs for experiments, but even after that i was still left over with quite a bit..... Make your masurments and order acordingly. I think that 6 feet is more the enough and costs - 54$.
From my local ACE depot - some metal and aluminium brakets and bolts, about 10$ worth.
Grand total about 770$. Not cheap, but every part is the BEST money can buy, for this type of thing.
You can save big on the hoses and fittings if you go for cheaper brands - same goes for the cooler and the rest of the stuff....
So, what i did.
1. Install the TOMEI block. I had to block off some colant pipes that were used for the OEM water cooled cooler - most of you wont have this problem.
The 10AN fittings that come with the Tomei Plate, are 12mm ID on one side, and only 10mm id on the other side. You dont need to do this, as the passages in the block are about 10mm id, but i used a 12mm drill and enlarged the fittings ID , all the way thru , to 12mm.
The fittings that come on the Greddy/Trust oil block ar 12mm all the way.
2. Next you need to decide on a location for the oil relocation plate. I made a flange, and connected below the battery tray - i had to drill two holes for that.
You can see here the hoses connected already.
All the STREIGHT fittings were used to connect to the Filter block, and to the Tomei block on the engine.
This filter relocation block requires a 3/4-16 UNF filter - i used the Greddy filter - part number "OX-1" - its 65mm Dia. You can use other types as long as they are 3/4-16 UNF. Check the Greddy site for more specs.
3. Next was the hard part. Mounting the Oil cooler and routing the lines to the wing area. I had to make some brakets for it, but i didnt have to drill any holes in the cars body. I used available holes only.
I think the pictures speak for themselves.
Remeber to check that you can get the hoses to the oil cooler, from the filter relocation block - without them tuching anything.
If they come close to something, use a piece of rubber hose to isolate them, as braided hoses wil eat thru any metal they tuch.
Allso remeber that these type of hose have a minimum bend radius of 4".
If you try to bend them tighter than that, you will damage the hose.
The way i routed them was the best i could find. They are pretty loose, and hardly tuch any metal. Where they do, i isolated them with a bit of silicon hose wraped around the relevant area.
Allso the cooler itslef is monted with insulated rubber on all corners, as recomanded by SETRAB.
Its important the have some FLEX in the whole system, so it wil apsorb the vibrations.
Here are the lines needed from the Filter Block to the cooler, and the brakets i made.
Here is the cooler mounted. Notice the Top mounting point, and the 90Deg fitting.
Here you can see how the line route benith the car to the engine compartment, and the beautiful braket i made.
The bottom line is with the 45 Deg. fitting.
Thats it.
The bumper goes back on, no problem with this size cooler. I would say that its the biggest you can get in there, with a FMIC and OEM bumper.
This is a ZENKI, but i belive it would look the same on the KOUKI.
Allso, if you dont have the arch lining you should make some kind of protection for the cooler, not to get hit by a rock or something.
Before you start the engine, i recomand to use the top line that goes to the cooler, and prime the cooler with fresh oil.
start the engine, check for leaks and go for a ride.
As its a thermostatic oil relocation/oil cooler block - you wont have problems geting to cold temps.
It would be a good idea dough, to monitor the oil pressure.
Leme know what you guys think, and if you have questions that i can answer.
Thanks,
Dany.
Master Chief is offline   Reply With Quote
Old 06-18-2008, 04:30 PM   #2
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
Looks great.
Awesome job and write up.
+1 to ya.
Old 06-18-2008, 04:35 PM   #3
zenki_240sx
zenki_240sx's Avatar
zenki_240sx is an unknown quantity at this point
Send a message via AIM to zenki_240sx
vey nice!!!!!!!
zenki_240sx is offline   Reply With Quote
Old 06-18-2008, 04:37 PM   #4
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
damn looks good. ++ for u
xdumbxguyx is offline   Reply With Quote
Old 06-18-2008, 04:39 PM   #5
97KATURBOSILVIA
Banned from the Marketplace
Trader Rating: (-1)
97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light
Feedback Score: -1 reviews
Yes indeed that is a sweet set up and $700 for added motor security sounds good to me +rep for u
97KATURBOSILVIA is offline   Reply With Quote
Old 06-18-2008, 04:42 PM   #6
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
very nice and clean dude +1
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 06-18-2008, 04:42 PM   #7
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
sick setup!!!
www.realize-jp.net
Old 06-18-2008, 04:43 PM   #8
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
looks nice and clean, I like your brackets and how you mounted stuff. Good write up, + for you.
