![]() Join Date: Mar 2002
Trader Rating: (-1)
![]() Feedback Score: -1 reviews
I just replaced my radiator and I was wondering if there is anything I can do with it? The only thing that is wrong with it is that it has a small crack on the right top. Is there any way that it can be used for anything or should I just throw it away.
thanks everybody |
Depends where the crack is. If it is on the fins you are SOL...fins cannot be welded. You can try some stop leak additives.
If the crack in on the tanks you can try JB Weld. That stuff is ghetto but works.
Daily Driver- 91 240 SX SE...S13 Blacktop HKS FMIC, EVC IV, W/G, Racing Suction, DP, Dual Drager, springs/pillow ball mounts Whiteline sway bars Tokico blues Koyo Radiator, Fluidyne fan J30 VLSD stock exterior. Fun Car- 94 FD3S (TO4S). The White HKS FD in FnF......may she rest in pieces. |
I hate you too...
![]() Join Date: Jul 2001
Welding on a aluminum (?) tank is kinda dumb. Aluminum... as I would imagine it is, cuz it will dissipate heat better, is a thin, weak, low heat tolerance metal. Therefore, welding isn't an option.
And as for fixes, you can braze, which is a low heat copper welding, or soldering. I would go with solder. I have soldered 3 holes in a friend's Integra radiator. And even if it is on the fins, so what? What would stop solder from mending it? Solder is not something to put moving parts together with... like don't solder the muffler to the piping, but on a low movement, low heat place, it works wonders. Also.. how long is the crack causing the leak? If it's too long, the structure of the radiator face you're soldering will move too much, and the solder won't work in that case... -Jeff
Whatup? |
![]() Join Date: Apr 2002
Or you can pay for shipping and handling (I have to get a box) and you can have my radiator for free! I just put a Koyo 2-row aluminum radiator in my 89 w/SR20DET...and now I have a perfectly good S13 KA radiator that I don't need. It's not new or anything, but it doesn't leak, and it's never let me down. Works good! Let me know ([email protected]).
Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
![]() Join Date: Jan 2002
put lots and lots of OATMEAL inthere . that should do the trick
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=' ![]()
240SXONE www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx ![]() ![]() |
