Ka24det Advice Needed !!!
What do you think of these specs ?
Greddy emanagement Greddy RS bov turbo timer boost controller b&m shifter AEROMOTIVE fuel pressure regulator walbro fuel pump 300zx fuel filter sr20det 370cc fuel injector t70 turbo 300zx LSD, 300zx Aluminum 4 piston Brake Caliper upgrade Full 3 inch APEXi exhaust system HID Its tuned to 230rwhp at 8 psi... Reliable ? something needed ? This Car is going to be daily driven to and from school, then work, and to local car clubs... Will it last ? |
LoL, its already put together.. and tuned to 8 psi.. Ive been told by plenty to change injectors and so i shall... probably goto 550's.. but what i ask is do you think it will last ? its gonna be my daily driver
#10 | |
WHY????? That turbo will barely flow enough on a 2.0 liter. The T28 will not make much power, might help a little on the spool but you'll be at 230-250 hp range all day no matter what injector you use. I recommend a turbo that moves a larger volume of are at a lower psi. Sure a T28 can make 350 hp at 28psi or whatever, but KA engine will not hold that kind of psi - with out major work. BTW I use stock injectors and a BEGI fpr with a t04b in combo to make 258rwhp at 8 psi. No tuning/afc/etc needed. just a good old fashioned wide band o2 sensor and a fuel pressure gauge. Terry
AKUMA WORLD Drift Buffet |
![]() Join Date: Nov 2004
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
if you change injectors you will need a tune. Why? because the computer will tell the injector to open at 50% when 50% open on a 370 is a lot different than 50% on a 550. i'm no engine expert though. and also, i don't see why 370cc should be bad with a t70? Won't the 370cc injector only LIMIT the amount of power it will put down?. And also, if its a good tune it should be fine. as long as you don't change anything you won't need a retune... IE sell the t70 and go to a t28. You'll def need another tune for that.
#12 | |
1st off wow at your avatar.. secondly i agree because im not shooting for any higher power.. i jus want a daily driver.. turn down for me is that i take the turnpike to school and will be tempted to boost 8-/.. and boost some more... |
