Old 05-04-2006, 08:32 PM   #1
kickboxin
kickboxin is an unknown quantity at this point
s13 with rb swap for sale
I am thinking about selling my s13 this summer and go back to having one car for now. I am located in a suburb of Chicago.
1989 240sx/s13 18x,xxx
grey on grey
Some rust here and there but not bad... can use a little body work and paint
Engine:
R32 rb20det
Top Hat engine mounts
Top Hat intake plenum
Front mount
Adj fuel pressure regulator
Walbro fuel pump
k&n intake
Koyo Racing Radiator
Dual 10" fans with aftermarket thermostat
Suspension:
KYB Agxs (adjustable)
Cheap springs from ebay
Racing max? 17x9 wheels
Dunlop sp9000 (fr: 235 / rr: 255)
tanabe rear tension
Aftermarket rear upper & traction
C's? Lower rear brace
TF front tension rod
Aftermarket front lower brace
Rear subframe collars
c's front and rear upper strut bars
Trans:
Short shift
xtd stage 3 clutch
180sx vlsd
Electronics:
Greddy boost, oil pressure and water temp gauges
Greddy profec b spec 2 boost controller
Greddy turbo timer
HKS Super AFR fuel control
Remapped ECU
Working tach.. hehe...
Misc:
Z32 front brakes / 180sx rear brakes
Has power steering
JDM s13 seats (180sx or silvia.. i dont remember)
Better headlights
I think that is it.. could be a good drift car too..
To be noted:
I have j30 diff to swap in since the 180sx is whining.
Front passenger side caliper is leaking, I just ordered a replacement
I have a rb25 turbo that can be swapped in
The turbo timer, boost gauge and egt isnt installed yet.
Price: $6000 obo
Here are some pics:
would consider trades for 97/98 s14 stock, sc 400, or c70 also 93+ supra na or m3 if the price difference isnt too bad.
kickboxin is offline   Reply With Quote
Old 05-04-2006, 11:48 PM   #2
keroto
keroto is on the path to ruinkeroto is on the path to ruinkeroto is on the path to ruin
i give u 2k for it
keroto is offline   Reply With Quote
Old 05-05-2006, 12:50 PM   #3
kickboxin
Originally Posted by keroto
i give u 2k for it
Ahh noooo....
Old 05-06-2006, 07:53 PM   #4
keroto
Originally Posted by kickboxin
Ahh noooo....
plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old 05-06-2006, 09:01 PM   #5
kickboxin
2k maybe with a nice trade.
Old 05-06-2006, 09:53 PM   #6
keroto
i have a 1994 rx7, but that will mean u have to put some cash on it. if u think u want to trade shot me an email [email protected] i will send u some pics and more detail.
Old 05-15-2006, 12:16 PM   #7
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
I'll give you $500 for your 94 rx7!!! PLZZZZZZZZZZZZZZZZZz
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 05-10-2006, 09:04 PM   #8
kickboxin
I may have a lead on a driveshaft so I might be able to swap out the lsd.
Old 05-15-2006, 12:04 PM   #9
kickboxin
Swapped out the diff this weekend.. What a pain. The whine is now gone. The diff was from a j30.
Also I put the boost controller back in and the turbo timer is in. It still needs to be programmed. Also the gauges were put back in the flat panel.
Here is a pic.
