Old 04-25-2005, 04:23 PM   #1
khoadogg
khoadogg's Avatar
khoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of light
Send a message via AIM to khoadogg
Q45 brake alternatives
What other rotor alternative options do I have if I want to run Q45 front calipers on a 4x114.3 . Will 1999 G20 rotors in 4lug fit the calipers?
Thanks,
Kho-ah
AIM SoarinStrong[B]STRONG 6iX[B]
RB single turbo ///Work AMKREAD 180sx
khoadogg is offline   Reply With Quote
Old 04-25-2005, 04:44 PM   #2
BoroBoroS13
BoroBoroS13's Avatar
BoroBoroS13 is on a distinguished road
I had a G20 back in the day and now I have the Q45 setup on my 240. The G20 rotors are barley if at all bigger than stock S13 rotors. As for them working, I have no idea.
BoroBoroS13 is offline   Reply With Quote
Old 04-25-2005, 06:18 PM   #3
JuJuBee
JuJuBee is an unknown quantity at this point
1998 altima rotors are exactly what you are looking for
same size and the bolt pattern is 4x114.3
JuJuBee is offline   Reply With Quote
Old 04-25-2005, 09:59 PM   #4
khoadogg
khoadogg's Avatar
You can rock 1998 altima rotors w/ Q45 calipers?
Old 04-25-2005, 10:52 PM   #5
S14DB
AFC #1
S14DB's Avatar
Yeah can anyone confirm that these are 11"x28mm and 4lug?
Old 04-25-2005, 11:05 PM   #6
BoroBoroS13
If they are im gonna be pissed cause I paid quite a bit to have my power slot rotors cnc'ed to 4 lug.
Old 04-25-2005, 11:14 PM   #7
JuJuBee
why dont you guys just call the dealer
Old 04-25-2005, 11:55 PM   #8
BoroBoroS13
Cause the dealer is stupid as shit and tends to say this, "It will only work on the car it was made for."
Old 04-26-2005, 12:25 AM   #9
JuJuBee
your dealer sucks then
superior nissan 4 lyfe
Old 04-26-2005, 12:30 AM   #10
HyperTek
hey khoah if you wanna beef up the brakes, pick a park in ontario got a few q45s... I think the rear brakes will swap over, big ass mofos with internal drum brakes...
Keep it Classy
Old 04-26-2005, 01:40 AM   #11
khoadogg
khoadogg's Avatar
i have the brackets already. I just need calipers and rotors. I'm waiting for a set of calipers for $50 so I'm trying to research some budget rotors.
Old 04-26-2005, 04:20 AM   #12
JuJuBee
nobody is giving my altima specs but here are links i found
http://forums.freshalloy.com/ubbthre...e#Post67921752
from www.napaonline.com
NAPA United Rotor - Front
Click on image to see enlarged view
Item#: UBP86363
Price: $ 86.49
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Usually ships in 24 hours.
Attributes:
Attributes: Rotor - Front
Diameter: 11 1/64''
# of Bolt Holes: 4
Bolt Circle Dimensions: 4.50''
Discard Thickness: 0.787''
doesnt tell you width but diameter wise...its 1/64" bigger which i doubt you can even measure
Old 04-26-2005, 10:48 AM   #13
S14DB
AFC #1
S14DB's Avatar
Spec's I see are that the rotors(altima) are 280mm(11") but only 22mm thick. Am I right or wrong?
Also, what is the "Full Active Suspension" on the Q45 and how does it afect caliper choice?
Old 04-26-2005, 01:13 PM   #14
JKim0901
JKim0901's Avatar
JKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfectionJKim0901 is close to perfection
i would also like to know if those altima rotors will work, i have a set of q45s that i never got around installing yet, more answers please
JKim0901 is offline   Reply With Quote
Old 06-16-2005, 02:45 AM   #15
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
altima rotors dont work, i looked on brembos site. theres no 4lug rotor on any nissan, infinity,toyota,mazda that will work with q45 calipers. if you look at brembos site and go to the pdf it shows diameter, thickness, and height. theres nothing that comes close enough thats 4 lug to be safe. Someone on freshalloy says he has the setup working. hes full of shit
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 06-16-2005, 04:04 AM   #16
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
good find...... phrozen........... ok
boroboros13, dude how much did it cost to get the rotors cnc'd? couldnt u have just did a template and used a drill press...? carboard white paper and crayola is the shit..
