Ac Setup With Redtop
Hey Im gonna use the ka ac assebly to bolt into a s14 with a redtop in it the way that it is explained in this thread. http://forums.freshalloy.com/showthr...light=Official
Now what all parts from the ka will I have to buy to make it work? I dont have any ka parts for ac. Or would it be easier to just get custom lines? I just dont have either the sr or ka lines and they have been hard to find. Thanks |
![]() Join Date: Dec 2004
Trader Rating: (58)
It's a bad link but you have 2 options:
1: Get a clutch and pulley from a 95/96 Pathfinder with the 3.3 in it or Do what I did: 2: Custom AC Bracket. I made it out of steal, and moved the ac compressor forward (to line up with the pulley) and down (to clear the bracket). I couldn't be happier, as after the SR install tonight, even the stock AC lines fit ![]() ![]() ![]() ![]() ![]() ![]() ..and a little inside joke with some friends : ![]() http://www.e-rak.com/cody/gallery/album243
#3 | |
![]() Join Date: Feb 2006
![]() 1999 Honda Civic Hatch EK9 N/A b16a2 (SOLD) ![]() |
#4 | |
What about the tensioner? I like your idea for custom brackets but that totally eliminates the A/C compressor bracket and the tensioner is attached to it |
#5 | |
Trader Rating: (58)
![]() Not to sound rude, but re look at the above pictures I took and at your setup ![]()
#6 | |
Damn it. Im an idiot. Thanks dude. I think I will fab up some brackets like that this weekend. |
#8 | |
Trader Rating: (58)
Thats what I said too. Living the northeast, I made it a point to have full working heat, defrosters, powersteering, and air conditioning ![]() I know it gots much hotter temperature wise in the Southwest...or say the Sandbox(I spent a 2 weeks at NTC at Death Valley in July, and a year in OIF), but NOTHING can compete with the humidity here! And, in all reality, you're not loosing that much power from the stuff (not that it would matter anyways)
![]() Join Date: Jun 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
ive been thinking about a/c from time to time in this 90+ degree weather since i usually dont drive when it is that hot or have a friend with a/c come pick me up.
![]() Join Date: Jul 2001
Is there some reason you can't use SR AC parts?
I'm S13, so maybe I'm just misunderstanding a logistical issue of some sort? But I used all stock SR parts and just had custom lines made so I had more flexibility in my engine bay. That bracket is so simple, yet damn slick, good job codyace |
#13 | |
Thanks! |
#15 |
well i cant use my sr parts cause i dont really have any of them except for the compressor. Also my compressor was never sealed when the install was done so thats probably faulty as well.
#16 | ||||
Trader Rating: (58)
Thanks for the kind words! I too got frustrated at looking all over 3 different forums for a solid answer, so I decided to take action into my own hands! I was seriously about 10 minutes from just slapping on the SR compressor, and heading to a Freightliner dealer that our shop deals with to get the lines made up...
Check for your quote for your answer ![]() Quote:
I will however be dipping into the idea of making a lower one as well when I have more free time. Quote:
![]() Quote:
Thanks for the props too...In our garage we've got a little saying for stuff like this: "No use re-inventing the wheel". Quote:
As for the bar of steel itself, I just took the edges of it to the grinding wheel to smooth them out and finish it. I hope this helps for you guys! Now you have no excuse to cruise around with your windows down and your chicky wondering why your car doesn't have A/C hehe....
#17 |
Trader Rating: (58)
Also, with this bracket, I didn't need to bend the A/C line AT ALL, and it also clears my stock manifold+gt287r WITH my custom actuator bracket as well...
#20 | ||
Trader Rating: (58)
![]() Quote:
#21 |
Why was a bracket needed for the KA compressor? The two front bolts bolt up perfectly. It even lines up to the belts. The only thing I did was grind down the AC bracket, The KA pully actually hits it. Then bend the lines alittle becaue it's in the way of the intake. That's what we did on Squidd's car. runs great.
I have an sr compressor on my sr20 and i'm going to be making custom low pressure lines. Only one line bolts up correctly. the other line from the firewall doesn't line up. Get the Sr end that bolts on the compressor, then mate it with the KA line.
![]() driftingisgay.com |
#22 | ||
Trader Rating: (58)
My setup is s13 redtop in a 1997 s14. Quote:
#23 |
http://forums.freshalloy.com/showthread.php?t=103266
KA24DE AC compressor bolts up to S13 SR and S14 SR. Red or black top doesn't mater. the bracket is different, but bolts up fine. only the two front bolts goes on. DOHC car, one lines bolts up to SR AC compressor. This is why most make custom lines instead, it's not even that hard actually. tons of people have comfirm this. it's old news too heh.
#24 |
Trader Rating: (58)
That is a great thread, and in fact that is also what helped me in deciding to make the bracket (like the One Ton Garage one)...
I guess it all comes down to what is easiest at the time. Being that I have the ability to use steel/aluminum from our shop to fab up things, I've always found it easier to custom make things... Plus, if I used the SR compresssor, I'd be to tempted to use some of the R12 we have for older trucks instead of converting it to 134a ...
