KA 3" exhaust before/after dyno
A few days ago I threw my stock KA24de 240sx on the dyno, bolted on a 3" catback exhaust system and ran it again... here are the results.
![]() This is on my completely stock (intake and all) 100,000 mile 5spd '98 240sx. Last edited by anyotherone; 02-27-2006 at 01:33 PM.. |
Ok, that's better. I'm not sure what's causing the weirdness at 4k rpms... but the graph is what it is... the only change is the catback.
Now that I own a dyno I intend to map every change I make to the car... I just thought that making an easy to find post with a comparison might help somebody making a decision on what exhaust system to buy for their stock(ish) 240sx. |
![]() Join Date: Jan 2005
are u kidding me? those numbers are rediculously low. I got 143hp and and 147 tq with just a 3in exhaust and intake, i got the vid to prove just gotta upload the sucker, i think i would look into ur motor cause that seems a lil low lo me.
A dyno is only good for comparison. Unless you drove down here to TX and dynoed back to back with me, comparing your numbers to mine is completely pointless.
The point is that I didn't loose any power down low. Everywhere across the curve I gained power. |
#9 | |
Hold on let me get this straight. It's 3" and sounds almost as quiet is stock. Sounds like a dumb question, but how? On all other boards I read, you will be horribly loud? Will you post on loudness with header, cause I know they rid of the cat, which usually always = louder. Thanks |
#11 | |
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
he proved that putting a 3 in exhaust on a stock ka will not take away power down low... and its as quite as stock, almost. Sweet
Slip Gypsies Blog Quote:
No problem sil80 - to be honest I was thinking the same thing at first. Our dynojet tends to read a little lower than average, just based on what I usually see on forums and such.
I'm going to test it again with an intake, then S13 cams, then possibly a custom intake manifold, tuned with my AEM EMS. I'm basically just having some fun before a built KA goes in along with a custom turbo setup. |
#14 | |
what if he is using a mustang dyno and you always use a dynojet. Like the original poster said, do compare unless you are willing to drive down to him and use the same dyno. otherwise saying you got XXXRWHP is sort of pointless. |
#16 |
I can't say for certain, but I would speculate that 2.5" would make less power, especially at higher rpms. I can't say for sure, and the difference could be very small.
No way to know for sure unless you test them back to back. |
#17 | |
![]() Join Date: Apr 2003
http://forums.nicoclub.com/zerothread?id=147604 His exhaust uses a resonator which cut's back on exhaust flow and increases back pressure. I've also seen dyno's with 2.5" making almost 8HP without a resonator, and a canister type instead of muffler type. Dyno dipping on the KA is typical at 4000RPM.... |
#18 |
2.5 inch would probably have better low end torque while the 3 inch has better high-rpm power.
8whp is pretty good for an otherwise stock Ka. Thanks for the dyno info. |
#19 | |
![]() Join Date: Sep 2004
~小アレンのリベリオン~ いくせ, 勝負た! 轟こう, オレのKRMS13!!! オレの得意技!蹴り進入!角度の少ないドリフト! ![]() |
#21 | |
You want to lose back pressure. Back pressure is a sound deadening effect that prevents your exhaust from getting to loud. All it does is send pulses back up the exhaust sooner than later, which isn't all that good either, unless you like lots of scavaging, or hot exhaust gasses sent back up the EGR into the mani. Back pressure does serve to maintain good smog emissions, and is no way a performance enhancer to have it. This is true and has always been determined by increased piping diameter as a performance enhancer, or doing to the effect of what is called header out, or cutting pipe where it goes cold. The fact is I live in Cali so I selected a 2.5" pipe to deaden a little bit of noise, and to keep it lower than 95dB. I understand that perferatted pipe is a sound deadener (resonators) and is associated with back pressure, and pulses to run back up my header and cause flow issues. So I selected a cat back exhaust with no resonators. I just didn't want a 3" horn blaring out the rear of my car, weither it had a resonator or not, i just wanted constant, uninterupted FLOW. The 2.5" over 3" debate is stupid, bigger is better. It's just the crap added to the CAT back that can make or break a CAT back as a performance enhancer. It's just a matter of what works with purpose over function. For purpose and function I have selected a 2.5". But if I didn't need a purpose, and just to serve for function, I would use a 3".... |
#22 |
![]() Join Date: Apr 2005
Hey man I was wondering with my custom Exhaust setup I got its 2.5in but no straight pipe its bent and routed just like the stock exhaust that was on the car originally, So you're saying backpreasure is worthless if you're trying to make HP, But tourqe is also sacraficed becasue with my set up I have very little tourqe like I used to when I had the stock exhaust on my car.
#23 |
![]() Join Date: Feb 2005
yay. I was like 95% sure my 3" was perfect for my NA KADE, but this just confirms it. I wonder what im putting out with my intake + exhuast +rebuilt motor with around 15k and full synthetic fluids??? makes me more confident when i go to replace my exhuast (canister is too big and preventing me from going as low as I want in the rear... can we say raked as hell? lol) that i will definatly go 3" again.
Thanks and +1 for you sir. |
#24 |
is this including a straight pipe in the dyno? i was thinking of getting the tanabe medallion concept g blue. its made for turbo applications, but wondering if you'll get results like yours or more without turbo.
#25 |
![]() Join Date: Jan 2006
I just got a 5zigen rocket exhaust(3", straight, no resonator) and expereinced a lot less power than I did with a custom 2.5" with a big resonator and a high flow cat. So, i bought a 2.5" cat which gave me the back pressure that I was lacking. I estimate I'm at around 145hp and roughly the same torque.
This is in my s13 with a 1998 KA24DE, 65k miles with an ebay underdrive pulley and stripped emissions. I have no problem pulling on my friends KAs throughout the powerband. Hopefully I will dyno the car soon. Anyways, I got a bit off topic. I think that if you do get a 3" on a NA KA you need a resonator or cat to provide sufficient horsepower and torque. |
#26 |
AFC #1
![]() Join Date: Oct 2003
Back-pressure rumor is bullshit and has been disproved many times including by me:
![]() Oh, that was on an auto tranny too.
#27 |
![]() Join Date: Sep 2003
daymn i love how u ladies always get disgruntled about the KA topics...
all good, maybe i should throw my 208k 16v to see where its numbers are...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#28 |
![]() Join Date: Aug 2003
dooooo iiiiiit.
Petition Nissan to Make the IDx on http://IDxClub.co ! |
#29 | |
#30 |
These are pretty nice numbers for gains on a KA.
Its know that you can bolt on a 3in exhaust on a stock KA and not see a power loss. That way, if you go the usual route with a 240 (turbocharge via swap or KAT) you dont have to upgrade the exhaust again to get the most out of it. With hondas that was always the problem. You would lose power on a 3ich exhaust regardless of the motor - 2&1/4inch piping was a must. The thing that sucked was that you'd have to upgrade to a 3inch system if you went turbo . . . BUMP for good gains on the KA |
