Old 05-04-2007, 01:02 PM   #1
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
built sr20, no power?
im looking for a little advice on my sr20build here it is so far, with this set up it was dynoed on a dynodynamics dyno and made 325whp and 315ft/lb tq.
this is the setup.
redtop sr20det bored honed
eagle rods
wiesco 9:1 compression pistons .020 over
stock crank
hks 272 cams
crower springs and retainers
greddy 1.5mm headgasket
greddy intake manifold, oil pan
blitz intercooler
sard fuel rail, fpr, and 800cc injectors
tial 50mm blow off vlave, 38mm wastegate
hotshot manifold
custom t3/t4 garrett with a t04e turbine wheels in a t3 housing and a t04e compressor housing
custom 3in down pipe to hks downpipe, testpipe and hks hi power exhaust
hbc manual boost controller
koyuo rad electric fans
vlsd
4 puck bronze unsprung with a hd pressurplate
no ac no powersteering
tuning on a power fc d jetro
as i said the car made 325 whp and 315ft/lbs tq at 18 psi, full boost dosent come on till 4200 rpm, and it feels like the motor makes no low end power. The cams apper to be nearly retarted, the nut on the cas is righ t at the bottom. At wot the injector duty cycle is at liek 96% and its pulling out 41 deg igniton timing. the car backfires often and some times bogs between gears. theres only about 3500 miles on the motor. I have been told the igniton map is way off. what should i do. any help is appreciated
sr20boostn20 is offline   Reply With Quote
Old 05-04-2007, 01:10 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
you have higher compression pistons but a lower compression headgasket so you are probably below 8.5:1
you have extremely high duration cams
you have a decent size turbo
I think you are stuck with 0 bottom end power....
96% duty cycle for 800cc injectors does not make sense for that much power. You should fix your ignition map and fuel map.............What else do you want someone to say?
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 05-04-2007, 01:13 PM   #3
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
who's doing ur tuning??
s13gold is offline   Reply With Quote
Old 05-04-2007, 01:34 PM   #4
sr20boostn20
what should the ignition timing be?
Old 05-04-2007, 01:34 PM   #5
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
i think the tuning has allot to do with it, u should be doing allot more hp
drifting_changed_mylife is offline   Reply With Quote
Old 05-04-2007, 02:09 PM   #6
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
the intake manifold and the cams doesn't help low end,
but yeah, who's doing your tuning, or go to apex's website and find an authorized apex tuner, that way you'll know they're decent
Wei240 is offline   Reply With Quote
Old 05-04-2007, 02:47 PM   #7
street240
street240's Avatar
street240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nice
What are you spinning the motor up to? Still sounds like tuning.
The Gallo 24 would be a better motor for my skyline...But I am waiting on the swap dvd...
street240 is offline   Reply With Quote
Old 05-04-2007, 03:07 PM   #8
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
yeah sounds like tunning... is that duty cycle at wot under boost? sounds rich
Zzzz
bongnak is offline   Reply With Quote
Old 05-04-2007, 03:50 PM   #9
Wei240
could be the wastegate too, if it's not installed/adjusted correctly, it can have no low end power and suddenly feel all top end...
Old 05-04-2007, 03:55 PM   #10
johngriff
johngriff's Avatar
to4e pos, who sold you that?
are they still tuning on the commander?
41deg at 18psi at WOT? Are you sure? If that is true, post the name of the shop, because NO ONE SHOULD GO THERE.
[email protected]
Old 05-04-2007, 04:16 PM   #11
wootwoot
ol Johngriff, the quote was "its pulling out 41 deg igniton timing"
is it even possible to pull that much timing?....
Old 05-04-2007, 04:40 PM   #12
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I saw this car in action over the past weekend at Island, and like I told the original poster, he has 3 major things (IMO) to look at:
1.TIMING is WAY OFF. I mean, not a little, but the CAS was completly turned to the left (so much as there was no more adjustment left with the cas) This would explain a serious lack of power...I'd be willing to bet nearly 50 hp would be gained by readjusting it.
2. The valve cover should (again, IMO) be connected to a vacuum source in order to work properly. At a minimum he should be running a catch can, or directly back into an intake.
3. Fix the fuel leeak at the gauge...having a small fuel misting/seapage in the engine bay like that is not good at all.
I can't attest to the D Jetro and it's values at all (as that stuff is complete jibberish to me...I couldn't tell you good from bad in it), but the car (from my perspective) didn't idle to bad, and didn't in herently smoke. I didn't get a chance to hear the car down the track for audible misfire or problems though :/
I still think the main thing is attributed to the timing being completly off....
Old 05-04-2007, 05:00 PM   #13
sr20boostn20
motors reving to 8000
top recorded valve on teh power fc was most definalty 41 deg, and my friend took the car for a pull and i watched it pull that timing out. the shop the car was tuned at was rpm nyc, im not entirly sure they did the actual tuning but they are one of the shops apex told me to go to.
Whats up man hows it goin, the gauge has been replaced. no more leak
Old 05-04-2007, 05:03 PM   #14
johngriff
johngriff's Avatar
Yeah, the cas needs to be trued up, especially with the PFC where you cannot dictate tooth offset. So the setup procedure should be OEM. Unless it was placed in on the cam incorectly.
[email protected]
Old 05-04-2007, 05:04 PM   #15
johngriff
johngriff's Avatar
good shop, good dyno, wtf timing...?
This thread sucks without graph scans.
[email protected]
Old 05-04-2007, 05:36 PM   #16
sr20boostn20
i gotta run to work ill get the dyno sheetts up when i get back
Old 05-04-2007, 05:48 PM   #17
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
Redo the cas timing using the fsm and then load up enthalapys base map for the power fc. Then see how it runs. Also are you running a wideband? What were your afr's? And one more thing.I think you might have entered the wrong injector correction or injector lag time. That high of a duty cycle on those big of injectors is just retarded!
good luck
rps13drift is offline   Reply With Quote
Old 05-07-2007, 05:49 PM   #18
it should be doing way more!
