Old 07-31-2006, 04:54 PM   #1
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
Not building boost
My SR won't build any boost whatsoever...and I can't seem to find a leak anywhere. Also, my boost controller (I don't have a boost gauge yet. ) is reading all over the place under acceleration. I'm reading about -9 psi of vacuum (about 18 mmHG correct?...sorry can't remember how to convert it) at idle. Under acceleration it starts to build boost, but when it gets around -6 psi or so it stops increasing but will read all over the place from -4psi to -9psi...it just won't build any boost. Any suggestions of possible causes or culprits...I'll keep looking for a boost leak; but I haven't found one yet and I've tightend up and checked all my IC piping and vac lines...hasn't made a difference. Thanks in advance!
Turbo setup is: Redtop SR (T25)
FMIC
Blitz BOV
Greddy PRofec B Spec II
mRclARK1 is offline   Reply With Quote
Old 07-31-2006, 04:57 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
Do the pressure tester on your IC piping.
And also, are you using stock wastegate? Sounds like the actuator is all fuct.
Old 07-31-2006, 05:10 PM   #3
mRclARK1
mRclARK1's Avatar
Yeah, it's the stock actuator/wastegate. I checked it out before I started up the car and it seemed to be working fine. I can hear it open when I apply vacuum to it, and I can open it by hand...so I don't think it's seized. But I'll give it another check.
Old 07-31-2006, 10:06 PM   #4
mRclARK1
mRclARK1's Avatar
Well I took it out for a drive again, after tightening up IC piping etc. again...and it's still doing it. But it's getting better. I am building up some boost now. So I must just have a leak somewhere I missed...I'll post again if I can't find anything after another good check.
Old 08-01-2006, 12:10 AM   #5
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
an easier way to find those leaks... run to home depot find some pvc pluming with a cap, epoxy a valve stem from an old bike tire in the end and tighten it with one of the couplers... pump it up to 15-20psi and listen for leaks
nsn240 is offline   Reply With Quote
Old 08-01-2006, 02:25 AM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
Yah, even if you don't think you have a leak.. DO THE TESTER ^^
thats how I found my leak..
Old 08-01-2006, 06:52 PM   #7
mRclARK1
mRclARK1's Avatar
Yeah...I've been meaning to do it anyway. Especially now since I'm having problems; I'll get it done ASAP. Thanks guys.
Old 08-02-2006, 12:15 AM   #8
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
how about the bov is it leaking/stucking you think. try capping off the bov somehow or using someone elses.
Zzzz
bongnak is offline   Reply With Quote
Old 08-02-2006, 12:28 AM   #9
fico
fico's Avatar
fico is an unknown quantity at this point
Send a message via AIM to fico
All I know.... boost controller + no boost gauge = BADDDDD
fico is offline   Reply With Quote
Old 08-02-2006, 02:38 AM   #10
NemeGuero
No more nissan.
NemeGuero's Avatar
Why? I don't agree.
Old 08-02-2006, 05:16 PM   #11
mRclARK1
mRclARK1's Avatar
I'm using a Greddy profec B specII...it reads boost/vacuum while you drive. So it IS a boost gauge as well...I just want a mechanical one to make sure I have correct readings...and have it in an easier to see spot.
I still gotta do the pressure testing on my IC piping, and I fiddled with the boost controller settings a bit, that improved it as well. I guess it just needed some fine tuning from my previous settings. And I may still have a leak somewhere...I'm gonna check ASAP.
