Old 02-16-2007, 03:28 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
Turbo elbows: Tomei-vs-Greddy-vs-Megan
I am trying to get the rest of the my parts together for my SR swap and now it has come time to figure out what turbo elbow to get. From what I have gathered the megan one is a single opening, where as the Tomei, Greddy and Circuit Sports one have a divider in them. What is the purposed of the divider? What are the performance differences between them? Does the divider for the wastegate help out with overall exhaust flow? I don't mind spending a little extra $ for a better product. So help me out if you can.
khilgers is offline   Reply With Quote
Old 02-16-2007, 03:34 PM   #2
samplesurf
samplesurf's Avatar
samplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to all
go with the greddy, ive had 2 and never had problems with either, had a megan once and it cracked so im not a fan of the 1 piece design, as for the divider it seperates the gasses from the wastegate and turbine wheel creating less turbulence, and the greddy has that also
samplesurf is offline   Reply With Quote
Old 02-16-2007, 03:38 PM   #3
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
i'm thinking it's better with the divider, helps air flow and such, but then again, i'm no engineer,
only problem you may encounter with the divider is if you have a s15 t28 that has a divider, kinda need to bend the elbow divider to fit...
Wei240 is offline   Reply With Quote
Old 02-16-2007, 03:42 PM   #4
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
s15 turbo just chop the divider so its flush with the mating service. go with either greddy or circuit sports. circuit sports if you're on a budget
i have the circuit sports one piece elbow-downpipe; works great
kensreliableb18b is offline   Reply With Quote
Old 02-16-2007, 03:49 PM   #5
RISINGSUNPROJECTS
RISINGSUNPROJECTS's Avatar
RISINGSUNPROJECTS is an unknown quantity at this point
Have used both Kazama & Tomei elbows...Both are pretty much identical design, both straight thru no divider. Work really well!
They think I'm slow because I'm from Canada Eh!
RISINGSUNPROJECTS is offline   Reply With Quote
Old 02-16-2007, 03:48 PM   #6
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
i've got the greddy one, and im running a s15 turbo, and it's fine, but as stated above if your on a budget then go with the circuit sports, if not then i'd go with the greddy
Slip Gypsies Blog
not sure if you realize this
Old 02-16-2007, 04:00 PM   #7
khilgers
So if a high end company like Tomei or Kazama DOES NOT use the divider then there has to be a reason, correct?
Old 02-16-2007, 04:16 PM   #8
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
Yes and no. For probably 99.99% of we Zilvians, we'd never notice a difference between an elbow that has a divider and an elbow that doesn't. The idea behind the divider makes sense, to a degree, but exhaust gas flow is always going to be turbulent. At the flow rates when the wastegate is opening (i.e. high rpms), I doubt that the the high rate of the main exhaust flow will be disturbed by gas from the wg opening. Of course, I have not tested either pipe, that's just my speculation as an engineer. Take it for what it's worth.
Personally, I like the Circuit Sports combo pipe, because it widens and flattens out in the middle, allowing for ground clearance for lowered vehicles. I will probably go for that pipe when I'm in the market for one.
S13 Charlie is offline   Reply With Quote
Old 02-16-2007, 04:21 PM   #9
kassed33
kassed33 is an unknown quantity at this point
s14
i have a Garrett 2871r on my S14 motor and i'm using a Greddy elbow. The purpose of the divider is to give you better exhaust flow, with out it the 4 exhaust pipes from the manifold just come to one big opening into the turbo, then compressed and either recirculated into the intake or out the exhaust. The spliter in the elbow will allow the compressed gas to eaily and smoothly flow out the exhaust pipe.The easier and faster and the more in and out flow you get the more power you get. Hope that helps ya in your decision, i've gone with just about All Greddy and Trust products and have nothing but good things to say about them...you cant go wrong with them.
josh kassed
kassed33 is offline   Reply With Quote
Old 02-16-2007, 04:40 PM   #10
khilgers
Charlie, yes that all makes sense to a certain extent. Like you said most of us would not notice the difference on a mildly built street car. I do like the elbow/downpipe combo, but I already have a downpipe. So it looks like I have a much better idea of what I am dealing with, thanks guys.
Old 02-16-2007, 06:40 PM   #11
Flybert
I have the greddy with an s15 turbo and it has to be cut to clear the built in divider on the turbo. I haven't used the circuit sports one but that seems to be the best one in my opinion. It's cast and looks to have more clearance to get the bolts on there.
Old 02-16-2007, 07:07 PM   #12
big_schaf
big_schaf's Avatar
big_schaf is on a distinguished road
i have a hks elbow and its a single as well...i recomend it it's built really strong
90 s13 dd, 90 s13 track, 90 ae92 winter
big_schaf is offline   Reply With Quote
Old 02-16-2007, 10:17 PM   #13
PoorMans180SX
PoorMans180SX's Avatar
the divider is trying to make an internal wastegate design more like an external one. Ideally, the divided section would be 10-12 inches long and smoothly integrate back into the exhaust.
Old 02-17-2007, 12:55 PM   #14
Crono562
Crono562's Avatar
Crono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of light
circuit sports
Go with the circuit sports one piece, its good quality and it has a better ground clearance then the others due to its flat design. Plus its a lot cheaper! Can even get one from off ebay, just search for 'askme4parts', I know he has one for sale and I can vouch for his service.
*Edited to remove ebay link, sorry about that, didnt know that rule.*
Mikey "Whitey" Ernst
'www.justdrift.com'
Crono562 is offline   Reply With Quote
Old 02-17-2007, 03:57 PM   #15
GSXRJJordan
GSXRJJordan's Avatar
The big problem with the Circuit Sports combo pipe is that it doesn't have a flex section. I love the fact that it gives better ground clearance, but no flex section = more stress on your turbo->manifold studs (I broke 2 sets before I learned why flex sections are important).
Also, ebay link posting is prohibited, just post up search words that will help the OP find what you're linking to.
I have almost everything Megan makes for the S13 (worked at a Megan sponsored shop, got it free), and I have to say, it's not bad. I dont use the coilovers, but on all the engine/chassis stuff, it's well made and they've always given me great support whenever I had a problem.
Old 02-17-2007, 04:03 PM   #16
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
I had a tomei and that was 3 inches (oval) all the way through. When I looked at the greddy and megan racing they seem to be a little smaller on the top side. I would go with a tomei.
mayco_86 is offline   Reply With Quote
