Gauging interest - EVO 8/9 Twin scroll Turbo Exhaust Manifold
Hi.
I am having a shop make me an exhaust manifold so I can get a evo 8/9 twin scroll top mounted on my car. I know exactly what these turbos can do. I have an HKS gt-ss sitting around with cams and more waiting to be installed but due to the fact that I have a spare longblock they can work on I will wait and see what can be done. There is a thread on FA regarding this exact issue and it generated a lot of interest. I even had my friend contact full-race about them doing this but they require, as they should, the car to be at their location which for me is not really an option. The shop making this is manufacturing and exporting many xhaust manifolds for EU cars and hondas. They only use thick SS of the higher grade which I cant recall what it is at this time. the manifold will be constructed to keep the true twin scroll functionality otherwise it will not be worth the trouble. The shop does not mass produce. They are very quality minded. So who wants a twinscroll turbo with amazing spool up and near 400hp capability for their SR? Just to let you know, if you do not, a new EVO 8 turbo costs just $549!!! An EVO 9 turbo with 10.5 turbine housing upgrade is only 899$!!!! I do not think that can be beat, as far as turbos go , for spool up and power potential all in one. I would go for a Evo 9 turbo since it is better in every way. Tell me what you think. Last edited by JohnC; 10-24-2006 at 04:09 AM.. |
This would be a fun option. You could possibly bolt up the evo 6 TME turbo as well as its basically the same design except it has a few features like titanium impellers and such. These have relatively low mileage used as well and offer great potential. I am sure they could be had used for the 450+ range
Hmmm, I think yoiu might be onto something |
I have an evo 8 turbo with 2k miles and a new evo 9 turbo to choose from.
Since the evo 9 already has better spool up and flow up top I will probably be using that. I would rather get a new turbo at this point. I can always upgrade it to TME later or just buy a new one with that option and sell my stock one. Thanks for the suggestion. The guy on FA that started this deservse the credit for thinking about it. Thread is here: EVO VIII twin scroll turbo on an SR20DET. Pictures on the last page are on a CA shouldnt be much of a difference. |
#5 | |
![]() Join Date: Feb 2002
I'm going to say 'no' because he doesn't have the KA where he lives.
Goals are dreams with a deadline. L.H.O.O.Q. |
![]() Join Date: May 2006
well i was reading and following up on this if those turbos from the evo 8 and 9 is able to produce anywhere from 300 to 450 hp. the madgnitude of the spool up evo 8 and 9 turbo would compare to as what to the turbo's you've seen to the bolt on's we buy. what is the difference.
Correct, this will be for the SR20DET.
The spoolup will should be right about where the s15 bb spools up but the response should be better and yes 400hp on 93 is a posibility. I do not know of a turbo that spools like a s15 and has power output ability of an 2871 with .82. If such a bolt on turbo exists, please let me know. I am not being sarcastic but truely asking. I have had my fair share of turbo charged cars over the past 13 years. every twin scroll equipped car I had was amazingly responsive. I had the STI Spec C turbo on my wrx. The setup gave me the power of an STI turbo with the low down spoolup and response of the stock wrx "mini"turbo. As for the EVo turbos, all I can say is get in an evo 9 with some bolt ons and feel what I am talking about. Boost on demand really exists with that setup. Yes it is the complete package that makes it so responsive but I am not just doing the turbo. The cams are being upgraded, the HG will give a 8.75 CR and the header will be made to fully utilize the turbos twin scroll fuction. Think about it this way: Full race mani- atleast $900 (worth it, even have one on the way for the evo). GT2871 - atleast $1000. This will get you to the same peak power levels but in no way will you be close to stock spoolup and lowend responsivnes of the t25 or s15bb. Evo 9 turbo - 900 and even less. Exhaust mani - let us say $1000. (not a real price , just to keep things "even") add oil water lines and a couple of custom pipes for a couple hundred more. Now, would you spend a few more dollars to retain bottom end response with a proven 400hp capability of the evo 9 turbo? I am. :-) If outright power is all one wants, just buy a bolt on , bigger turbo aand your done. If one want best of both worlds, this might be the way to do it. I will be dynoing the car with current setup. I will dyno the car with poncams and HG. Then I will dyno the car with the new manifold and turbo. If this works I beleive this will be a great setup. If not, well I will just put my HKS GT-SS in with the tomei manifold I have and be done with it. |
Id be down. With all the bolt ons the evos are still putting down around 350awhp right? or is it around 380 with the cams? if using a good equal lenght manifold and greddy or similar style inatke manifold you think itll produce around 400? or the turbo alone without the intake manifold and cams?
Edit: also dont the evo guys run around 26 psi for that kind of power? Im pretty sure they have stronger internals and I would not want to push that many pounds to achieve that kind of power. |
#11 | |
![]() Join Date: Sep 2005
I think after selling my SR Hatch in May it's time for a new beast. |
![]() Join Date: Jun 2003
I have been thinking about this for a while now for my CA, sounds like it could be cool if done right.
![]() Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
#14 |
My friends Evo 9 with just exhaust, filter and tune
puts down 403 hp on 93oct and that is at 1.5-1.6 bar. 21-23 psi. keep in mind that drivetrain loss for the evo is around 23%. That translates to roughly 310awhp. Push 23 psi on the same turbo, theoreticaly creating the same power, on our cars and the translates to 333whp assuming a 17% loss. To achieve the same whp figure as the evo you will be running around 19 psi. The evo 8 will not produce the same hp figure at same boost pressures. Smaller turbine housing, no MIVEC, and a different cam layout all contribute to around a 10% less power at the same modification level. Evos run 19psi stock? I have an 8 and it was around 16 psi. The 9 was also 16 psi and I have been in about 15 evos with different mod levels. But pressure as we know is not the whole story. the evos ignition maps are very retarted and the fuel map is very rich. One friend kept 1.2 bar as his boost level and just playing with the maps, on evo 9, had a 50hp increase in hp with just an exhaust and tune. |
#15 | |
#17 |
Thats what I thought above as well?? Been around evos for a while and I thought it made around 19 psi and tappered off to 16 or less around redline to liability and engine 'reliability'?? But, lets not talk about that. Everyone can look it up on the net (look at Sport Compact Cars' project car garage)
Quick question John, how do you equate those numbers considering that two engines have a bit different spec (bore, stroke, head flow properties, etc.)?? I guess thats more of a ball park figure?? But keep this thread alive!!! |
#18 |
The two engines being different is a factor that we are taking into account.
flow will be changed by installing poncams. Different stroke has come up in conversations with an engineer but The best thing will be to wait and see. I am hoping for the best but only real numbers will tell the story. Chibo, Is you EVO 9 completely stock? I am sure we agree that 19psi on a tuned, freeflowing exhaust equipped car will produce more power and tq then a stock one.. 23psi on a 9 turbo is daily practice for tuned Evo so You will not really be pushing the turbo too much. |
#19 | |
#22 |
Pricing as Ralliartrsx said will depend on the components.
No pricing yet but it will be available as a kit which will include The Header, Turbo, water/oil lines, Intake pipe, hot pipe, elbow and downpipe. The biggest unknown is the pricing of the manifold. For the other components you can use references from other products being sold individually. You can get the compnents made up by yourself and maybe save a little. |
