Old 01-11-2008, 09:52 PM   #1
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Help with SR accelerating issue!
Well my problem is that I can't seem to accelerate my car without "pumping" the throttle. If I just go from closed throttle to wide open I can't seem to get the car to accelerate, even at idle.
Its an S13 SR redtop
370CC injectors
I replaced my MAF and am able to rev all the way to redline with ease.
I also checked my TPS, and its set at .37V closed.
I replaced the injectors with new ones from DW because there was always a cyclinder that kept flooding, even after changing the o-rings.
I've checked my timing at least 4 times already.
My vacuum is at 15Hg
I checked for boost leaks already with a boost leak tester and fixed the leaks. I dunno what else to look for really, so any suggestions would help.
duffman1278 is offline   Reply With Quote
Old 01-12-2008, 08:44 AM   #2
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
you sure you didnt replace the maf with a bad one?....i would check fuel pressure...maybe even spark plugs
ecuastyle84 is offline   Reply With Quote
Old 01-12-2008, 12:47 PM   #3
cotbu
cotbu's Avatar
I like my tps @ .45~v but, it may not be your problem. Test your mafs. You said you checked your timing. What was it? What's the condition of your clutch?
Old 01-12-2008, 01:14 PM   #4
duffman1278
My clutch is brand new. I'm going to see if I can find someone with a MAF I guess from a working SR.
As for the fuel pressure, I'll probably need to hook up a gauge to my line since I don't have one right now
Spark plugs are brand new
Old 01-12-2008, 01:49 PM   #5
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
Check your fuel pump. Had a problem very similiar to that. Once i changed my fuel pump, worked like a charm.
Good luck!
SidewayZ-s14 is offline   Reply With Quote
Old 01-12-2008, 01:57 PM   #6
duffman1278
But the fuel pumps brand new
Old 01-14-2008, 12:01 AM   #7
duffman1278
I turned on the car for awhile today after making sure my IC tubes were nice and tight, and also that the vacuum lines were tight. However, it was still the same results. hits 3500RPM at full throttle and wont pass that unless I "pump" the throttle. When I got back home though, I took out the spark plugs from the cylinders and noticed my number 2 cyclinder was STILL flooded, and seemed a bit worst. I could smell some fuel in the oil, so I'll be changing the oil for that before I drive it again. btw, I allowed tried allowing my cyclinder to evaporate the fuel by pulling out the spark plug for a whole day, doesn't seem to really go away. My other cylinders are dry, its just that number 2. I'll be making a fuel pressure gauge this week to hook up to the fuel line and see what I'm at..
Old 01-14-2008, 12:05 AM   #8
lazy240
lazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymore
hey if you want to take the fuel out of the cylinder unples the injector and take out all the spark plugs and turn the motor over a couple of times till theres no more fuel in there
lazy240 is offline   Reply With Quote
Old 01-14-2008, 12:08 AM   #9
duffman1278
I'll try that this week a than, thanks. I also forgot to mention that I readjusted the TPS to .4V closed.
It was at 4.0V at WOT. But that was BEFORE I took it for a drive.
Old 01-14-2008, 08:45 AM   #10
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
You seem to have gone pretty in depth with checking things over so you've probably already done this, but did you check your #2 coil pack? Try pulling it out while the car's idling and see if that affects anything, or use your timing gun to see if it's getting spark.
Also worth mentioning that -15 in vacuum seems a little low, my mostly stock SR pulls 19-20.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 01-14-2008, 12:15 PM   #11
duffman1278
O yea, thanks for the idea shift, I forgot to try the coilpack thing. I'll try unplugging that as well. I changed over some vacuum lines last night also with something that would fit tighter to see if that helps.
Old 01-18-2008, 09:16 PM   #12
duffman1278
Alright, so I didn't get to turn on the car today but I turned the key all the way so that the fuel pump came on and I took a pic of the pressure in my fuel. I dunno if this helps but tomorrow I'll take another one with the car on.
Old 01-18-2008, 10:54 PM   #13
fakts13
fakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nice
@43psi w/o vacuum is right for most cars, so it looks like your fuel pressure is good. check your #2 injector wiring, you might have a short, causing the injector to stay open and flood the cylinder. even if you're not getting spark in that cylinder, you shouldn't be flooding it with the stock injectors, it seems more like it's stuck open if it's flooding.
fakts13 is offline   Reply With Quote
Old 01-19-2008, 02:13 AM   #14
duffman1278
Hmm I gotta find out how to look for a short than. Thanks alot
Old 01-19-2008, 03:04 AM   #15
fakts13
if you have a noid light, see if it stays on when on the #2 injector plug (harness side), or if it blinks. if it blinks, it's more than likely okay. if it stays on, you have a short. this should help you in determining if trying to find a short is worth your time or not. also, have you checked to see if the seal on injector 2 is good? i know you said you put new o-rings, but maybe something might be wrong with the rail?? it's a long shot but you never know.. just unbolt the fuel rail, turn fuel pump on and see if anything is dripping/leaking out of that injector area.
