Old 10-21-2009, 10:46 AM   #151
blackrms13
blackrms13's Avatar
Originally Posted by S-Nation S13 View Post
so i got reffed lol for my external coil,and floor mounted computer (granted i have obd 1 ka) which means he cited me for my stock external coil and assumed i had after market ecu but it was my stock one (m.fullen oceanside pd serial number 1274) effing dumbass citing me for not knowing what the hell is stock or not
so i went to the ref passed all visual but fail the
15 mph :hc 88/103 and no 704/713 <can i run that guranteed to pass juice and lower these numbers? 25mph i passed all so ya whats the best thing i can do? my timing was 18 btdc if i move to 20 or 22 can i lower these number enough to pass?
the repairs ive done
new oem o2 ,oem egr valve,oem egr solenoid,all vac lines changed,new plugs and wires ONLY THING I HAVENT CHANGED WAS CAT, BUT I PASS SMOG COUPLE MONTHS AGO if i have a messed up cat wouldnt i fail across the board ?
SOHC KA = 15 degree
DOHC KA = 20 degree
that should help the numbers...
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 10-22-2009, 05:29 AM   #152
miklos
miklos's Avatar
miklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choices
Found out the EGR solenoid had no ground. The manifold passage was filled with carbon where the EGR mounts. The Vacuum lines were melted back there on an SOHC.
And the egr carbon was there after running seafoam through the throttle body twice.
miklos is offline   Reply With Quote
Old 10-22-2009, 08:47 AM   #153
BILLFISHER21
BILLFISHER21 is an unknown quantity at this point
im so happy we dont have emissions in fl
BILLFISHER21 is offline   Reply With Quote
Old 10-28-2009, 10:52 AM   #154
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Originally Posted by blackrms13 View Post
SOHC KA = 15 degree
DOHC KA = 20 degree
ok i just did that today i was wondering if i ran that guranteed to pass smog juice would it help more seeing that my numbers are so close?
S-Nation S13 is offline   Reply With Quote
Old 10-28-2009, 02:16 PM   #155
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
u want a grantee pass, change ur oil, change filter change or clean o2 and plugs...and check if CAT is good
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 10-28-2009, 03:55 PM   #156
blackrms13
blackrms13's Avatar
those bottle of guarantee to pass thing did not work for me...
then again my numbers were like 3000+ for NOx...so yeah
Old 10-29-2009, 05:29 PM   #157
cc4usmc
cc4usmc's Avatar
How does a smog tech determine that there's a split in a pcv breather hose? I just yanked mine out and cleaned it up and there's no split...and these aren't flimsy little hoses either.
Edit- Is it possible I pulled the wrong hose? I pulled the one coming directly from the pcv. I did a lot of searching but could only come up with threads with dead pictures. When I called the Nissan dealership the guy I spoke to said there are two hoses....so... fuck.
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
Old 10-29-2009, 06:08 PM   #158
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
If you're still answering questions... and don't mind?
High HC @ idle, I don't have to roll just run at idle and I think 2500rpm. Everything else checks super clean. I'm at work and don't have the sheet in front of me atm, so just ideas would help a lot. New o2, new plugs, wires, oil change, fuel filter, 1 yr/o CAT, 91 KA24DE in a 90 chassis, timing 20DBTDC.
Prime is offline   Reply With Quote
Old 10-29-2009, 06:22 PM   #159
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
my friend was wondering if you can pass smog with a 3" catback exhaust......
completely stock and everything
WheelsDirty
Old 10-30-2009, 11:53 AM   #160
S-Nation S13
Trader Rating: (92)
read my first post i only failed 15 mph not by that much if i had a bad cat would i have failed at the 25 mph as well and on top of all of my emission required equipment has been change not to long ago 5 months give or take 1 or 2 months i have a dirty ass filter lol
Old 10-30-2009, 05:01 PM   #161
RBD240
RBD240's Avatar
RBD240 is an unknown quantity at this point
Man, i am glad i live in oregon. In a town that has no smog or deq, My rb20 with 3 inch all the way back and no cat would definatly not pass.
My suggestion to all is move. haha
Goodluck to all. sounds like it sucks.
RBD240 is offline   Reply With Quote
Old 10-30-2009, 05:09 PM   #162
LB.Motoring
LB.Motoring's Avatar
I throw a code because of a wheel sensor, could I clear it drive it around then pass smog?
Robby Leuer
Old 11-01-2009, 06:03 PM   #163
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
hey i was just wondering whats good oil pressure for a s14 sr20det?