MELLO*SOS is offline   Reply With Quote
Old 06-18-2008, 04:56 PM   #9
Master Chief
Thanks guys.... I guess now i should go and take some pictures of the rest of the engine.....
Old 06-18-2008, 04:59 PM   #10
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
looks great man, i'll be posting my writeup on this soon, but in a different location.
INeedNewTires is offline   Reply With Quote
Old 06-18-2008, 05:01 PM   #11
McRussellPants
wheel has to be 2in from that cooler at full lock.
McRussellPants is offline   Reply With Quote
Old 06-18-2008, 05:12 PM   #12
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
dude, that is one hell of a sick setup
https://instagram.com/e_lemonation/: @e_lemonation
Old 06-18-2008, 05:13 PM   #13
Master Chief
It looks close in the picture, but the cooler sits way inside within the OEM arch liner....
I aggree that if the wheel will tuch the liner, it might get close, but i dont think its suposed to tuch the liner, even with wide wheels and tyres.
I could always give it a bit more angle, on the Y AXIS if there is a problem, but for now its clears very well.
Old 06-18-2008, 05:29 PM   #14
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
sick. very nice.
I CAN FLASH MODIFY YOUR XBOX 360.
Modrified is offline   Reply With Quote
Old 06-18-2008, 05:58 PM   #15
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
i'm beating a dead horse...but
sick setup!! that cooler looks awesome, setrab is the shit
clark is offline   Reply With Quote
Old 06-18-2008, 06:03 PM   #16
mangoes
mangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond repute
very nice and clean.
i want to lick your engine.
Outside Family
mangoes is offline   Reply With Quote
Old 06-18-2008, 06:34 PM   #17
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Very Nice I will be looking at this as a referance !!
WoolyS14DET is offline   Reply With Quote
Old 06-18-2008, 06:39 PM   #18
GSXRJJordan
GSXRJJordan's Avatar
Overkill, but I dig it.
I used an oil filter relocation kit ($80 @ Baker Precision), a $50 Earl's core (same size as your Setrab), and a couple AN->90* barb fittings. No thermostat (takes a while for oil temps to come up). Mounted it in the same spot, basically.
$135, same performance, less bling.
Old 06-18-2008, 11:16 PM   #19
Master Chief
I aggree, and also mentioned that you can go way cheaper and get a similar result.
I just have this thing, from experience unfortunatly, about doing things the right way, first time.
A 80-100 PSI hot oil system, using a couple of barb hoses runing thru my engine, doesnt sound good enough for a 500HP car, intended for drifting.
On the other hand i bet it could work just as well, but would require meaby some attention, here and there.
BTW: I must admit - the bling factor is always a plus in my book - as long as its allso functional.
Thanks for the comments guys, and i really like your Zenki GSXR....
Old 06-19-2008, 04:07 AM   #20
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
awesome set up man... so 500 drift car huh... please do post those engine bay shots
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
Old 06-19-2008, 06:20 AM   #21
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
Pretty nice set-up and good to see a write up.
Hope you put this thing to good use!
IIIXziuR is offline   Reply With Quote
Old 06-22-2008, 01:06 PM   #22
Master Chief
I defently intend to, IIXziuR !
Old 06-22-2008, 03:27 PM   #23
florante rea
florante rea's Avatar
Trader Rating: (43)
florante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of light
Feedback Score: 43 reviews
Send a message via AIM to florante rea Send a message via Yahoo to florante rea
thanks for sharing.
fdrea
florante rea is offline   Reply With Quote
Old 06-22-2008, 04:57 PM   #24
TheArkitekt
TheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the rough
very nice, same place i mounted mine but mine sits out a little further. It made a huge difference to my cars oil temps on the track. after a 20 minute session the temps stayed stable.
TheArkitekt is offline   Reply With Quote
Old 06-22-2008, 05:02 PM   #25
Nismogirl
Nismogirl's Avatar
Nismogirl will become famous soon enoughNismogirl will become famous soon enoughNismogirl will become famous soon enoughNismogirl will become famous soon enough
Send a message via AIM to Nismogirl
very very nice and sexy... keep up the good work
Aim= nismonancy
Nismogirl is offline   Reply With Quote
