can you still get the Olympic plates in CA?
http://bhworld.wordpress.com/ |
![]() Join Date: Dec 2004
Did you hear about the other Smog shop in Saugus that was raided by the FBI with guns drawn because of a few "hook up" smogs? Pretty crazy and over dramatic I think.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
lol, nah. i heard about one on bouquet canyon road that was caught for clean piping. cali takes smog as "serious business" and will throw a 10g fine on the technician, and a 10g fine at the shop if caught clean piping. the guy who got busted just bought a new machine, and as far as i know, is still doin it.
![]() Join Date: Dec 2002
If i can get my car to run clean without the PAIR valve POS. can it get it certified? i did a SOHC to DOHC swap.
No... no one stole my interior... its safely in my garage... ![]() |
#14 |
the 240's had the pulse air injection up till 94. the only check for that emissions system, dyno test or 2 speed idle, is a visual on the component itself, and checking the vacuum lines. depending on whether the technician notices if it is there or not, he can fail it accordingly. TECHNICALLY, he is supposed to fail it. but if it runs through the tailpipe emissions test, he might either overlook it or just pass it so he doesnt have to retest it again.
#15 |
![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
i got a quick question i need to smog my car but it has engine light on because it used to be auto now its 5 speed stock ka 95 would they let me smog it??
#16 |
technically, your supposed to fail any car with the check engine light on. but since its not OBD II (96' and newer cars) we dont have to plug the smog machine into the diagnostic connector. if it passes the tailpipe emissions test, i would try taking out the bulb, since there is no way to check if the bulb burned out without pulling the dash, and the smog tech wouldnt see that the MIL is commanded on. how many miles can you go after disconnecting the battery without the light turning on?
#17 |
Is this cuz u didn't swap to a 5spd ECU?
Rock wha U jock and don't talk if U ain't got!! ![]() ![]() |
#19 |
try disconnecting the battery to turn the light out, and see how long it takes for it to come back on. if it doesnt come on for a long time, disconnect it again then try and get it tested immediately. hopefully the light wont come on during the test. the monitors and drive cycles on the 95-97 nissans usually take a long time to run, so i think you might have a good chance of the check engine light not coming on for a while after disconnecting the battery.
#21 |
Thats fine, but don't sell the car like that! My g/f bought an Integra and the previous owner did that but didn't tell me. I was having a hell of a time trying to pull codes and trying to figure out what was wrong with that damn car.
#22 |
![]() I have the same problem... Hi NO readings...on my Honda Accord 4 cylinder. Im going to try some suggestions some of you members suggested. some of you seem to have the same problem as I do. |
#23 |
theres a somewhat common problem with accord 4 cylinders. the egr ports get clogged with carbon. theres a technical service bulletin on it somewhere if you can find it
#25 |
![]() Join Date: Apr 2008
Trader Rating: (64)
![]() Feedback Score: 64 reviews
If your motor can pass smog, the BAR should give you a sticker or plaque saying that your swap is legal since ithe motor is newer than what originally came in your chassis.
Check my for sale thread for S13 parts |
#28 |
I know a dude that use to work at the state ref got fired for giving smog advice online and it wasn't even real advice it was like. You have to go to a ref to get so and so tested if you want to have it BAR'd
#29 | |
working for the state ref is "serious business." thats a state run joint, not a mom and pop store like my shop. but damn, just for giving ppl advice? |
#30 |
![]() Join Date: Jan 2008
How come someone can get a GTS-T registered and i cant put an RB20DET into my 240? i just pay for fake smog anyway so it doesn't matter but ive seen a few skylines cruisin around legally registered...