TurboStrong is offline   Reply With Quote
Old 11-06-2009, 07:50 PM   #164
SmogSUX
SmogSUX's Avatar
SmogSUX is an unknown quantity at this point
Send a message via AIM to SmogSUX
Tell me..if I have a dohc swapped 89...will the smog tech either:
Not care
Not notice
Kick my ass to the curb
96 S14 w/ Kouki Front
05 Yamaha YZF600
SmogSUX is offline   Reply With Quote
Old 11-07-2009, 01:00 AM   #165
miklos
miklos's Avatar
Not care
Not notice
BAR told me just come to the referee & they will approve it since it is newer than what came in the 89.
Old 11-07-2009, 11:36 PM   #166
s13love-green
s13love-green's Avatar
Trader Rating: (50)
s13love-green is on a distinguished road
Feedback Score: 50 reviews
hey so will it pass if i swapped sohc to dohc????
will they auto fail???
s13love-green is offline   Reply With Quote
Old 11-07-2009, 11:44 PM   #167
NISMO_tuner
NISMO_tuner's Avatar
Trader Rating: (64)
NISMO_tuner is an unknown quantity at this point
Feedback Score: 64 reviews
Send a message via Yahoo to NISMO_tuner
If your motor can pass smog, the BAR should give you a sticker or plaque saying that your swap is legal since ithe motor is newer than what originally came in your chassis.
Check my for sale thread for S13 parts
NISMO_tuner is offline   Reply With Quote
Old 11-08-2009, 11:08 AM   #168
s13love-green
Trader Rating: (50)
do u guys pass cars ...for example i know my wont pass visial so can i take a car same yea and model as a sub to pass mine????
Old 11-08-2009, 12:35 PM   #169
articdragon192
articdragon192's Avatar
I really don't think that's the point of this thread.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 11-09-2009, 10:45 AM   #170
S-Nation S13
Trader Rating: (92)
had a question, what causes you to fail on low speed hc/nox but not high speed. ive cleaned my air filter/check my plugs/timing/clean throttle plate/had all emission related units changed with oem nissan parts/ cat is still the same "IF I HAD A BAD CAT I KNOW FOR SURE ID FAIL HIGH SPEED AND I WOULD FAILL ALL ACROSS THE BOARD!!!"
Old 11-10-2009, 03:46 PM   #171
S-Nation S13
Trader Rating: (92)
so i went back to the ref here are me results:
15mph: HC 88/137 CO 0.52/0.06 NO 704/594
25mph: HC 53/53 CO 0.50/0.06 NO 738/530
ive changed everything possible cap n rotor are next as well as new ngk iridiums and wires, is there anything i can do to lower hc only? ive heard of rubbing alcohol ? is this true?
Old 11-10-2009, 07:29 PM   #172
Howlermonkey
Howlermonkey is an unknown quantity at this point
In virginia, they use the standards for the newer motor if it's in an older car.
If the car is newer than the motor, they use the car standards.
Of course, the tech. would first have to recognize that the car had a different year motor.
Howlermonkey is offline   Reply With Quote
Old 11-12-2009, 01:40 PM   #173
S-Nation S13
Trader Rating: (92)
anyone anyone????? well today just changed out cap and rotor as well as plug wires,oil change and oil filter currently im going to re-time my ignition , any more things i can do to lower my HC readings?????? please im in need of my car lol its the only transportation i have so any help will do please!!
Old 11-13-2009, 02:34 PM   #174
Dezi
Dezi is an unknown quantity at this point
Emissions seem to be a big deal in California but I was wondering if anyone from Florida knows the local laws on emissions or if we are required to get a smog test at all. Another thing I would like to know is if I had a car brought to Florida from another state does it have to get a smog test before I can register it in Florida?
Dezi is offline   Reply With Quote
Old 11-15-2009, 01:55 PM   #175
techn9ne
techn9ne's Avatar
techn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the rough
Send a message via AIM to techn9ne
pcv hose is the big one coming out of the valve cover. yes, THAT big one. it goes into the intake, just before the throttle body on a dohc
techn9ne is offline   Reply With Quote
Old 11-15-2009, 02:00 PM   #176
techn9ne
techn9ne's Avatar
a cat will drop your emissions across the board. youre still measuring high for HC and NOX. granted you are passing the 25mph, the numbers are still high. if your timing, and smog equipment is on the dot, the only thing i could think of would be a misfire, or the cat might actually be bad. is there high O2 coming out as well?
Old 11-16-2009, 11:34 AM   #177
S-Nation S13
Trader Rating: (92)
Tech here are my current results im only failing at hc at low speed but passing at high speed
Old 11-21-2009, 03:03 PM   #178
techn9ne
techn9ne's Avatar
none of those are oxygen. its usually to the left of the hc/co/nox columns
Old 11-23-2009, 10:56 AM   #179
S-Nation S13
Trader Rating: (92)
lol ok so the question is how to i lower HC ?
Old 01-05-2010, 01:51 PM   #180
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
Okay so dumb question, do I have to smog my car every year or every other year for registration?
Its an s13
palmdale_mob is offline   Reply With Quote
