Old 04-13-2007, 11:09 AM   #1
kenshinS14sks
kenshinS14sks's Avatar
kenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to behold
Steering pull during acceleration
I had recently changed out my rack and pinion due to leaks and torn boots, and my mech said they didn't bleed the air bubbles since normal driving would clear that up (including the "rumbling and shaking" during full turns at stops)
It did this before the rack and pinion change out but it was slight even afterwards...and is getting worse. The pull is always to the right when I'm on the accelerator and I have to steer a bit left, and between shifts, the car will straighten out again causing me to weave if i don't remember to anticipate and straighten out the steering wheel. When I'm cruising or in neutral, the car runs straight without any adjustments to the steering. So only during acceleration...and more acceleration = more pull
At first I thought it was an alignment issue so I went and got that done... According to them, the problem was radial pull but from my research, then it should still be pulling even when I'm cruising off the throttle
Do I just need to bleed it again or is there another problem that I'm not looking into?
Sorry for the long and possibly confusing post... I did the best I could in chronological order.
facebook.com/SodiumDanceCompany
kenshinS14sks is offline   Reply With Quote
Old 04-13-2007, 11:14 AM   #2
zerooath
98 Kouki Slicktop. Tip Dealer!
zerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to all
Send a message via AIM to zerooath
I sorda had the same problem and i did a brake change and bleeded the brakes and put new brake fluid and all that in it. It went away a little then i got a proper allignment and it went away completely. Your frame is straight and not bent a lil or anything like that?
also sry i couldnt be more help lol
zerooath is offline   Reply With Quote
Old 04-13-2007, 11:40 AM   #3
kenshinS14sks
I don't see why my frame wouldn't be straight... and if it wasn't, the alignment job should've detected it no?
Old 04-13-2007, 12:00 PM   #4
drewc87
drewc87 is a well-known jackass
i know some1 that had the same prob. make sure your lca's are tight.
drewc87 is offline   Reply With Quote
Old 04-13-2007, 12:03 PM   #5
cdlong
maybe a bad or weak bushing in the rear. a bad bushing could allow a change in toe more on one side that the other which would change the thrust angle (an alignment spec, should be zero when they're done).
cdlong is offline   Reply With Quote
Old 04-13-2007, 12:06 PM   #6
zens14
zens14 is on a distinguished road
sound like you'll need a good alignment
zens14 is offline   Reply With Quote
Old 04-13-2007, 01:05 PM   #7
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Subframe torqueing skew under accel maybe? How are the subframe bushings?
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 04-13-2007, 01:09 PM   #8
kenshinS14sks
everyone's talking alignment, but if it is...shouldn't it be pulling even during cruise without acceleration? and wth is a lca? (i'll do google right now, but just in case i don't find none)
Old 04-13-2007, 01:16 PM   #9
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
LCA =lower control arm
pbcstylez is offline   Reply With Quote
Old 04-13-2007, 01:32 PM   #10
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
If its your rack you will hear an annoying whine when you turn the wheel (like almost all Delta 88s make).
If you have aftermarket adjustable arm on the car you need to have a race shop or someone other than Sears do the alignment. These type shops dont know how to make correct adjustments to aftermarket parts. A friend went to Tire Kingdom and they fudged his tracking... car looks like its crab walking when going straight, but drives normal and alignment shows normal... when in reality the rear is off to one side. Also if you have stagered wheels, the rear is wider so they may toe the front in or, the rear out, to compensate which will cause the steering to react to everything.
Alot of possable issues... when you have adjustable links... pro-alignments only!!
Peace
Drew
Follow on IG - KoukiTheToolBox
MadScientist is offline   Reply With Quote
Old 04-13-2007, 02:50 PM   #11
kenshinS14sks
sorry i should've stated these things earlier... but the only after market i have are the kazama tension rods and nismo power brace... and my car is mainly stock on eibach springs and kyb agx shocks and a nismo 2 way
all parts are less than a year old besides the nismo which i got used ... the subframe seems ok too... =(
Old 04-16-2007, 11:16 AM   #12
kenshinS14sks
ok... so after an initial inspection...i noticed my rear passenger tire was a bit flat... at first it seemed ok but later in the day...it was noticeably flat. hence the pull only during acceleration... gg
goes to teach me to inspect the basics first before anything...
Old 04-16-2007, 12:23 PM   #13
pbcstylez
haha, glad you found the problem atleast
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
