Old 04-03-2007, 10:39 PM   #1
Jason240sx
Jason240sx is on the path to ruinJason240sx is on the path to ruin
Car tire setup
hi all if i were to run 18x9 wheels and i use the car for autocross/track
is it better to go with 225/40/18 all around or should i put it as a staggered setup like 215/225 fronts with 235/245 rear?
really appreciate those with track times on different tire setup thanks a lot
Jason240sx is offline   Reply With Quote
Old 04-03-2007, 10:46 PM   #2
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
If you're autocrossing or track racing and you want to be competitive, I don't think 18" wheels are for you.
That being said, I'd prefer an "all around" setup for autoX and a staggered setup for the track. If for both, I'd do the same size all around.
Opinions opinions. It all depends on how the rest of the suspension is set up.
Chernobyl is offline   Reply With Quote
Old 04-03-2007, 11:05 PM   #3
OptionZero
OptionZero's Avatar
both setups suck monkey balls, why would you go with so little rubber
Lose the 18s and run 17x9 w/ 245/40/17 on all 4 corners
Old 04-03-2007, 11:06 PM   #4
Jason240sx
OptionZero: in your sig are u running 18's or 17's? they're very nice
i run coilovers on the car , just wondering is it necessary to roll/pull fenders? or people do the roll/pull just to slam down their car more?
on the s14 wheel gap it looks like 18's will just make them look better? like 17's just look a lil small , want to be competitive and look good on the car as well =)
thanks for the info guys.... 245 sounds like a lot of tires on a stock KA
Old 04-03-2007, 11:24 PM   #5
OptionZero
OptionZero's Avatar
you need to do far more searching about wheel fitment and performance in general
looks are subjective, so i can't comment, but 245 is not too much for a stock KA
those are 17x9 in the sig
Old 04-03-2007, 11:45 PM   #6
Jason240sx
i found several wheel fit ment threads but all are just pictures nothing mention on the need to roll/pull fenders and quarter panels....
anyy keyword help will be appreciated cause those i tried never came out right
Old 04-04-2007, 12:26 PM   #7
ronmcdon
ronmcdon's Avatar
you may have searched, but you're not really looking meticulously enough. the fact that you did not list your offsets (very important detail), leads me to believe you could benefit from further research. Check out ths link please; Note, that the things you ought to be looking for are;
-width of wheel & tire
-offsets (spacers should be taken into account)
-any fender modifications
-whether or not full coilovers and/or z-brakes/other big brake kits are used.
http://www.zilvia.net/f/showthread.php?t=129865
while it will not give you a precise formula per say, it will give you a fairly comprehensive list of what will work, and how it ends up looking. its an awesome resource that imo everyone should consider when planning their wheel/tire setup.
for regular track driving, i myself dont like stretching tires too much, but thats just my personal preference. running on 17x9's, id go no lower than 245's.
Old 04-04-2007, 01:16 PM   #8
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
What class are you planning on running? I'm going to guess STS, but if you're DSP or SM then you can pull fenders (STS only allows rolling the lip, AFAIK).
I run 18x10 and 18x12 with 285/30/R18 and 315/35/R18 respectively. The 17's have a larger rolling diameter in every R-compound size....
On a 9" wide wheel, though, you'll want at least 245's.
AceInHole is offline   Reply With Quote
Old 04-04-2007, 01:00 AM   #9
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
first off, what are the offsets of the rims..that will say a LOT.
Second- if you want any grip, 245 is not too much for a stock ka. I'm running a very stock ka on 255 fronts and 275 rears on 18x9.5 rims.
gotta240 is offline   Reply With Quote
Old 04-04-2007, 01:27 AM   #10
OptionZero
OptionZero's Avatar
rolling your fenders is easy
fitment always depends on camber, height, tiresize, and offset
Turdz put 245/40/17 on 17x9 +22 on stock height and untouched fenders
on freshalloy, Kookz put 245/40/17 on 17x9 +15 on stock fenders, slammed to the ground, with a roll and camber IIRC
have you tried searching "wheel fitment"?
i highly doubt you'll be buying wheels so aggressive that they'll require a pull
go to the group buy section and get some MB's to beat on
Old 04-04-2007, 11:54 AM   #11
Jason240sx
u dont need to send to a shop to roll fenders?
yea the wheels im thinking to get is from the GB so if 17's it is +17 and 18's is +15 . dont really want to slam it down but put 1 finger grap all around.
Old 04-04-2007, 12:02 PM   #12
aznpoopy
aznpoopy's Avatar
you need a torch and a baseball bat
or a heatgun and a fender roller
no reason not to do it yourself. unless you're lazy i guess.
1 finger gap may not be zilvia slammed but its pretty damn low.
what kind of suspension modifications do you have? is your car an s14 or s13?
Old 04-04-2007, 01:23 PM   #13
McRussellPants
Ha Ha.
Autocross cars.
McRussellPants is offline   Reply With Quote
Old 04-04-2007, 02:49 PM   #14
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Here is 17x9 +20 with 245-40-17s all around... On an S14 you will have more clearance...
If you want to have fun with your car go with 17s and 245s.... If you want to look good to your friends then go with 18s and 225s and slam the car as low as possible...
And here is one way to roll your fenders... Don't be scared to get your hands dirty and try it out...
http://www.youtube.com/watch?v=DDTK9IjKIYU
Nikeboy355 is offline   Reply With Quote
Old 04-04-2007, 04:46 PM   #15
aznpoopy
aznpoopy's Avatar
Originally Posted by Nikeboy355
lol.
i love how he just sprays that shit over like whatever.
