![]() Join Date: Sep 2005
IACV Question. Need Help! fucking car wont start!!!
I sprayed Carb Cleaner through the tube that leads to the IACV and now my car is having a hard time starting. ive done this before and after a few tries the car would start. now ive tried about 10 times and nothing.
please i need suggestions thanks. Last edited by Bigballin; 10-09-2006 at 01:48 PM.. |
wont crank just keeps trying to. i remember something like this happening to a friend when his injectors flooded his engine.
by the way my car is completely stock i was just trying to cleant hat fucking IACV |
![]() Join Date: Jun 2003
shouldntve flooded anything, carb cleaner evaporates really fast, MAYBE the carb cleaner dissolved somthing in the iacv that got clogged somwhere else, but i doubt that would keep it from starting..
#6 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
keep trying it a few times, and if it doesnt start, then wait a few hours and try again, it shouldnt not start for that long of a time since its only carb cleaner, unless you left or made a vacuum leak in the process.
Slip Gypsies Blog Quote:
#8 | |
i tried again to start it this morning no luck. im really hoping something didnt seize up. anyway more ideas. anyone? can i try cranking it for a couple of minutes or will that damage something?
Take all your spark plugs out and then crank it over, this should clean all your cylinders out. If its full of gas to the point of being hydro locked you might want to check your injector seals. If nothing comes out, you should check for power to your starter.
well nothing came out and when i tried to put the spark plugs back and start it the starter kind of sounded like it was losing power.
im i fucked here? im getting the errors from my ecu 15: fuel injector clogged 25: IACV help please Last edited by Bigballin; 10-10-2006 at 10:53 AM.. |
is it slowly cranking?
is it cranking and does it get faster or slower? check for spark and fuel pressure or just listen if your pump is hissing. if all that passes check your compression. |
#14 |
it cranks but it gets slower. i think my injectors are clogged and it cant get fuel to start
can i buy feul injector cleaner or is there a better way to clean the injectors? |
#15 |
injectors are cleaned except the number 3 injector (the screw was stripped) checked my ecu codes and its ready that everything is ok.
try to start the car and it gets slower.... Last edited by Bigballin; 10-10-2006 at 03:21 PM.. |
