Old 04-08-2007, 11:28 AM   #1
RpSinner
RpSinner is an unknown quantity at this point
SR sr20det vaccum line help AGAIN
just did a swap but im having problems getting any power while in boost. i can drive around ok under 4k just not in boost. i know i am boosting because the bov is going off. however while boosting i hear the bov hissing so i think im leaking boost. i swapped bov's but that did nothing. i checked my vaccum lines and they are fine.
i have a greddy intake manifold and a stock throttle body. i did some searching and people have said the bov vaccum line should go to the top left nipple on the throttle body but i do not have any nipples above my throttle body. WHY!? instead i ran the vaccum line to the nipple on the bottom. from there it runs accross the motor and i have a T with one line to the wastegate actuator and one to the bov. i tryed running the vaccum line to one of the three nipples underneath the intake manifold but that didnt do anything for me either.
can anybody help?! i want power!
RpSinner is offline   Reply With Quote
Old 04-08-2007, 11:36 AM   #2
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
Never T your line to the BOV. Are you sure there are NO vacuum nipples on the top portion of your TB? There should be a larger one (run that one to your BOV) and there should be at least one more that attachs to the FPR.
mRclARK1 is offline   Reply With Quote
Old 04-08-2007, 03:18 PM   #3
RpSinner
i am positive that there are no nipples above my throttle body. i think that those went away with the stock intake manifold as i have a greddy replica manifold now.
ok so i understand now that i shouldnt T the bov and wastegate. can i run seperate lines for each of them onto the bottom nipples of the intake manifold?
Old 04-09-2007, 10:31 AM   #4
RpSinner
thoughts anybody?
Old 04-09-2007, 10:47 AM   #5
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
post pics of your TB so we can see what ur talking about
ladiesman8527 is offline   Reply With Quote
Old 04-09-2007, 10:52 AM   #6
mRclARK1
mRclARK1's Avatar
What I said before is a little misleading... there are no vacuum nipples on the top portion of the TB, they're dircetly above it on the intake manifold.
On the Greddy manifold there should be 2or3 threaded holes IIRC, above where the throttle body mounts, for attaching vacuum nipples to it. I'm just going from memory though, I don't have one myself.
Old 04-10-2007, 01:44 PM   #7
RpSinner
ok so i see those nipples under the greddy manifold. i hooked the bov to one. and for the wastegate do i HAVE to run a line to the intercooler piping or can that go to another one of my vaccum line nipples on the manifold?
Old 04-10-2007, 03:15 PM   #8
mRclARK1
mRclARK1's Avatar
Run it to the IC piping. Do you have a boost controller? If so, run the vac line from the wastegate to the boost control solenoid (assuming it's an EBC) and then from the solenoid to the IC piping.
Old 04-10-2007, 03:54 PM   #9
Crono562
Crono562's Avatar
Crono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of light
Yea that nipple below the TB that your talking about is before the butterfly in the TB which is definately not what u want.
The stock manifold has 2 nipples after the TB buttefly. You should have a hose running from one of these nipples to your FPR, this is also where i would recommend you T in your bov. Run a 2nd hose from the other nipple to your wastegate, you want to leave this as undisturbed as possible (as little Ts as possible) so you get better acuator response.
So find 2 nipples on the greddy (freddy? ) manifold that you can use to copy that setup
Cap off that nipple thats below the TB, dont need it.
And you should be good
Mikey "Whitey" Ernst
'www.justdrift.com'
Crono562 is offline   Reply With Quote
Old 04-10-2007, 08:46 PM   #10
RpSinner
mrclark1 says run the wastegate to the ic piping
crono562 says run the wastegate off a nipple on the manifold which is after the butterfly
so who is right or are both of you right? does it matter? is the a difference between the two sources?
-andrew
Old 04-10-2007, 09:11 PM   #11
g6civcx
g6civcx's Avatar
On the stock setup, the big nipple on the TB goes straight to the BOV/CBV. No T. The wastegate goes to the coldpipe.
http://srownersclub.com/faq/index.asp#fuel
The vacuum lines are simple: 3 lines start at the throttle body. The bottom one goes to the canister, block it off unless you are using the canister. The larger one on top runs to the bypass valve (BOV), there should be no tee's or branches - go directly to the BOV. The smaller top line splits to the fuel pressure regulator, and runs across the front of the engine to your boost gauge and/or the boost pressure port on your boost controller.
The wastegate gets its signal from the nipple on the intercooler piping. The Apexi boost controller stepping motors go in between the IC piping and the wastegate actuator.
Old 04-11-2007, 12:06 PM   #12
RpSinner
i have a greddy fmic and hot pipe and it does not have a nipple to hook the wastegate up to. so i tryed hooking it up to a vaccum line on the manifold but that doesnt seem to work. so i guess ill tap into the ic piping. should have going to the manifold work as well as to the ic piping or could i have something else going on thats wrong?
