Old 04-29-2006, 06:18 PM   #1
ThatGuy
Admin Asshole
ThatGuy's Avatar
What's the difference between S14 and S15 SR Turbos?
Part numbers and Pictures would help.
Old 04-29-2006, 06:19 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
So folks, I figure that while I'm pink I may as well be useful.
Here's a quick EDU regarding S14 and S15 turbines, and how to tell them apart.
First, here's your part numbers:
'S14' turbo: 14411-69F00
'S15' turbo: 14411-75F00
Here's an 'S14' turbine.
This turbine came on S14 K's and S15 Spec-Rs with automatic transmissions.
Inlet:
Outlet:
Part number:
Here's an 'S15' turbo. These came only on S15 Spec-R with manual transmission.
Inlet:
Outlet:
Part number:
As you can see, they're nearly identical in construction. The face of the compressor housing has the same markings, even.
The housing do have slight differences in their castings, and other small details. The greatest difference between them is the presence of a divider wall in the outlet of the S15 Spec-R MT turbine.
This is the greatest giveaway (besides part number).
Originally Posted by PHLIP
Old 04-29-2006, 06:22 PM   #3
S14DB
AFC #1
S14DB's Avatar
A/R's and wheel trims are the same?
Old 04-29-2006, 06:39 PM   #4
mrmephistopheles
A/Rs are the same.
Wheel trims are also the same as far as I know.
this is another S14 turbine, I'm pretty sure from S14 K's AT.
Here's a reverse shot comparing it to a CA18DET T25 (on the left)
I do not have a part number for this turbo.
The distinctive difference is the 1-1 marking on the compressor face.
Pics sourced from here:
http://www.turbophile.com/our_cars/c...600_specs.html
Old 04-29-2006, 06:40 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Are they both BB? I thought only the Spec-R MT are BB.
CLICK HERE!!!
Old 04-29-2006, 06:51 PM   #6
mrmephistopheles
Actually, I might need to revise this whole thing.
I found this on another forum:
Jap PS13 14411-50F00
AU/NZ S14 (pre-facelift) 14411-75F00
AU/NZ S14 (facelift) 14411-75F00
Jap S14 (pre-facelift) 14411-69F00
Jap S14 (facelift) 14411-82F01
Jap S14 (Autech/270R) 14411-RP801 (Same as S15 early MT turbo)
Jap/ NZ S15 (early*) 14411-91F00 Manual model only
Jap/ NZ S15 (early*) 14411-69F00 Automatic models
Jap/ NZ/ AU S15 late* 14411-75F00 Same as NZ S14 and same for both Auto and manual
and also this (regarding BB or not)
The first number is a batch number, it tells you when/where it was built
The second number is the "oem" number. On a nissan turbo it's a nissan part number, on an HKS turbo it's an HKS part number, on a garret turbo it's a garret number, on a Tomei turbo it's a tomei number etc etc. 14411-69F00 is a nissan part number.
The last number is a chra number. 466541 is a ball bearing cart with a 60 trim 60mm comp wheel and a 62 trim 53.8 mm turbine wheel, 466543 is a brush bearing cart with the same wheels. On this particular turbo the second part of that number describes what turbine housing is used. If it ends in 01 it means the "normal" turbine housing, if it ends in 02 it means the S15 turbine housing with the splitter between the turbine and wastegate exit.
Old 04-29-2006, 06:53 PM   #7
mrmephistopheles
Apparently the IDEAL S15 turbo to have is the early version with this part number:
14411-91F00
This isn't really making sense.
according to that first quote.. The late S15/early S15 automatic turbine is the same as the zenki S14 turbine, which isn't possible as those didn't have exhaust outlet divider walls. Also according to that second quote, the 'S15' turbino I have should be a brushbearing while the 'S14' turbo I have should be ball bearing. For sure the S14 turbine shaft spins better but i figured it was just in better shape...
Old 04-29-2006, 08:50 PM   #8
mrmephistopheles
More fun questions..
Just went to look at the blown turbine on my 180sx. It's a 1-1, so my guess would've been zenki S14, part number 14411-69F00, right?
But it's 14411-TM416.
Old 04-29-2006, 09:27 PM   #9
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
intense analysis....sticky this bitch can we get a detailed analysis of S15 ecu ID codes? i have a "QT" ecu...is this late or early model S15?
sean350z is offline   Reply With Quote
Old 04-29-2006, 10:32 PM   #10
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
is not the S15 turbo ceramic coated, besides being ball bearing VS S14 just being ball bearing? I know my RB turbo is ceramic.
New Video
Buy my mounts!
Old 04-30-2006, 03:58 PM   #11
mrmephistopheles
Dave - there's no ceramic coating... the wheels on your RB turbine (compressor at least) is/are MADE of ceramic. I'm sure you know about their propensity to shatter at high boost.
Old 04-30-2006, 05:06 PM   #12
drift freaq
Ya, I know Kev, actually its not going to matter, because I just upgraded to a HKS GT2535 ball bearing bolt on baby!!
I was pretty sure the wheels in the S15 turbo were ceramic as well.
New Video
Buy my mounts!
Old 04-30-2006, 10:28 PM   #13
mrmephistopheles
forgot to add the pic of the stock S15 piping.
Old 05-01-2006, 06:19 PM   #14
ryangreg
ryangreg can only hope to improve
I ordered an s15 t28 from Performance Nissan Parts in Cali, and what I got reads Garrett A/R 60 M24 1-1 on the compressor housing. Garrett 0.64 on the turbine housing. The badge in the center section reads...
IL 0105J
14411 91 F00
466541-4
Did I get an s15 turbine, or is PNP taking me for a ride?
ryangreg is offline   Reply With Quote
Old 05-01-2006, 07:44 PM   #15
mrmephistopheles
IL 0105J
14411 91 F00
466541-4
You got an S13 turbine. I'll buy it from you for $200
You must've missed this post:
http://www.zilvia.net/f/showpost.php...83&postcount=7
That's the ideal S15 turbine.
Old 05-01-2006, 08:05 PM   #16
ryangreg
^^ what exactly do you mean? Please tell me that you are joking.
Old 05-01-2006, 08:36 PM   #17
S14DB
AFC #1
S14DB's Avatar
$250 final offer
Old 05-01-2006, 08:43 PM   #18
sean350z
sean350z's Avatar
Can you help with ECU IDs for S15s
I've seen:
NA
QT (mine)
Old 05-02-2006, 12:37 AM   #19
mrmephistopheles
Holy crap, man, READ!!!
You posted the part number that I'd already stated is the 'ideal' S15 turbine.
by adding these , I'm joking. I thought I wasn't being anything less than completely obvious, but I guess I was wrong.
Old 05-01-2006, 07:16 PM   #20
S14DB
AFC #1
S14DB's Avatar
Courtesy Parts has one too
http://www.courtesyparts.com/Merchan...ode=SR20DET-TC
