Old 03-11-2007, 03:19 AM   #1
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
SR Question about injectors/FPR
Ok so I plan to run about 500HP later down the road but right now I'm just going to run the stock turbo at 15psi for a while. I'm running an s13 redtop with a haltech ecu(e8) and a walbro 255. Should I get a nismo fpr to handle the pressure or should I choose a different FPR? I'm thinking either 740cc or 850cc injectors. The question is should I go with side feed or top feed injectors. Also peak and hold or saturated? I've read about both and am still totally confused. I know with top feed I need a new rail but they are also cheaper. Is there any down side to topfeed that would make side feed better? And would I need a different fpr with the new rail? Thanks for answering my questions in advance .
rocksteady_racer is offline   Reply With Quote
Old 03-11-2007, 05:13 AM   #2
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
i would say go with a adjustable fpr.
what motor are you running? 500hp sounds kinda high if you only have injectors and fpr
i would say change your cam and rebuild head and head gasket. with slightly bigger injector then get wideband and tune it.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 03-11-2007, 07:33 AM   #3
oki_dorifuto
oki_dorifuto is an unknown quantity at this point
you really don't need an fpr since 850cc injectors will give you all the fuel you need to make about 500 hp... stock fpr is completely fine... but its going to be hard to tune with 850's in a car only making 300 hp (thats only what im estimating you have)
and bo20 it sounds like he doesn't plan on making 500 hp with just injectors and fpr... he says it will come later down the road
oki_dorifuto is offline   Reply With Quote
Old 03-11-2007, 03:58 PM   #4
rocksteady_racer
SR Ok good points
Yes, I'm going to start out with the stock turbo for at least a couple months to get down driving with that then upgrade to a more powerful one. I've already got the head rebuild planned also. I'm probably going to use the haltech wideband kit to tune it since it'll plug right into my ecu. Now the bigger question: side feed or top feed? Anyone have any insight on that?