Old 04-11-2007, 12:08 PM   #13
RpSinner
the car idles ok but when i step on it and try to boost the bov will just go off numerous times, buck, bog, and hesitate
Old 04-11-2007, 12:14 PM   #14
mRclARK1
mRclARK1's Avatar
If you are sure there is nowhere to attach a vac line on your IC piping. Just drill a small hole in either your hotpipe or coldpipe and weld a small vac nipple for your wastegate, and you should be set.
EDIT: Start checking for boost leaks as well... especially around your BOV.
Old 04-13-2007, 12:13 PM   #15
pearlwhiteS14
pearlwhiteS14's Avatar
pearlwhiteS14 is an unknown quantity at this point
Can you connect the line from the wastegate into the turbo intake pipe or does it have to be the cold or hot pipe? I have a fmic and there is no hook up for the wastegate hose. Where is the ideal location for the wastegate hose to be connected to the system?
pearlwhiteS14 is offline   Reply With Quote
Old 04-13-2007, 02:11 PM   #16
mRclARK1
mRclARK1's Avatar
I just run my wastegate line to my hotpipe, it's the closest and easiest place to connect it too. Any intercooler kits I've ever used do not come with a place to specifically connect the wastegate. You just gotta make a place to connect it yourself.
Really anywhere on the IC piping will work.
Old 04-13-2007, 03:11 PM   #17
SRpetey
SRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really nice
So i guess my set up is incorrect too.
These are the two nipples i found on top of the throttle body.
This is the only one i found on the bottom
I used a T to connect the actuator from the BOV line
Right now my car drives really good. I havent had any problems.
So, is connecting the actuator with the bov bad?
SRpetey is offline   Reply With Quote
Old 04-13-2007, 09:36 PM   #18
pearlwhiteS14
What is the acuator?
Old 04-13-2007, 09:40 PM   #19
youngmanvr4
youngmanvr4 is making a name for him/her selfyoungmanvr4 is making a name for him/her self
Typo-actuator
For the ones who dont know, actuator senses boost pressure. Once boost is to actuator limit and shaft is pushed and opens the wastegate.
youngmanvr4 is offline   Reply With Quote
Old 04-13-2007, 10:03 PM   #20
speed_racerx
speed_racerx's Avatar
speed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to all
Send a message via AIM to speed_racerx
um.. i know ya'll guys are talking about vacuum lines and all. but i had a similar problem with my sr when it was off timing. when i would try to boost the motor would "sputter" and the BOV would go off like crazy.
mrclark1: why never run a T to teh BOV?
speed_racerx is offline   Reply With Quote
Old 04-14-2007, 09:37 AM   #21
tommy_thrash
tommy_thrash's Avatar
tommy_thrash is an unknown quantity at this point
How did you fix your problem, im having a similar problem, and i was running the WG off the bottom vacuum source in the TB. When I get on it it sounds like a boost leak and I loose power and the BOV sounds off a little, I check timing and it sometimes seems right and other times it is way off.
"I live my life a quarter panel at a time"
THRASH
garage THRASH racing
tommy_thrash is offline   Reply With Quote
Old 04-14-2007, 09:50 AM   #22
speed_racerx
well.. i had a friend look at it for me and he set the timing to 15 degrees BTDC(second mark from the right) and i have a vac line from the top left vac source "T'd" to the BOV and wastegate.
Old 04-14-2007, 12:48 PM   #23
mRclARK1
mRclARK1's Avatar
This isn't to hard really. lol
Just run your BOV to the large nipple above the TB on the intake manifold, and run the wastegate, or actuator, to the intercooler piping. That's the stock setup, go with what you know works, and if you have problems it's NOT your vacuum line routing.
Old 04-14-2007, 01:12 PM   #24
johngriff
johngriff's Avatar
The most ideal situation is to have No T's. The most important place not to have t fittings is the line for the wastegate actuator.
This line you want to keep less than 6 inches, do not t, and pick up pressure on the compressor housing, or right off the charge pipe, to attain accurate boost control.
Connecting the line on the plenumb side of the throttle body is asking for trouble.
As for the bov and FPR. Those need to be hooked up on the plunumb side of the thrortle body, if you would like the bov to release air, and fpr not to push too much fuel at low boost.
[email protected]
Old 04-16-2007, 12:26 PM   #25
RpSinner
well i got a thing from atpturbo.com called quick tap and tapped into the hot pipe and hooked up the wastegate. then i ran an individual line to my bov from a vaccum source.
as i was doing all that i noticed i didnt even have a line going to the vaccum nipple on my FPR...hmm THAT COULD BE A PROBLEM! so i hooked that up and now the car is just slow but not jerky...time to try adjusting the timing i guess...i hope all goes well
thanks everybody for your help
