Old 10-26-2005, 03:22 PM   #1
thejester03
thejester03 is an unknown quantity at this point
Send a message via AIM to thejester03
Power Assist Fluid Q
My friend has a 95 240, with power assist steering, does it use PS fliud or AT fluid?? Hes been running PSF, and has been working fine, we are having a debate on wihich it uses, help me win some money guys!!!
Signature Exceeds Forum Limits
thejester03 is offline   Reply With Quote
Old 10-26-2005, 03:33 PM   #2
SHIFT_control
SHIFT_control's Avatar
SHIFT_control is a well-known jackass
It can use both..... the ATF has to be dexron III though
'93 Pathfinder SE daily driver
'93 HB blue (under construction)
'89 Celica GTS RIP
SHIFT_control is offline   Reply With Quote
Old 10-26-2005, 06:30 PM   #3
projectRDM
projectRDM's Avatar
PS fluid will eventually damage the pump and rack.
FORMERLY R240NA
Old 10-26-2005, 07:39 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
Dexron III ATF ***ONLY***
Originally Posted by PHLIP
Old 10-26-2005, 10:25 PM   #5
S14DB
AFC #1
S14DB's Avatar
My rack is shot now that the Previous Owner used PSF.
Old 10-27-2005, 11:51 AM   #6
sdtouge
sdtouge can only hope to improve
i tohught 240s were power steering, why would the power steering fluid mess up the rack and pump? and how long does this take to happen.,
sdtouge is offline   Reply With Quote
Old 10-27-2005, 06:24 PM   #7
projectRDM
projectRDM's Avatar
Congratulations on the receipt of your brain.
Yes, 240s have power steering. Most cars do. However, that doesn't mean they're designed to operate on thick, heavy power steering fluid. Most import cars use ATF because it's thinner, has a higher viscosity, and doesn't breakdown as fast. Plus it has anti-corrosion products in it to reduce buildup and varnish inside the lines and rack. Using straight PS fluid will gum up the lines and increase friction, wearing the gears in the rack and the bearing in the pump.
FORMERLY R240NA
Old 10-27-2005, 10:52 PM   #8
sdtouge
i was saying i thought they were power steering, ie not like some wierd systtem lol that i dont even know about. hence the power steering fluid.
Old 10-27-2005, 11:49 PM   #9
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
Why not run Nissan power steering fluid?
Then there are no questions about compatibility.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 10-27-2005, 11:55 PM   #10
mrmephistopheles
You can, but Nissan PS fluid is Dexron III ATF.
May as well save the extra $3-5.
ALL Nissan cars (mid 80s and up at least) use Dexron III ATF for PS.
Old 10-28-2005, 12:07 AM   #11
krustindumm
I just use OEM fluids everywhere, except oil (Mobile1) and usually I have no problems.
Old 10-28-2005, 12:53 AM   #12
mrmephistopheles
haha ok smartass, fine
DEXRON only!
Dexron III came out in 89 i think, just newer better version of Dexron II
Old 10-28-2005, 08:18 AM   #13
krustindumm
IDK, i can't remember what the backwards compatibility is, I was just messing around.
