Old 02-06-2008, 08:02 PM   #1
rb25jun
rb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the roughrb25jun is a jewel in the rough
Send a message via AIM to rb25jun
s14 Blitz DSBC / Apexi Timer Help
so i have everything hooked up. but for the life of me i cant figure out how to check boost or set my boost. tried the search but found old unanswered topics. maybe someone can help me out..
something weird is happening also.. the unit is showing -36 cmHG... how do i change it back to hkpa..?
i set the gain to 20. i turned off the warn and limit feature... someone please offer some advice.
as far as Apexi Timer i searched and found a lot of different results...
i just want to hard wire because i bought the harness and it doesnt work. the accessories work but the engine wont crank.. and when the timer counts down everything turns off like it should..
all i want to know is where i tap the blue and green wire to on my ignition .. greatly appreciated .. the red goes to a 12v constant ..right?
i have a 97 s14 se w/blacktop sr20 t25
rb25jun is offline   Reply With Quote
Old 02-06-2008, 09:50 PM   #2
cotbu
cotbu's Avatar
set your gain 15 set your ratio to 30 set your warning to 1.00 set limiter -5
you do have a boost gauge right? Also your vac seems low, I thought my -46 cmHg was low....
If you want boost to come on faster change the gain, if you want higher boost change the ratio (0 = stock anything else is a % over stock)
leave scramble alone, till you know what your doing!
Got a wideband? your tuning my friend....
Old 02-07-2008, 12:13 PM   #3
rb25jun
wow.. thanks man ill try it as soon as im off from work
Old 02-07-2008, 02:21 PM   #4
rb25jun
nobody know how to hardwire a turbo timer??? ive searched but mixed results????? someone help?????