Old 01-19-2008, 03:09 AM   #16
808_Drift
808_Drift's Avatar
808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light808_Drift is a glorious beacon of light
Yea i used to have similar problem with my spark plugs, also like the others said check your coilpacks since they can cause similar problems. Also check the engine harness around the fuel rail area. I had a clip broken on my old one and sometimes it would not connect. I hope this helps and i hope you figure it out!
808_Drift is offline   Reply With Quote
Old 01-19-2008, 03:14 AM   #17
duffman1278
Alright so I'll check for that stuff later on in the day today and hopefully it fixes it. I've taken the fuel rail out before and turned the key on just before starting it and NOTHING leaks out. I even put a towel to it and there were no marks on it. Kind of a noob at electrical but is a noid light a test light?
Old 01-19-2008, 04:45 PM   #18
duffman1278
So today I cranked the motor a few times without the fuel pump on to try and get out the excess fuel. After that I blew some air into the cyclinder to dry it up.
I also changed my vacuum lines with brand new ones but now the car wont even idle anymore!
I noticed that my fuel pressure when I pumped the throttle from the engine bay, was going from 39-40 psi. I dunno if thats normal?
I'm uploading a video right now which I'll post up asap.
Old 01-19-2008, 05:32 PM   #19
KasperSlide
KasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choices
adj. tps to .45-.5V. a noid light checks the pulse of the inj. it will light up when the inj. opens
KasperSlide is offline   Reply With Quote
Old 01-19-2008, 05:42 PM   #20
duffman1278
I don't have a noid light but I did use a stetescope and I could hear a constant *click click click click click* sound. I'll go adjust the TPS soon. Thanks
Old 01-19-2008, 05:56 PM   #21
duffman1278
Here's the video
http://s5.photobucket.com/albums/y17...t=MOV03939.flv
Old 01-19-2008, 08:26 PM   #22
duffman1278
I readjusted my TPS so that it was .32V closed throttle and the idle was perfect, it went back to normal HOWEVER, when it was running, I decided to pull each injector plug individually and I noticed that as I pulled them, all but the second cylinder were were causing the engine to turn off. When I unplugged the second cylinder injector, the engine ran normal at idle, as if I did nothing to it.
Old 01-20-2008, 01:44 AM   #23
fakts13
have you pulled out the #2 coil while the engine is running and checking to see if it sparks?
Old 01-20-2008, 01:47 AM   #24
duffman1278
I'm gonna swap coil packs with one that works tomorrow and see if that makes a difference. But last time I checked, which was awhile back, their was spark on all 4 coils. I'll test it again tomorrow.
Old 01-20-2008, 02:00 AM   #25
fakts13
also, are you sure it's fuel that's filling up the cylinder? maybe it's oil instead?
Old 01-20-2008, 02:01 AM   #26
duffman1278
Hmmm, thats a good point. How would I clean that out though? And really, it doesn't look like oil at all, has more of a thin liquid type of look, not thick.
Old 01-20-2008, 02:05 AM   #27
fakts13
does it smell like gasoline? that's the easiest way to tell. (smell the spark plug)
Old 01-20-2008, 02:06 AM   #28
duffman1278
O YEA!, smells like it big time.
Old 01-20-2008, 07:37 PM   #29
duffman1278
So today I swapped the coilpack with one that works and still didn't make a difference, which means its not the coilpacks.
I also pulled out the plug injector that is causing all the problems to see if it would make a difference. Well like the video will show, the car runs the same with or without the injector plug in. What could be going on? I might order a set of noid lights this week unless someones got one local that I can use to test out?
http://s5.photobucket.com/albums/y17...t=MOV03958.flv
Old 01-21-2008, 12:37 AM   #30
fakts13
did you actually check the coil to see if it's sparking? coil might not be the problem, maybe the wiring is bad. pull the coil out , plug it in and put a spark plug on it while touching the thread on the spark plug to the valve cover or intake manifold. that will tell you if you're actually getting spark or not.
