Old 09-21-2005, 12:38 PM   #1
driftking777
driftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of lightdriftking777 is a glorious beacon of light
SR oil banjo fitting to the block
I have ran into a problem...took off my turbo the other day to find out that the threads for the banjo bolt for the oil to the turbo have been stripped...i have talked to a few sources and on person said, since there are more threads in the block that have been untapped, get a double banjo bolt of the same size and use that. cut off the excess threads and call it good...another person suggested that i get it helacoiled (imporper spelling?) but that person wasnt sure if you could bore that part of the block out far enough to do that? so im asking for some suggestion to people that have A) come arcross this problem, or B) know what the hell there talking about...or C) have an extra SR block just sitting around for me...anywho...any help would be appriecated.
driftking777 is offline   Reply With Quote
Old 09-22-2005, 10:35 AM   #2
SirWarrior
SirWarrior is an unknown quantity at this point
tap it for AN line and run those instead.
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 09-22-2005, 10:37 AM   #3
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
it can be helicoiled....very cheap and very effective
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 01-19-2006, 10:07 PM   #4
fcdrifer17
fcdrifer17 is an unknown quantity at this point
did this problem get solved?i have the same exact problem..how do i get it helicoiled? and where? what else can i do? does anybody know were i can find a differnt sizes banjo bolts in socal, fontana? thanks
fcdrifer17 is offline   Reply With Quote
Old 01-19-2006, 11:00 PM   #5
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Helicoils are something you can do yourself. It inclues using a tap and these weird little insert things that take place of the damaged threads. I think Autozone or whatever you have in your area should be able to give you a hand
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 01-20-2006, 07:37 AM   #6
g6civcx
g6civcx's Avatar
If the threads on the bolt are stripped, you may discard the bolt and upgrade to braided lines from Taka Motorsports. They come with their own fittings that will thread directly into the block.
If the threads on the block is stripped, you may follow the directions above.
