Old 11-11-2007, 10:11 AM   #1
SixSpeedSleuth
SixSpeedSleuth's Avatar
SixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to behold
Those with Topmount Turbo's and ROM Tune with MAF, Please Help!
I have searched religioulsy locally, so I'm going to expand my search. I'm running a TS 3071R Topmounted with an Enthalpy Rom tune. So, basically I'm still running a MAF. I'm sick to death of Maf turbulence, the car idling like shit, and the car cutting off if I don't manually "catch" the revs. I know this is Mafs turbulence, but I can't lengthen my intake pipe anymore unless I have a custom one made (I can't find ANYBODY locally to do this and I've searched). So, can everybody show me the picks of YOUR Intake Pipe setup with a topmount and Mafs? Or, if somebody knows a shop or can build me a pipe that will fit in my bay with the appropriate length/bends I will gladly pay somebody. Here is a pic for reference followed with my current setup.
Now, my setup at the moment.
SixSpeedSleuth is offline   Reply With Quote
Old 11-11-2007, 10:56 AM   #2
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
have you considered blow-through?
My iTrader rating!
babowc is offline   Reply With Quote
Old 11-11-2007, 11:04 AM   #3
2bad240
2bad240's Avatar
2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about
i have my pipe going down.
you, its whats for dinner.
2bad240 is offline   Reply With Quote
Old 11-11-2007, 11:11 AM   #4
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
I did blow through!
rps13drift is offline   Reply With Quote
Old 11-11-2007, 11:12 AM   #5
Josh K.
Josh K. is an unknown quantity at this point
get a map-ecu. I'll sell you my old version for cheap.
Josh K. is offline   Reply With Quote
Old 11-11-2007, 11:40 AM   #6
SixSpeedSleuth
With "Blow Through" do you mean routing the breather from the Catch can into the intake pipe after the Maf? Will that eliminate my problems?
Also, the poster that put his pipe "down". Did that elimanate the turbulence??
I'm just sick of the horrible idle and such. But, is does run fantastic under full throttle.
Old 11-11-2007, 11:50 AM   #7
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
blow through means you put the maf on the cold pipe after the turbo. before the thottle body, after the intercooler
Review Thread
bardabe is offline   Reply With Quote
Old 11-11-2007, 11:53 AM   #8
SixSpeedSleuth
Hmmm. Interesting. So, the Maf would function normally and this would eliminate all of the symptoms I described? Also, I could just bolt the Filter right onto the turbo with no Intake Pipe if I did blow through right?
Old 11-11-2007, 11:56 AM   #9
bardabe
bardabe's Avatar
exactly, also if you put the BOV before the MAF (hot pipe) you won't have any stalling or running rich betwen shifts issues.
Review Thread
Old 11-11-2007, 12:18 PM   #10
johngriff
johngriff's Avatar
an SAFC will fix this with the decel setting.
[email protected]
Old 11-11-2007, 01:07 PM   #11
SixSpeedSleuth
Will this fix the idle as well? I can't get it it to idle less than 1800 or so rpms.
Old 11-11-2007, 01:09 PM   #12
bardabe
bardabe's Avatar
he was talking about the running rich betwen shifts and stalling when getting off the freeway
Review Thread
Old 11-11-2007, 01:12 PM   #13
johngriff
johngriff's Avatar
Probably not, that sounds like you tps or timing, or AICV or TUNE is off.
I just know for a fact that one of the little things the SAFC does right is Decel AFM Signal trick, where you lift and the SAFC sends a flat voltage to the ecu for the MAF signal, fixes the Open atmosphere BOV dip and and turbulent maf air.
Unfortunately the SAFC doesn't make for a good tuning tool.
[email protected]
Old 11-11-2007, 01:13 PM   #14
bardabe
bardabe's Avatar
actually i really think its the MAF problem my buddy had the same problem. (Vinhisbored) we extended his intake pipe to 18" and walah! everything was A Ok.
Review Thread
Old 11-11-2007, 01:26 PM   #15
SixSpeedSleuth
Do you have a picture of this setup? I've looked the engine bay over, I just don't see anywhere to extend this to unless I have a custom Intake Pipe made with several bends. I've already purchased the Aluminum pipe, I just cant find ANYBODY willing to custom make one for me.
