Old 10-25-2007, 10:27 AM   #1
240_de_Ville
240_de_Ville has made poor choices240_de_Ville has made poor choices240_de_Ville has made poor choices240_de_Ville has made poor choices240_de_Ville has made poor choices240_de_Ville has made poor choices240_de_Ville has made poor choices
Question compression loss
ok a buddy of mine has these numbers on his sohc ka...90, 60, 60, 60... what would be the cause of the compression loss? i was thinkin about buyin his 240 and putting my engine in his shell...since mine has seen better days. but if it was something somewhat cheap to fix then i would just fix his since it has less miles on it. any suggestions? and no droppin an sr in it at this time is not an option.
i like fried chicken with my rice.
240_de_Ville is offline   Reply With Quote
Old 10-25-2007, 10:37 AM   #2
ROADKILLS13
ROADKILLS13 is an unknown quantity at this point
its probly bad rings or seals. how many miles on the car?
ROADKILLS13 is offline   Reply With Quote
Old 10-25-2007, 10:40 AM   #3
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
check if the valve cover has blowby.
try opening the throttle while doing a compression test, then try a wet.
and did you try it while the motor was warm?
just pick up another sohc. those things are cheap! i have another in my garage just sittin for just incase times.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 10-25-2007, 10:47 AM   #4
240_de_Ville
i'm not too sure how he tested it. but he said he'd take 500 for it and i know the tires on it are worth 300 by themselves...soo...i was just hopin it was a simple gasket and that way i would have 2 runnin 240's. but i think i'm gonna put my engine it his and combine the best of the 2 and sell the other one. but more info on the compession loss is still need for a final decision...thanks
Old 10-25-2007, 11:00 AM   #5
Dream240
Dream240's Avatar
There's really three basic parts to compression.
1. Pistion rings/piston condition
2. Valve seal/timing condition
3. Spark plugs/gaskets condition
With three cylinders being at the same level, it's quite posssible that the 90 is due to excessive carbon buildup in the cylinder. Try some fuel treatment and Sea Foam to see if the levels don't change.
The rule for compression is as long as they are all within 12 psi(IIRC) of each other then your fine. Low compression numbers across the board are just a sign of a worn motor.
Old 10-25-2007, 04:14 PM   #6
240_de_Ville
well i think i am goin to get his 240 i will definatly try what you guys said i hope it works cause i really dont want to swap the engines. lol if i wanna do all that work i would want a better engine for it. thanks again
Old 10-27-2007, 10:08 PM   #7
240_de_Ville
thanks for the info guys. i have another thread with a "poll type" question but i didn't think it belonged in here but i wanna try to get as many opinions as possible this is the link....
http://www.zilvia.net/f/showthread.p...07#post1613307 check it out and let me know what you think i should do
