Old 01-29-2007, 09:12 PM   #1
nissolet
nissolet's Avatar
nissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-known
KA clutch pedal is weak...
so i just installed a new clutch on my 91 coupe, and bleed the line perfectlly there is no air in them. but my clutch feels realy weak like there is not alot of pressure, why? is there away to ajust the clutch? if you how?????
please help i just bought the car and cant wait to drive it to school...
nissolet is offline   Reply With Quote
Old 01-29-2007, 09:15 PM   #2
snappy
snappy's Avatar
snappy is an unknown quantity at this point
it's just the new clutch... it releases at the bottom and isn't stiff cuz it's brand new.... The only time it's stiff is if it's a stage 2 or higher and if it's a high performance clutch..... If it doesn't feel right you can always adjust the clutch pedal but it's a bitch sometimes.
Originally Posted by holemilk00 View Post
Its a 98 LE (leather edition)
snappy is offline   Reply With Quote
Old 01-29-2007, 09:40 PM   #3
nissolet
nissolet's Avatar
its a stock new clutch but it feels so so weak that when i test drove it, i felt like it had no clutch pedal not springy at all!!!
Old 01-29-2007, 09:49 PM   #4
Sidewayzzz
Sidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura about
Send a message via AIM to Sidewayzzz
still got the clutch dampener line? if that gets air in it, good fucking luck.
Probably your issue there, its easily bypassed..you can either bend the line (carefully) or get a SS Braided line to bypass it. Then you only have to bleed it from the slave, not both.
Sidewayzzz is offline   Reply With Quote
Old 01-29-2007, 11:09 PM   #5
Crono562
Crono562's Avatar
Crono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of light
also u can adjust the clutch pedel, by moving the nut back and forth on the threads where the master cylinder connects to the pedel. take a look and youll see what i mean
Mikey "Whitey" Ernst
'www.justdrift.com'
Crono562 is offline   Reply With Quote
Old 01-30-2007, 07:23 AM   #6
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
werd. do this. that little box is a pain in the ass. that bitch takes forever to bleed. your pedal will feel much better.
ladiesman8527 is offline   Reply With Quote
Old 01-30-2007, 07:44 AM   #7
g6civcx
g6civcx's Avatar
Replace the following:
* master cylinder with an OEM unit from the dealer
* slave cylinder with a Nismo unit
* all hardline, flexline, damper and loop with a Taka Motorsports braided line that goes straight from the master to the slave cylinder
Then bleed the slave cylinder and adjust the clutch pedal as per FSM.
Old 01-30-2007, 11:10 AM   #8
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Don't forget to replace the pivot bolt with the nismo upgrade when you do this. Recommended cause it will crack from the higher pressure slave.
http://www.courtesyparts.com/Merchan...de=30537-CLTPV
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 01-31-2007, 07:44 AM   #9
g6civcx
g6civcx's Avatar
Definitely replace the pivot bolt at the same time you replace the clutch.
Old 02-08-2007, 11:01 PM   #10
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
What other oem slave cylinders are good out there? I just replaced mine last October and it just died on me tonight on the freeway in traffic.
I'm looking at another oem replacement. This one is Beck/ Arnley $26 w/ a 1yr warranty where the others have only 3months at $10-$14. Or I can just get a Nissan unit for $36-40. And yes, I don't need a Nismo one at $150+...
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 02-09-2007, 08:47 AM   #11
g6civcx
g6civcx's Avatar
Think about what you just said for a minute.
It may not be your slave cylinder at all. Replace the master and braided line and bleed the slave again. It should take you 10 seconds if you use the Taka line.
Old 02-09-2007, 10:35 AM   #12
drew935
drew935's Avatar
You're right right that I shouldn't be looking at oem replacement/ remanu. I'll just get a Nissan oem. Yes, it is my slave as it just spit out fluid on the road. I know it's not anything else. It's not the line, or master. I have no box as well. And I use a power bleeder.
I'm just wondering how long the oem will last since I'm not sure their suppose to last.
I'm driving fast
-drew