Old 11-11-2007, 01:25 PM   #16
SixSpeedSleuth
I think Bardabe is right. I did have an extra bend in my intake pipe, but it was not a smooth transition to the turbo, and I was losing power, however, it would idle right *most* of the time and would not cut off between shifts, ect, ect.
I've checked TPS voltage, my base timing is 15* and my tune is Enthalpy, and I DOUBT his tune is off. I've had 4 tunes from him with all spot on AFR and such. I have not checked the IACV, but it does not seem like a problem related to that.
So, from what I'm reading, a blow through setup would be the easiest way to rid all of these problems? Or, get a custom intake Pipe?
Old 11-11-2007, 01:27 PM   #17
2bad240
2bad240's Avatar
yea i had my maf to close and it was doing the samething you are talking about, my car would foul a set of plugs in less than 5 minutes, then i extended the pipe and it ran fine.
Old 11-11-2007, 01:29 PM   #18
2bad240
2bad240's Avatar
my pipe came from vibrant, it was like $26.
Old 11-11-2007, 01:31 PM   #19
SixSpeedSleuth
Picture or link? This is with a Z32 Maf and topmount right?
Old 11-11-2007, 03:36 PM   #20
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
To avoid this on a turbo KA setup, we ran the filter in the driver side front fenderwell area with the MAF shortly after it and a longer pipe going to the turbo. Seemed to work pretty well. BUT, then you have all the issues associated with a CAI, namely sucking up water if you go through puddles, etc. Could be hard to route depending on your IC setup also.
turtl631 is offline   Reply With Quote
Old 11-11-2007, 04:26 PM   #21
johngriff
johngriff's Avatar
flatter filter (like the hks... or ebay knockoff anyone?), and longer pipe, push it up against the fender well.
[email protected]
Old 11-11-2007, 06:26 PM   #22
SixSpeedSleuth
Thanks for the suggestion, but that's the step I'm at now. I had the JWT Pop Charger, but then bought an Power Enterprise Filter because of it's compact nature and I have it tucked as deep and as far into against the fender well as I could get it.
Old 11-12-2007, 09:53 AM   #23
SixSpeedSleuth
Anybody else have pictures of their setup?
Old 11-12-2007, 09:59 AM   #24
dkingkong
dkingkong is on a distinguished road
you're supposed to have at least 12" of piping from the MAF to the compressor wheel, right?
why not just route it down.
I've seen some people route the filter infront of the motor.. not a great idea!
dkingkong is offline   Reply With Quote
Old 11-12-2007, 11:38 AM   #25
turtl631
True, I've seen setups with the intake on the passenger side. You get a really long straight section of pipe that way, but you have to worry about clearing cold side IC pipes, clutch fan (if you still have it), plus possible heating of the charge air (doubtful). Actually, might not be a bad idea if you have room.
Old 11-12-2007, 11:43 AM   #26
DUBCITY
DUBCITY's Avatar
DUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud of
you guys that run MAFS on the gt3071 TS should order it with the 3" inlet instead of the 4". that 4"-3" reducer cant be helping the turbulence inside the intake.
DUBCITY is offline   Reply With Quote
Old 11-12-2007, 06:42 PM   #27
smelly240
smelly240's Avatar
its downstairs where u cant see it unless ur out front layin on the ground.
the extra width opening is for the ported shroud - the compressor wheels inlet is still little...
not driven in or around water... - just so u guys know.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 11-12-2007, 07:15 PM   #28
SixSpeedSleuth
Smelly240, thanks for the picture. I'm going to try and figure out something soon. Is there any way you can snap a picture of the actual Mafs and Filter location?? Thanks!
Old 11-12-2007, 10:40 PM   #29
turtl631
Good point on the 4" opening- I wonder if that significantly affects turbulence within the MAF when using a sharp 3"-4" transition coupler. From what I've read about the ported shroud housings, I'm not even so sure I'd want one, but that's besides the point if you already have it on there. I'd say that somehow relocating the filter and MAF to inside your front fenderwell is the way to go. Also try to keep the BOV recirc hose and/or catch can vacuum source far from the MAF is possible.
Old 11-12-2007, 11:04 PM   #30
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
SixSpeedSleuth, you have a PM. might be able to help fab one up for you
Pepperoni is offline   Reply With Quote
