Old 08-04-2007, 10:55 AM   #1
ltsPureLuck
ltsPureLuck is on a distinguished road
Send a message via AIM to ltsPureLuck
HKS SSQV Install Alternatives
I was wondering if anyone used anything else besides the C-Clip to install the HKS SSQV. I have spent about 2 hours of my spare time trying to get the C-Clip in, even with the right tool. It either flings out into my room or just doesn't go in. Help me with suggestions installing this or other alternatives besides the C-Clip.
Thanks Zilvians!
ltsPureLuck is offline   Reply With Quote
Old 08-04-2007, 10:57 AM   #2
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
uh..sounds like your not using the right tool. its a simple task
ch1873857 is offline   Reply With Quote
Old 08-04-2007, 11:10 AM   #3
ltsPureLuck
i am, it even has the picture of it on the cover. craftsman 0.432-2.0inch internal/external ring pliers.
Old 08-04-2007, 12:42 PM   #4
RurouniMidnight
RurouniMidnight's Avatar
RurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to all
i just put the new hks in the other day with theses same craftsman snap ring pliers the best thing id say to do is if the hotpipe isnt on your car stabize it with something and while you squeezze the c clip get a friend to push it down with a flathead into the flange, i got the clip in in about 20 seconds.
http://nightparade.wordpress.com/
Join in on instagram @nightparade
RurouniMidnight is offline   Reply With Quote
Old 08-04-2007, 12:49 PM   #5
red s14
red s14's Avatar
red s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond reputered s14 has a reputation beyond repute
dude i can do it in like a minute with everything in my hand. really simple. is everything lined up right? your do have snap ring pliers right? ne ways good luck
S14 BACK IN ACTION
red s14 is offline   Reply With Quote
Old 08-04-2007, 10:15 PM   #6
ch1873857
the right tips help to. stop being a pussbaby and get it done! wimp.
i keed i keed
Old 08-05-2007, 09:28 AM   #7
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
i've seen ppl struggle with this. And they just can't use their heads. Take off the cover before you start messin with the C clip. Im pretty sure thats the way your supposed to do it.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 08-05-2007, 09:46 AM   #8
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
i use the 45 degree angle snap ring pliers.
I compress the snap ring.. get it "inside" the flange.. then use a screw driver to push it down into the slot.. u have to make sure that your pushing down on the BOV so that your squeezing the gasket.. but it takes all of 5 minutes.. 10 without snap ring pliers.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 08-05-2007, 10:47 AM   #9
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
yep i did mine in about 10 minutes without snap ring pliers. =] 2 flat heads
Review Thread
bardabe is offline   Reply With Quote
Old 08-05-2007, 11:36 AM   #10
WideS13
WideS13 is an unknown quantity at this point
I used JB weld.
No, really, I did, because some of the "HKS" flanges that are floating around out there are not machined properly. If you mount the SSQV on them, with the o-ring, and the snap ring fully seated you can still blow air around the seal. I used the o-ring and some JB quick (inbetween) and the snap ring to put mine on my EVO. I pressure tested it after about 50 miles, no leaks.
WideS13 is offline   Reply With Quote
