Old 04-18-2006, 07:58 PM   #1
RYS13
RYS13's Avatar
RYS13 is an unknown quantity at this point
Filling worn motor mounts
What do you guys recommend using to fill up worn motor mounts? Would a rubber-based sealant work? Thanks.
RYS13 is offline   Reply With Quote
Old 04-18-2006, 08:37 PM   #2
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
3m polyurethane window weld
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 04-18-2006, 08:38 PM   #3
aznpoopy
aznpoopy's Avatar
yeah and you don't really fill them. you slather it all over them.
is that ayanami rei in your avatar?
Old 04-18-2006, 08:42 PM   #4
RYS13
RYS13's Avatar
Yes it is. And thanks for your help.
Old 04-18-2006, 09:06 PM   #5
speedstar01
speedstar01's Avatar
speedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the rough
rei is a very confusing character....evangelion is confusing altogether (maybe someone should start an Eva thread...)
anyway i remember reading somewhere that motor mount repairing supplies can be bought at home depot....
speedstar01 is offline   Reply With Quote
Old 04-18-2006, 09:23 PM   #6
Ritz S14
Ritz S14's Avatar
This topic has been covered many times. Most caulk-type sealent should work. But a lot of people tend to use 3M window weld, because of it's stiffness. There are others that are stiffer, you'd just have to do your own research on them.
I just use bathroom sealent, and it works great. No major engine vibration, nor do I feel it in the cabin either.
Here is the end result:
Ritz S14 is offline   Reply With Quote
Old 04-18-2006, 09:27 PM   #7
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
got tired of the clunk flop clunk wheni start my car. just ordered new mounts from performance nissan. So, i won't be going that route. I know it's been done using the polyurethane caulk.
sncs14 is offline   Reply With Quote
Old 04-18-2006, 09:57 PM   #8
S14DB
AFC #1
S14DB's Avatar
Better off drilling a hole in the side of the mount. In the center of the rubber section.
1)drill the accordion section.
2)drain all the diarrhea looking fluid.
3)heat Window Weld to 170*F
4)inject into mount.
Old 04-18-2006, 10:06 PM   #9
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
some of that industrial urethane designed to fill in concrete is the great stuff.
s14db method of filling in the mount is a very good idea.
If not search some more.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 04-18-2006, 10:07 PM   #10
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
just break down and buy some Syko Performance Custom Polyurethane mounts from me. They are a hundred better than trying to do it yourself with industrial window poly that was not designed for what your trying to use it for.
shameless self promotion here
www.dfreaq.com
New Video
Buy my mounts!
Old 04-18-2006, 11:09 PM   #11
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
I used black urethane caulking on my civic, worked wonders. I've been considering either doing the same to my 240 or welding them solid.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 04-18-2006, 11:53 PM   #12
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
I used the same window caulk as V did. My motor barely moves when I start it. Hardly shakes when I rev it. I couldn't be happier. Only cost me $14 too. You should get a spare set of mounts though. . .because the caulk takes a week to cure, and harden.