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-16-2005, 08:04 AM   #17
SHIFT_control
SHIFT_control's Avatar
SHIFT_control is a well-known jackass
the "active suspension" on the early Q45 is in essence the same as the electric dampners on the Z32 and WD21 Pathfinders. Nissan decided to be different when they named the system. Anyone needs Infiniti parts im you man, I'm on the parts counter at an Infiniti dealer
SHIFT_control is offline   Reply With Quote
Old 06-16-2005, 01:07 PM   #18
infinitexsound
at cost? or discounted? how much for 1 q45 rotor?
Old 06-16-2005, 02:23 PM   #19
SHIFT_control
I'll have to get with my boss on monday to see what I can do..... I can also get Nissan parts since we're a Nissan dealer too, maybe 20% off retail or something like that, I'm gonna be in charge of internet sales here so I'll have pretty much free reign.
Old 06-17-2005, 02:38 AM   #20
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
koah I thought you sold the 180. now your keeping it?? man pick one and keep it haha, besides the 180 is fat tits nice IMO
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 06-17-2005, 09:51 AM   #21
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
Altima U13 (93-97) and L30 (98-01) have 4 lug rotors... Both should have the same spec on them. the 1st gen (U13) parts are cheaper than L30 I think...
Hope it helps.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 06-17-2005, 11:07 AM   #22
khoadogg
khoadogg's Avatar
The car is sold but I'm still doing research for friends. I have a set of 30mm complete for sale. Rockin' the TT brakes on the soarer.
Old 06-17-2005, 11:23 AM   #23
Irukandji
i just q45 brembo blanks from nopi.com
theyre pretty inexpensive, then i just took them to my mechanic and he redrilled them to 4 lug for a very good price..
Irukandji is offline   Reply With Quote
Old 06-18-2005, 03:10 AM   #24
infinitexsound
ok well i check'd out the price its not even great of a price.. it cost the same or even more... ive seen OEM ones for as low as 15 bucks a piece, but its the shipping which bites u in the ass...
Old 09-10-2005, 12:38 PM   #25
VIPCefiro
VIPCefiro is making a name for him/her selfVIPCefiro is making a name for him/her self
ok, I went to my local autozone today with a stock 4-lug rotor off my s13, an infiniti Q45 5-lug rotor, and I requested to check out a 98 altima 4-lug rotor.
Here are my findings.
bolt pattern - identical
diameter - might be a fraction smaller, but not noticeable.
thickness of the rotor - big difference. The Q45 rotor is much thicker than the altima rotor, I'd say by at least 1/8" (this is eyeballin only, don't quote me on that) Then I asked the dude. . So do you think it will clamp? He said, probably not.
If they are indeed 22mm, q45 rotors are 1mm thinner than the zbrake 28mm rotors, so that makes it 5mm difference in thickness.
Sooooo. . . I really wanna know if anybody is running Altima rotors on their q45 brake conversion. If so, lemme see some pics!
VIPCefiro is offline   Reply With Quote
Old 10-12-2005, 02:25 PM   #26
nocturnaldrifter
nocturnaldrifter's Avatar
nocturnaldrifter is an unknown quantity at this point
Send a message via AIM to nocturnaldrifter
here it is
1990-1996 Q45's have front brake rotor dimensions of:
Brake Rotor Dimensions
Outer Diameter 11.02 in (280 mm)
Standard Thickness 1.10 in (28.0 mm)
I have done A LOT of research and I just measured my rotors, exactly 28mm thick and 11 inches in diameter.
nocturnaldrifter is offline   Reply With Quote
Old 10-12-2005, 08:03 PM   #27
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Hmmm.... very good information. Going from memory.......isn't this the same size as the 300zx rotors??? I'm looking to do the Z32 upgrade also and would love to not redrill Z32 rotors.
And I'm guessing the 90 - 96 Q45 rotors are 4 lug right? Cause the post above you claimed they were 5 lug.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 10-12-2005, 08:09 PM   #28
Gjohnson7
Nevermind I looked it up real quick, Z32 rotors are 280mm x 30mm.
Old 10-12-2005, 10:05 PM   #29
phrozen
like i said on. there is no 4 lug rotor that will work with q45's i went thru brembos complete pdf of rotors aftermarket and stock and nothign was even close enuf
-Moderation
Old 10-12-2005, 10:59 PM   #30
golfer17
golfer17's Avatar
golfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nice
Send a message via AIM to golfer17
i got some q45 brakes, and i was wondering what kind of good racing/street pads were made for it. all the good pads ive wanted to put on it arent made for the q45 brakes.
golfer17 is offline   Reply With Quote
