Old 03-25-2007, 11:31 AM   #1
sr20tom
sr20tom's Avatar
sr20tom is an unknown quantity at this point
SR Power FC install moonlanguage help!
Ok, the intake air temp sensor has two wires, brown and red. The pinout in moonlanguage leads to the top wire that is black and the bottom wire that is teal. I am afraid to connect it the wrong way. What wire goes where? my first guess is black to brown but that is a $1k GUESS THAT I DONT WANNA TAKE. Thanx
91 SRtweezy powered sil-80
sr20tom is offline   Reply With Quote
Old 03-25-2007, 01:14 PM   #2
rockinpandas
rockinpandas's Avatar
rockinpandas has made poor choicesrockinpandas has made poor choicesrockinpandas has made poor choicesrockinpandas has made poor choicesrockinpandas has made poor choicesrockinpandas has made poor choices
looks like japanese to me
rockinpandas is offline   Reply With Quote
Old 03-26-2007, 02:43 AM   #3
RACETUNE
RACETUNE's Avatar
RACETUNE is on a distinguished road
Send a message via AIM to RACETUNE
you will be fine, the way you think is the correct way to hook it up, its just an temp. comp. input. well anyway good luck with the D-jetro.
-Garage BOSO-
-Racetune Engineering-
RACETUNE is offline   Reply With Quote
Old 03-26-2007, 10:10 AM   #4
johngriff
johngriff's Avatar
Just to clarify. You are tapping into a ground, and sending signal into the PFC via a cut wire.
The wire you are cutting into is the EGT, which is not used 99% of the time, which makes sense for apexi's utilization. I am guessing the air temp loom was pre crimped? It should have been new. The butt connector goes into the Blue/yellow wire, in the lower row, and the striped wire taps the black ground.
Man this looks like sooo much fun!
[email protected]
Old 03-26-2007, 01:14 PM   #5
steve shadows
steve shadows's Avatar
on a side note:
make sure the ground on the battery is pulled off while installing the unit to the harness. then...tighten down the 10mm and put the ground term back on.
this is per apexi suggestions.
Like Me on FaceBook !
